Skipy stepná kengura
Zaslal: So september 13, 2008 21:59:12 Predmet: |
Vlado
skús sa skontaktovať s PetrKp (lopuch.cz) |
Založený: 18 január 2007 Príspevky: 20504
Zaslal: So september 13, 2008 22:00:28 Predmet: |
Citace:
As right as the JP80 was for acoustic music is as wrong as it was for rock. It didn't rock, sounding sluggish with rock music. Transients were softened, the top octave smoothed-over, and the lower midbass somewhat distended, seemingly in another dimension (but the transition from upper midbass to midrange was seamless). Deep-bass fundamentals were there, but they put on an overly grandiose performance.
Clearly the JP80 was slightly dark on top, a darkness that affected tonality and, to a greater degree, the resolution of air and space. With classical music it never seemed to be a problem—I never felt that brass was softened or robbed of its fundamental metallic edge. But if you like a speedy, crystalline percussive sparkle to snare drums and tubular bells, or if you like hearing reverberant trails ricocheting and crackling off of hall walls, you might not be satisfied. |
Vlado Nádejný hifista
Založený: 04 júl 2008 Príspevky: 66
Zaslal: So september 13, 2008 22:04:10 Predmet: |
[quote="Skipy"]Vlado
skús sa skontaktovať s PetrKp (lopuch.cz)[/quote]
Ďakujem za typ!!! |
Zaslal: So september 13, 2008 22:10:09 Predmet: |
PMA: Ja som tu recenziu pozeral už dávno, ale potom si recenzujúci protirečí, alebo tie chyby o ktorých píše boli zanedbateľné, ale musel ich napísať kvôli cenovej kategórie ... lebo na konci píše zasa chvály. |
Zaslal: So september 13, 2008 22:15:04 Predmet: |
Tyto recenze je často nutné číst "mezi řádky", toto ani ukryté nebylo, samozřejmě na konci přístroj pochválil, to ani jinak není možné. |
Zaslal: So september 13, 2008 22:21:19 Predmet: |
Stále je to len článok v časopise, aj keď ako som už písal Stereo... má dobrý kredit. Musím to zohnať na doma, asi zájdem do Rakúska ...
Keď mám povedať pravdu - o predzosilňovači som uvažoval od CJ - premier 17 alebo 16 /ART je drahý a podľa vyjadrenia výrobcu ... 17-ka je 95% ART-u za 60% ceny/ + Monobloky Jadis / JA 100, 200/ - len to nie je možnosť niekde v Česko - Slovensku zapožičať na skúšku, ako by bola na tom táto kombinácia |
