Založený: 21 november 2007 Príspevky: 12812
Zaslal: Ut august 11, 2020 08:09:15 Predmet: |
citácia: | ... If one looks at each and every sample in a signal, then one can compile the statistics of this signal. The most obvious is the mean, or really the DC term. This will virtually always be zero, or nearly zero, since the audio system cannot propagate DC. The next is the Standard Deviation (SD) which tells use what the signals level is (the RMS) - loud or soft, etc. But there are many higher order moments in statistics. The third moment is the skew, which tells us if there are more or less positive points than negative ones. The fourth moment is the kurtosis, which tells us how "peaked" the signal is, i.e. how points tend to lie beyond the norms implied by the SD (i.e. a Gaussian distribution, which has no moments higher than SD.)
Consider a signal with a high skew going through a system with clipping on one side and not on the other. If this signal is one way then the THD will be higher, if it is the other way then the THD will be lower. The skew, in this case, shows use that different signal skews and system nonlinearities affect the signals very differently.
I noted this when after a discussion with Sean Olive he mentioned that they found the works of Tracy Chapman the most revealing of poor sound quality. When I looked at the stats of her songs they had extremely high values of skew - far higher than any other artists. |
Zdroj: https://www.diyaudio.com/forums/multi-way/338806-acoustic-horn-design-easy-ath4-post6256242.html _________________ www.at-horns.eu | "ATH - the best waveguide designs possible" - Earl Geddes |
bvgsxduij112 Ready2Die
Zaslal: So september 02, 2023 09:12:47 Predmet: |
iPad nehraje basy a ani nahlas. A pochybujem, ze iPad zahraje potichu Fast Car rovnako dobre ako ine bedny co mas…
Mozes mu zmerat frekvencnu charakteristiku. Mozno to maju naozaj dobre naladene :) |
Zaslal: So september 02, 2023 10:24:07 Predmet: |
miero napísal: | iPad nehraje basy a ani nahlas. A pochybujem, ze iPad zahraje potichu Fast Car rovnako dobre ako ine bedny co mas…
Mozes mu zmerat frekvencnu charakteristiku. Mozno to maju naozaj dobre naladene |
Ale o tom vůbec nemluvím
Mluvím o tom, že klasická hudba (větší orchestr) s velkou dynamikou se z iPadu (z jeho repro) ani z maličkých beden nedá poslouchat. Kdežto u té Tracy Chapman Fast Car je to tak nějak jaksi jedno, pořád je to stejné líbivé nic. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: So september 02, 2023 13:10:37 Predmet: |
Neviem ci si cital ten clanok, ciel s tym Fast Car nie je pocuvat, ale popisat charakteristiku reprodukovaneho zvuku. Niecim intm nez ruzovym sumom. |
Zaslal: Ut september 12, 2023 12:04:08 Predmet: |
Plati, ze ak zostava vie kvalitne reprodukovat (fast car alebo ruzovy sum...) potichu a zaroven i nahlas, tak zvladne kvalitne reprodukovat i nahravku s velkou dynamikou?
Resp. este inak, koreluje to s tym co meria Erin v "Dynamic Range (Instantaneous Compression Test)" resp. v "Long Term Compression Tests", k videniu napriklad tuto:
- https://www.erinsaudiocorner.com/loudspeakers/jbl_m2/ |
