ARTA
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Koutek Velkého Boba
velky bobo
Big Audio Druid
Založený: 04 február 2007
PríspevokZaslal: St december 09, 2009 01:32:40    Predmet: ARTA Odpovedať s citátom
Pokud to někoho zajímá a ještě o tom neví neví, je nová verze ARTA - v1.6.0
http://www.kvakeri.cz/
godz
Založený: 05 máj 2007
PríspevokZaslal: St december 09, 2009 09:21:49    Predmet: Odpovedať s citátom
Vďaka za info. Mateljan rozdával mikulášske darčeky. Cez víkend skúšam.
PríspevokZaslal: St december 09, 2009 11:14:57    Predmet: Odpovedať s citátom
Dík za info, je tam něco nového, co by stálo za upgrade?
velky bobo
Big Audio Druid
PríspevokZaslal: St december 09, 2009 11:20:02    Predmet: Odpovedať s citátom
Nevím, nestudoval jsem to. Ale asi to bude ppsané na webu autora.
godz
PríspevokZaslal: St december 09, 2009 12:56:30    Predmet: Odpovedať s citátom
New features, implemented in program ARTA, are:
- Signal recorder now function as storage scope with triggering capabilities on both channels, with predelay and postdelay.
- For recorded signal the gated spectrum analysis and Short-Time Fourier waterfall plot are possible.
- Import from wav and ascii files can be analysed as IR or signal time record.
- A contour plot added for the presentation of directivity patterns.
- In reveberation window, the 95% cut of tail enabled.
- In all time windows 8 x zoom enabled, with zoom report on graphs.
- A button is added to Imp window control bar, for setting cursor on position of max amplitude.
- New tool: Two-channel voltage level meter and 1/3 oct. analyser.
- Enhanced FR target filter generation.
- Difference mode - in Fr1, Fr2, Spa - shows difference of Magnitude and overlay levels.
Following bugs are removed:
- Arta 'Load target' command - accept files with arbitrary number of points (removed hidden restriction on 720 points)
- Arta peak meter in SPL windows is tracking the peak in every recorded blocks
- Limp correctly reports Le.
- Steps correctly reports X-axis values in Distortion vs. excitation plot.
L.V.
Založený: 14 september 2007
PríspevokZaslal: Po február 22, 2010 18:40:14    Predmet: Odpovedať s citátom
Potreboval by som radu. Meriam cez loopback zvukovku M-Audio Audiophile 2496. Pokiaľ viem, pri meraní THD by mali byť lepšie výsledky pri nastavení vyššej samplovacj frekvencie. Samozrejme za tej podmienky, že sú parametre správne nastavené /rovnako/ v Control paneli zvukovky a v nastavení Arty.
Prečo mi potom vychádza spektrum "čistejšie" pri 24/48 ako pri 24/96 ? Používam OS Vista 64. Dík za radu.
Tu je meranie pri 24/48:
Tam, kde leží Little Big Horn ...
L.V.
PríspevokZaslal: Po február 22, 2010 18:40:42    Predmet: Odpovedať s citátom
24/96:
PríspevokZaslal: Po február 22, 2010 19:26:57    Predmet: Odpovedať s citátom
January 3, 2009.
ARTA version 1.6.1 is published (see download section).
- Saves background color in registry.
- IR measurement dialog gets check box 'Close after recording' to close itself after recording.
- Alt-R-R-R starts and closes measurement in PIR window.
- Alt-R-R starts and closes measurement of PIR in FR window.
- Envelope and Step response windows remember the zoom ratio.
- Shorcut keys for Cursor movement: Home (to 300 sample) , Del (to 0 sample).
- Shorcut keys for Cursor movement are: Crtl+Home (to 300) , Ctrl+Del (to 0), Ctrl+Ins (to cursor).
- Signal recorder can do a triggered time averaging.
- Spectrum estimation of gated recorded signal now gives an averaged spectrum of ovelapped segments.
Foollowing bugs are removed:
- Contour plot appears after reopening the directivity window.
- In correlation graph the background color now trace the global backgound color.
- Spectrum overlay does not depend on type of window (if made in PSD mode must be used in that mode).
5er
Založený: 19 február 2008
PríspevokZaslal: Ut december 21, 2010 18:13:28    Predmet: Odpovedať s citátom
Pokiaľ to neviete, je vonku ARTA version 1.7.0.
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Koutek Velkého Boba Časy uvádzané v GMT + 1 hodina
