Zaslal: Ut december 24, 2013 09:12:34 Predmet: Reprosústava budená prúdom |
Nemám znalosti posúdiť, či nasledujúci článok nekecá, ale zaujímalo by ma kolko pravdy je na tvrdení, že reprosústava navrhnutá na zosilňovač s prúdovým výstupom hraje lepšie.
Príklad takéhoto výrobku z poslednej doby sú monitory Grimm Audio LS1.
citácia: | The most remarkable thing here regarding loudspeakers is that the voltage between the ends of the wire does not appear anywhere in these equations. That is, the speaker driver in the end obeys only current, not caring what the voltage across the terminals happens to be.
There cannot be found any scientifically valid reasons that justify the adoption of voltage as the control quantity - it is only due to the historical legacy originated almost a century ago, most likely by cheapness and simplicity; the quality and physical soundness of operation have not been considerations in this choice. Engineers are also more accustomed to identifying electrical signals as voltages rather than currents. |
Zdroj: Loudspeaker operation: The superiority of current drive over voltage drive
http://www.edn.com/Home/PrintView?contentItemId=4423155
Naposledy upravil miero dňa Ut december 24, 2013 10:11:19, celkom upravené 1 krát. |
Zaslal: Ut december 24, 2013 09:39:01 Predmet: |
To je odborný článek od výrobce, nebo nezávislá publikace? _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: Ut december 24, 2013 10:24:46 Predmet: |
V podstate vyrobca...
citácia: | Esa Meriläinen received the M.Sc. degree in electrical engineering from Tampere University of Technology, Finland, in 1990, specializing in applied electronics and measurement technology. He has, as a devoted hobby, researched and experimented with current-drive of loudspeakers for a long time. He has authored a book on the subject and holds the rights for three pertinent inventions. He maintains a website at www.current-drive.info |
Zdroj: http://www.edn.com/user/Esa%20Merilainen |
velky bobo Big Audio Druid
Zaslal: Ne január 26, 2014 21:21:10 Predmet: |
Je to pravda, nezávisle ověřená měřením. V podstatě jde o to, že pohyb kmitačky je určen silou, která je daná mimo jiné proudem. Napětí do toho vstupuje pouze zprostředkovaně. Nevýhoda je, že frekvenční charakteristika je při proudovém buzení dosti divoká a musí se elektricky korigovat. Výhoda je menší nelineární zkreslení. _________________ Nemám nic proti hifi, vadí mi jen hifisti. Ale technokraty taky zrovna nemiluju.
http://www.kvakeri.cz/ |
