sekal Hifi expert
Zaslal: Po september 07, 2015 13:34:44 Predmet: |
On odpovědět dost dobře nemůže, poněvadž zpochybnit se ten rozbor BV dost dobře nedá a při záporné odpovědi by přiznal, že za 2 konc. zesilovače, jejichž moduly se v PA audio prodávají za ca 7000,- Kč/kus, on vysolil zhruba třináctinásobek. |
Zaslal: Po september 07, 2015 16:43:57 Predmet: |
Daň za ignoranciu.. |
aretax Hifista - pokročilec
Zaslal: Po september 07, 2015 19:13:26 Predmet: jeff rowland |
Basstl: Chcel si odpoveď pre BV? Tu ju máš:
http://www.dagogo.com/jeff-rowland-design-group-501-monoblock-amplifier-reveiw
The ICEpower™ technology inside the 501 derives from Dr. Karsten Nielsen Ph.D., a Danish designer. In 1994 he used a government grant to develop a more efficient power technology for amps. Bang & Olufsen (known as B&O) made a significant investment in the resultant company, ICEpower. The 501’s use the ICEpower module. Class D chip amps (not to be confused with true digital amps) like ICEpower, Tripath and H2O are opening up a new world of extreme power for the average listener. Previously, with class A/B, very few 1,000 Watt designs were available and they were priced into the ionosphere. The rank and file audiophile can’t afford mega buck amps – $10k is still beyond the pale of most enthusiasts. But the 501 offers authentic hope that in years down the road trickle down effect will bring into view much more affordable power. Jeff is already bringing several aspects of primo amplification into financial reach with these $7k per pair specimens _________________ 112233 |
Zaslal: Po september 07, 2015 19:46:15 Predmet: |
Takže ty si ešte ušetril. 1000 W A/Bčko bude veľká, ťažká a drahá krava. Posledný víkend sme viacerí počuli vedľa seba Dčko a A/Bčko.... dá sa počúvať oboje. A ja po tvojom poslednom príspevku mám chuť si kúpiť neDéčkové Dčko Jeff Rowland. Doug Schroeder ma so svojou recenziou dostal. |
Zaslal: Ut september 08, 2015 09:01:00 Predmet: |
aretax
Si ako špatne vycvičený papagáj.. Vieš aj niečo iné, ako copy/paste textu, ktorému (obsahu) absolútne nerozumieš? Tušíš aký je rozdiel medzi "digital amp" a classD? Ani náhodou.. Zato si to zvýraznil. Ale ani jeden z nich nie je "v signálovej ceste kompletne analógový", to ani náhodou.
Ale si ideálny zákazník, kúp si ešte bybee quantum purifier a budeš mať všetko.. |
Zaslal: Ut september 08, 2015 09:36:30 Predmet: |
Aha, tak v tom je problém. On netuší že trieda D a digitálny zosilňovač je to isté..... |
Zaslal: Ut september 08, 2015 09:40:39 Predmet: |
to akoze z ClassD zosilnovaca lezu jednicky a nuly, ci ako mate definovany digitalny? :D |
Tico Hifista - zaslúžilec
Zaslal: Ut september 08, 2015 09:48:26 Predmet: |
2 místo: To je, předpokládám, otázka na toho pana recenzenta, na kterého se aretax odkazuje, ze? _________________ HTPC/Foobar/Esi Juli@/WaveIO -> BB-DAC -> Customworks HYPA1+Actidamp mk4 -> DPA222Mk3 SE + DPA386SE -> B&W704, Sony ST-SB920QS, Sony CDP-XB930QS, AKG K701mod. |
Zaslal: Ut september 08, 2015 09:54:11 Predmet: |
miero napísal: | to akoze z ClassD zosilnovaca lezu jednicky a nuly, ci ako mate definovany digitalny? |
Class D mají definovaný všichni stejně, není to lineární zesilovač pracující ve všech stupních se spojitým signálem, ale pracuje ve (výkonové části) se spínaným 2-úrovňovým signálem, většinou na principu impulsové šířkové modulace, tento modulovaný impulsní signál pak pomocí filtru typu dolní propust převádí na spojitý analogový výstupní signál. _________________ mám rád hifi, ale víte, jak je to dál ..... |
BlackBerry Hifi inventar
Zaslal: Ut september 08, 2015 09:57:48 Predmet: |
http://www.zones.sk/studentske-prace/basne/10860-basnicky-na-hviezdoslavov-kubin-pre-6-rocnik/
Krajolik
Na skaline zápoline, sedí jumo plnodumo,
pred ním šíra úbočina, strechoklonná sihlovina.
Spredku sihla roztvorená, tam koliba postavená,
nad kolibou začadenou, pod zelstenou sihlovenou,
košiar kolo obhatený, rud haluzne obložený.
Zníž koliby prosto k predu, doskokryté strungy sedú
a pod nimi honelnica, ležmožŕdna bel-plotnica.
Pred honelnou k zápoline, na zelenej pažitine,
nad dolňou radosihlinou a zhora pod boriovčinou,
neridzia si stádo bielo, ležiac akob´skamenelo.
Čad-koliba ticho stojí, v nej si čušia chlapci svoji.
Tá koliba začadená, strmodáškom zadoštená,
stojí ticho si pod stenou, sihlo i jelozelenou.
Zvežičkaná to lesina, strechoklonná zel-bočina.
Konča nej od chrbtoviny, spoza výsosihloviny,
Zdvíha sa homol zelená, ku spodku strmohlená.
Od homole z priehybina, voznesujús horhoriny,
Velboravy z neb-horavy, nad sihlami rozgrúňavi,
rozgrúňavi do polkola, proti zápoline spola.
Od priehyby nad šírgruňom, sihlostrmým zelerúňom,
na najvyšší široštít, ostrokoná tvrdonít.
V jeho straze a žltzeli, kosodrievne ruozosteli,
šarzelené ruozochrasty, neobhrúbne zemo-plasty.
Od šírštíta kolklonená, nižšia rázlebeň zelená,
po nej s´ kosodrevné chrasty, šarzelené samopasty.
Zemoplazne hustopasú, ponad rázčel skal-belasú.
Pod skalčekom šarolesy, dvojkloň grúňom sihlonesy,
od zelenej rázlebiny, ďalším kruhom velvýšiny,
zasi strmý široštít, trochu menší zel-tvrdít.
De tu chrastom pošarený, štrochojarkom predelený.
Pri ňom kruhom velvýšiny, strmoboké úšustiny,
ponad šedé úšustavy, dlhostrešné zel-výšavy,
zas dutá zel-hrvolina, pod ňou strmá zbelavená,
od zelhrbu do výšiny zdlhá-dvižné sklepeniny,
poborené stražšústiny.
Vyššej zelné múranesy, obloležmé pokrovesy,
po nich kríčky zelšarné, sihlovitky zakrpené,
pozniž sihly rozostrené, strm zel-grúne zjašútené.
A pri oblopokrovine v trochu vyššej nebovine,
ešte šíra obgoruna, strmsihlistá rozhoruna,
v tele skálim obkladuňa.
Pod jej telom vňusklonená, oblokrivá grúň-horena,
vrchom sihlo-zhrebenená,
nad strmsihlu zel-šarenú, v čele skalu má vnorenú,
skalomodrým polookom, škúli dolom prehlbokom,
i na juna v zápolinu, v protispolnú nížskalinu.
Pod zápolou vôbočinka, zelrovienok košarinka,
de tu skálim posypaná, bujnozelom zarastená.
Len pri samej zápoline, šumí vetrík po jeline.
Jela stará pňošeravá, len vrchovcom haluzavá
sama stráži zápoliny, ale kolo vôbočiny
z krajoriadnej strmprepasti, sihlojelaň vysorastí,
tam pod šírou strmbočinou, sihlojelo bukovinou.
V hlbodiali lesokryté hučia vody šumšumité,
zrozogrúňov donosité.
Velborava strmhorava, popod nebo zel-šarava,
za kolibou od sihliny zelvežunej chrbtoviny,
zel-homolou napočatá, široštítom vysočatá,
rozklonami štít-strechami do polkola rozhoratá,
ponad šíre sihloravy, strmoklonné zelšaravy,
roztobožne sa roztvára, svojmu junu prihovára.
Pod šir-štítom ostronitom, rozochrastne pozakrytom,
od rázlebnej skalčeliny dolu sihlou rázdaliny,
rozobkrivné jarkoviny.
Zmenša štíta ostronitá, z jeho jarka štrochovitá,
sihlokrytá jardelita, v zelrázvrší temolinie,
k druhu jarku v klin sa vinie.
Od zelhrbu spod blau-skaly, ten sa kamnojarok valí,
dol zelgrúňami do rázdola – kde skrytá vodovýmola,
medzi lesom šuchoráňa, k nej od stráne obgoráňa,
spod sihliny dolu štrochom, šumí jarček striebrotokom,
v krytom hlbodole sa sníma Grúňojarkov potočima.
Z proti-spolnej zápoliny ponad košariny,
za zelveže strmbočiny.
Do hĺbavy jumo hľadí, uchom vodošum sa radí,
velboravou rozgrúňavou, zelšarenou rozhoravou,
sin-obláčky preletujú, vetrošumy podychujú.
Vetrovodohukošumy, buďte ducha môjho dumy,
velborava širzelená, buď mi v Bohu zbajonená.
Jozef Kozmon
Tak už to prišlo, už niekto stlačil gombík,
pamätáš sa na hríbik, ty náš malý zombík?
Na hríbik žiarivý, nad strechami sveta,
keď vzbĺkla mamička, roztieklo sa dieťa.
Chodieval si k moru, poháre mal plné,
teraz si si zasurfoval na tlakovej vlne.
Červy a potkany ti lezú pod tričko,(lezu jednicky a nuly)
vydrž pár dní, staneš sa kostričkou.
Bez údov sa nedá vykonávať sex,
takisto sa nedozvieš ako skončí Rex,
nesyp si však na lebku nukleárny popol,
však ten svet predtým až tak dobrý nebol
Štefánia Pártošová - A keby zas
Kto seba druhým nedával,
v ulite dušu schoval,
kto do hviezd oči nedvíhal,
schol bez teplého slova,
kto miesto boja líhal si
spokojne na pažiť,
ach, tomu škoda, preškoda
bolo na svete žiť.
Kto pravde cestu nedláždil,
do búrok bál sa vkročiť,
kto v teple driemuc na peci
trýznivé nemal noci,
komu cez prsty pretiekla
zázračnosť ľudských síl,
kto v iných seba nenechal -
načo sa narodil?
Kto vieru v prehrách roztratil
a nenašiel ju znova,
lež k brehom svojej porážky
pokorne zavesloval,
kto na plytčinách utopil
kyticu mladých liet,
nič nedarujúc nikomu -
zbytočne uzrel svet.
Kto nikdy láskou nevzbĺkol,
šanujúc sviecu žitia,
kto poryv suchých citíkov
na zisky prepočítal,
kto chladný ako meteor
sám seba vyžiaril,
ten môže mŕtvy za živa
vystrieť sa na máry.
Ja požehnávam ušlé dni
búrlivo pulzujúce,
a keby bolo treba zas
vytasiť vlastné srdce,
i s krvou ho ja rada dám,
života neželúc,
len aby ľuďom na cestu
zasvietil jeho lúč. |
Zaslal: Ut september 08, 2015 10:03:30 Predmet: |
PMA: Pekne vysvetlene! :)
Ale oznacovat to za digitalny, mne - cloveku z IT, pride zavadzajuce. |
Zaslal: Ut september 08, 2015 11:45:22 Predmet: |
Správnejšie by bolo hovoriť o spínanom konci, ale asi kvôli označeniu triedy "D" (alebo kvôli dvom stavom "zapnutý", "vypnutý") sa hovori o digitále. |
Zaslal: Ut september 08, 2015 13:38:04 Predmet: |
Pojem "digitál" je zmätočný. Napríklad pri telefonovaní mobilom sa signál prevádza do paketov binárnych a komprimovaných dát no kvôli tomu sa to nevolá ani digitálny ani binárny, ani paketový a ani stratový telefón...
No nič, je mi jasné je to už zažité, ale správnejšie je to nazývať dčko než digitál... a je to i kratšie :) |
sekal Hifi expert
Zaslal: Ut september 08, 2015 13:39:25 Predmet: |
Já bych si jen dovolil poznamenat, že za ca 8000,- €, co stály ty monobloky JR 501, lze pořídit i velmi kvalitní konc. zesilovače tř. A/B od zn. Bryston nebo Parasound, které mají téměř srovnatelný jmen. výkon, jako diskutované monobloky JR. To jen pro zajímavost.. |
Zaslal: Ut september 08, 2015 13:58:07 Predmet: |
To je uz jedno, mozno bol ciel usetrit ... a ked uz nie peniaze, tak aspon elektricku energiu. |
Zaslal: Ut september 08, 2015 14:03:21 Predmet: |
Dosť by ma zaujímalo čo si aretax predstavuje pod pojmom "digitálny zosilňovač". Alzákov spievajúcich "We don't need no education!" ? |
šeďour Hifista - zaslúžilec
Zaslal: Ut september 08, 2015 16:08:08 Predmet: |
Já mám v zesilovači tohle...
Class-D Power Amplifier by ABLETEC, Norway, 90W/ch of output power (at 4 ohms)
Ale nestálo to 8000 euro |
Zaslal: Ut september 08, 2015 16:40:49 Predmet: |
miero napísal: | PMA: Pekne vysvetlene!
Označoval jsem to snad tak? _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Ut september 08, 2015 17:08:42 Predmet: |
To uz ale nepatrilo tebe... :-) |
Zaslal: Ut september 08, 2015 17:15:31 Predmet: |
Jako "digitální zesilovač" (i když to slovní spojení je tak trochu nesmysl) bych asi označoval něco, co má jako vstup digitální data, v různém formátu. Teprve jako o dalším bych se bavil o metodě zesílení a finálního převodu na analogový signál. Jednou stejně bude něco jako elektroakustický měnič se vstupem v podobě binárního signálu. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Ut september 08, 2015 17:49:51 Predmet: |
Za idealny digitalny zosilnovac povazujem zariadenie, ktore pouzival Neo v Matrixe |
Zaslal: Ut september 08, 2015 21:44:57 Predmet: |
miero, ty máš doma asi to naj čo sa dá momentálne zohnať v D triede. |
Zaslal: Ut september 08, 2015 21:56:48 Predmet: |
Tak pozeram, ze uz vysla i (negativna) recenzia komercnej verzie nCore a to zosilnovaca Kaluga Brunovej znacky Mola-Mola.
Predpokladam, ze tie DIY nCore na tom zvukom nebudu lepsie, takze odcitujem veticku zo zaveru:
citácia: | There is just no way one could consider both, the analog and switching amps equally capable of materialising that grand illusion of performers playing and singing in front of us - this is just impossible due to huge differences in sound. |
Zdroj: http://www.monoandstereo.com/2015/08/mola-mola-makua-and-kaluga-review.html |
Zaslal: Ut september 08, 2015 22:12:53 Predmet: |
citácia: | [Here it’s instructive to note that amongst Ncore OEMs today already are Acoustic Imagery, Bel Canto Design/Bel Canto Black, Jeff Rowland, Merrill Audio, NAD and Theta Digital – Ed] | Zdroj: http://6moons.com/audioreviews2/molamola/3.html
Takze novsie vyrobky JR by mohli byt este lepsie nez tie stare... |
Zaslal: Ut september 08, 2015 22:46:06 Predmet: |
Vlastne uz nieco s GaN FETmi existuje. No nie ClassD ale vyrobca tvrdi, ze je to non-feedback full-digital amplifier.
Zdroj: http://www.technics.com/us/products/r1/se-r1.html
A sme zasa na zaciatku. |
ivanb_cko Hifista
Založený: 08 júl 2010 Príspevky: 119
Zaslal: St jún 14, 2017 12:30:11 Predmet: |
po téměř 2 letech jsem se vrátil k tomuto tématu a zjistil, že rozumné odpovědi jsem se tenkrát a ani teď pořádně nedočkal!!? Debata se zvrhla do žvanění o tom, že většina nemá ráda zesilovače "D" třídy nebo v hádky o slovíčkaření či technických (ne)znalostech a další a další nic neříkající... Každopádně o značce a jejich výrobcích nic! Mimochodem dělají i zesilovače v AB třídě, ale to tak nějak zapadlo. Škoda, trochu jsem to čekal.
Tak já jeden ten integráč vyzkouším a uvidím co a jak sám... _________________ Luxman DA-06 & Audirvana Plus /Denon DN-961FA /Luxman PD-444 w Nottingham Analogue Ace Space & VDH MC-10 + Dynavector DV-505 arm & DV-507 mkII shell & Kiseki Milltek Aurora /PJ Phono Box RS /Jeff Rowland Concentra I /[audio physic] Scorpio |
