moses Hifi expert
Založený: 17 november 2012 Príspevky: 1907
Zaslal: Pi december 16, 2016 21:46:10 Predmet: NO TOTO! |
http://tech.sme.sk/c/20411702/pocuvate-hudbu-v-mp3-budete-menej-stastni.html
Nepocuvaju tu poniektori iba komprimovanu hudbu??? _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
moses Hifi expert
Zaslal: Pi december 16, 2016 21:48:20 Predmet: |
Tu este pridavam cele dielo:
http://www.aes.org/tmpFiles/elib/20161216/18523.pdf _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
bacil2 Hifi expert
Zaslal: So december 17, 2016 04:51:50 Predmet: |
hej, ale odpoved na zasadnu otazku si sem nedal:
citácia: | Compressed sounds were encoded and decoded using the LAME MP3 encoder [49]. Instrument sounds were compressed with three different bit rates. As a preliminary step, we listened to the sounds compressed at different bit rates and judged that 112 Kbps sounds were the lowest bit rate that sounded nearly indistinguishable from the original sounds. Sounds at 32 Kbps had obvious artifacts. We selected 56 Kbps as an intermediate bit rate, representing medium quality between indistinguishable and obvious artifacts (i.e., some artifacts). Though theseparticular bit rates may not be as common in practice, they are representative of the basic levels of compression. These three bit rates also gavenear-perfect (for32Kbps),intermediate(for56Kbps), and near-random (for 112 Kbps) discrimination results in a previous discrimination study of these MP3-compressed musical instrument sounds [40], meaning listeners in that study could nearly always notice a difference between the original sound and a 32 Kbps compression, sometime notice a difference for 56 Kbps, and were unable to reliably notice a difference for 112 Kbps. |
Vyskum jak repa... |
moses Hifi expert
Zaslal: So december 17, 2016 07:26:54 Predmet: |
Inak pre vacsiu objektivnost mohli pouzit aj ine bitrate-y a enkodery... _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
RedBaron Hifista - pokročilec
Zaslal: So december 17, 2016 10:20:25 Predmet: |
U čehokoli pod 192kbps zní výšky jako šustění papírem od sekaný, ale pravdou je, že rozdíl mezi kvalitní 320kbps a flacem už jsou jen nuance v nejnáročnějších pasážích. Pokud je kvalitní nahrávka, 320kbps MP3 rozhodně neodrazuje od vychutnání hudby, alespoň já to tak mám. _________________ Doma: Synology DS920+ > NUC8i5Beh+Akasa+Foobar2000+REW > SPaudio D1 > P1 > A400 > JBL 250Ti Jubilee |
Zaslal: So december 17, 2016 11:06:09 Predmet: |
Souhlasím, mám to stejně.
Pořád platí, že alfou a omegou je kvalitní původní záznam a mastering. Umím si celkem bez uzardění představit, že dobře udělaná mp3 320 kbps vytvořená ze špičkové nahrávky zní zásadně líp než CD s průměrnou či mizernou nahrávkou. |
tatko Tom Hifi expert
Založený: 21 február 2016 Príspevky: 2995 Bydlisko: Prievidza
Zaslal: So december 17, 2016 11:38:50 Predmet: |
192kbps wma(2) tiež v pohode, myslím. _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
moses Hifi expert
Zaslal: So december 17, 2016 11:45:31 Predmet: |
Ja pouzivam v mobile 320kbs LAME robene z CD cez dBpoweramp a je to uplna pohoda. Von aj tak netreba nic lepsie . _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
