velky bobo Big Audio Druid
Zaslal: St december 09, 2009 01:32:40 Predmet: ARTA |
Pokud to někoho zajímá a ještě o tom neví neví, je nová verze ARTA - v1.6.0 _________________ Nemám nic proti hifi, vadí mi jen hifisti. Ale technokraty taky zrovna nemiluju.
http://www.kvakeri.cz/ |
godz Hifi expert
Zaslal: St december 09, 2009 09:21:49 Predmet: |
Vďaka za info. Mateljan rozdával mikulášske darčeky. Cez víkend skúšam. |
Zaslal: St december 09, 2009 11:14:57 Predmet: |
Dík za info, je tam něco nového, co by stálo za upgrade? |
Zaslal: St december 09, 2009 11:20:02 Predmet: |
Nevím, nestudoval jsem to. Ale asi to bude ppsané na webu autora. _________________ Nemám nic proti hifi, vadí mi jen hifisti. Ale technokraty taky zrovna nemiluju.
godz Hifi expert
Zaslal: St december 09, 2009 12:56:30 Predmet: |
New features, implemented in program ARTA, are:
- Signal recorder now function as storage scope with triggering capabilities on both channels, with predelay and postdelay.
- For recorded signal the gated spectrum analysis and Short-Time Fourier waterfall plot are possible.
- Import from wav and ascii files can be analysed as IR or signal time record.
- A contour plot added for the presentation of directivity patterns.
- In reveberation window, the 95% cut of tail enabled.
- In all time windows 8 x zoom enabled, with zoom report on graphs.
- A button is added to Imp window control bar, for setting cursor on position of max amplitude.
- New tool: Two-channel voltage level meter and 1/3 oct. analyser.
- Enhanced FR target filter generation.
- Difference mode - in Fr1, Fr2, Spa - shows difference of Magnitude and overlay levels.
Following bugs are removed:
- Arta 'Load target' command - accept files with arbitrary number of points (removed hidden restriction on 720 points)
- Arta peak meter in SPL windows is tracking the peak in every recorded blocks
- Limp correctly reports Le.
- Steps correctly reports X-axis values in Distortion vs. excitation plot. |
L.V. Hifista - zaslúžilec
Zaslal: Po február 22, 2010 18:40:14 Predmet: |
Potreboval by som radu. Meriam cez loopback zvukovku M-Audio Audiophile 2496. Pokiaľ viem, pri meraní THD by mali byť lepšie výsledky pri nastavení vyššej samplovacj frekvencie. Samozrejme za tej podmienky, že sú parametre správne nastavené /rovnako/ v Control paneli zvukovky a v nastavení Arty.
Prečo mi potom vychádza spektrum "čistejšie" pri 24/48 ako pri 24/96 ? Používam OS Vista 64. Dík za radu.
Tu je meranie pri 24/48: _________________ Tam, kde leží Little Big Horn ... |
Zaslal: Po február 22, 2010 18:40:42 Predmet: |
24/96: _________________ Tam, kde leží Little Big Horn ... |
Zaslal: Po február 22, 2010 19:26:57 Predmet: |
January 3, 2009.
ARTA version 1.6.1 is published (see download section).
- Saves background color in registry.
- IR measurement dialog gets check box 'Close after recording' to close itself after recording.
- Alt-R-R-R starts and closes measurement in PIR window.
- Alt-R-R starts and closes measurement of PIR in FR window.
- Envelope and Step response windows remember the zoom ratio.
- Shorcut keys for Cursor movement: Home (to 300 sample) , Del (to 0 sample).
- Shorcut keys for Cursor movement are: Crtl+Home (to 300) , Ctrl+Del (to 0), Ctrl+Ins (to cursor).
- Signal recorder can do a triggered time averaging.
- Spectrum estimation of gated recorded signal now gives an averaged spectrum of ovelapped segments.
Foollowing bugs are removed:
- Contour plot appears after reopening the directivity window.
- In correlation graph the background color now trace the global backgound color.
- Spectrum overlay does not depend on type of window (if made in PSD mode must be used in that mode). |
5er Hifi obsluha
Založený: 19 február 2008 Príspevky: 7 Bydlisko: Bratislava
Zaslal: Ut december 21, 2010 18:13:28 Predmet: |
Pokiaľ to neviete, je vonku ARTA version 1.7.0. |
Zaslal: Št marec 28, 2024 09:23:56 Predmet: |
citácia: | 5. března 2024; Důležité upozornění:
Životnost projektu ARTA skončila.
Po více než dvaceti letech vývoje softwaru ARTA jsem se rozhodl ukončit vývoj a věnovat se sám sobě.
Splnil jsem svůj slib, že uživatelé ARTA dostanou všechny verze 1.x.x. zdarma.
Pozn:
1) Prodej ARTA bude ukončen 30. března 2024.
2) Firma ARTALABS být uzavřena v dubnu nebo květnu 2024.
3) Webové stránky ARTALABS budou aktivní do února 2025. Ke stažení bude k dispozici poslední verze a podpůrné soubory.
4) Doufám, že software ARTA budete moci používat v systému Windows ještě mnoho let (dokud bude systém Windows podporovat 32bitové programy).
S pozdravem,
Ivo Mateljan |
DeepL preklad z https://artalabs.hr/ |
