myschovip Hifi obsluha
Založený: 08 január 2016 Príspevky: 14
Zaslal: Ut júl 25, 2017 09:23:56 Predmet: Zahorenie slúchadiel |
ahojte, kupil som si sportove sluchadla Audio-Technica ATH-Sport3, zahoruju sa aj taketo spuntove sluchadla? alebo u nich to nema moc vyznam, nikdy som nemal kvalitnejsie spunty, aby som spozoroval, ci sa nejak zmeni kvalita zvuku po zahoreni,
ak sa taketo spunty zahoruju, aky sum alebo co mam do nich pustit? staci len normalne pocuvat hudbu a nestarat sa o sum ani nic podobne? aby som z nich dostal maximum |
Založený: 08 september 2010 Príspevky: 11492 Bydlisko: Praha
Zaslal: Ut júl 25, 2017 10:05:30 Predmet: |
tym, ze budes normalne pocuvat hudbu nic nepokazis, a ani ruzovym sumom na nizkej hlasitosti :-) |
Zaslal: Ut júl 25, 2017 10:18:05 Predmet: |
cital som zase nazory, ze ruzovy sum moc neodporucaju, neviem co je na tom pravdy, asi sluchadla zahorim iba hudbou ktoru pocuvam a na sum sa vykaslem, pri spuntoch zahorenie mozno ani nema velky vyznam kvoli ich malickym membranam, ale mozno sa mylim |
Zaslal: Ut júl 25, 2017 10:30:56 Predmet: |
citácia: | Shure has tested some thoroughly used pairs of its E1 earphones, which first launched in 1997. And guess what? They measure the same now as when they came off the line. In fact, during the 15 years Shure has been actively selling earphones, its engineers have reached the same conclusion again and again: The sound produced by these tiny transducers during final testing is the same sound you'll get in a day, in a year, and in five years... unless something goes wrong.
So next time you buy a new pair of earphones, try this alternative ritual: Open the box, remove the earphones, put them in your ears (using the correct method, of course), and then start playing music. Like the way they sound? Great. Keep them. Don't like it after a day or two? Return 'em. Even if you brain says otherwise, the sound they produce isn't going to change. |
Zdroj: https://www.wired.com/2013/11/tnhyui-earphone-burn-in/ |
moses Hifi expert
Založený: 17 november 2012 Príspevky: 1901
Zaslal: Ut júl 25, 2017 10:56:01 Predmet: |
Asi tak. Normalne ich pocuvaj a uvidis (teda zacujes ). S experimentovanim s nejakymi frekvenciami stratis iba cas a pripadne ich este aj poskodis... _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
