bogino Hifista - pokročilec
Zaslal: Ne máj 18, 2014 10:22:59 Predmet: |
2) Rein Audio X3 DAC vs. Valab DAC X9 = Gustard DAC X9
Valab DAC X9 = Gustard DAC X9 za $400
Rein Audio X3 DAC v cenach $1000 az $1700
Gustard DAC X9 zvnutra
Rein Audio X3 DAC zvnutra
Zmienka o tom, ze cinsky a nemecky produkt su vlastne to iste:
http://www.stereo.net.au/forums/index.php?/topic/40936-valab-dac-x-dual-wm8741-24bit-192k-dac-balanced-xlr-output/
http://www.head-fi.org/t/658236/rein-audio-x3-dac-review/15#post_9453847
I do know that the "first generation" DAC-X9 has been on sale on Taobao since early 2012 (see this link dated March 2012 referring to the DAC-X9); that version had only a Tenor TE7022 receiver chip, so it was only capable of 24/96 over USB. Here, in May 2012, someone on Computer Audiophile reviews it: http://www.computeraudiophile.com/f6-dac-digital-analog-conversion/valab-dac-x-dual-wm8741-11939/
Prva zmienka o Rein Audio DAC X3 sa na facebooku Rein Audio nachadza z januara 2013. Vo februari ohlasuju prvu moznost DAC kupit https://www.facebook.com/ReinAudio/posts/481150355276700 a v marci sa zjavila prva recenzia na avrev:
http://www.avrev.com/home-theater-preamplifiers/stereo-preamps/rein-audio-x3-dac-review.html
Zaujimavy nazor od Project86 z head-fi:
http://www.head-fi.org/t/658236/rein-audio-x3-dac-review/30#post_9598746
I've never talked to the folks at Rein Audio but from what I can tell, the eBay model was around long before the X-3 was ever announced. My friend picked it up early last year. At that time Rein had barely released their original X-DAC (which I found very underwhelming). So I highly doubt they had the X-3 completed by then.
It looks to me like this is a case of OEM rebadging, complete with massive price increase. I've seen this before when Decware took the Gigawork DAC found on eBay for a few hundred dollars, renamed it the ZDAC, and sold it for $875 (and implied it was worth far more than that). When people called them on it, they gave all sorts of excuses and questionable explanations, then eventually listed their ZDAC as "sold out" and waited for the whole thing to blow over.
I suspect this situation is the same, based on the dates of release. Could be wrong but I doubt it. _________________ Moje testy: http://headaudio.weebly.com |
DanoP Hifi obsluha
Založený: 03 február 2015 Príspevky: 23 Bydlisko: Trnava
Zaslal: So február 28, 2015 20:27:31 Predmet: Gustard X12 |
Momentalne sa hram s DACom Gustard X12. Prekvapilo ma ze CD pustene cez notebook a USB cez tento DAC v DSD128 hra uplne inak - nejak prijemnejsie, na rozdiel ak pouzijem S-PDIF-koax z CD prehravaca (Sony XB820). Zeby jitter ? Inak origo subory v DSD 64 alebo DSD 128 su uplene ina kava.  |
DanoP Hifi obsluha
Zaslal: Ut marec 10, 2015 09:29:31 Predmet: |
Vdaka za odkaz. Netusil som, ze moze byt aj rozdiel medzi prehravacmi. Zdalo sa mi ze JRiver hra tak nejak dsrnejsie oproti Foobar, ale myslel som si ze si to nahovaram, teraz vsak vidim, ze to postrehli aj ini. Inak pouzivam XMOS ST ASIO verziu 2.23 (bola na CD k Gustardovi). Skusal som najst LT verziu, ale bez uspechu.  |
Zaslal: Ut marec 10, 2015 19:42:40 Predmet: |
Pouzivam verziu 2.19, ktoru som odvodil z Luckit WaveIO drivera a zmenil prislusne konfiguracne subory tak, aby poznal Gustarda. Tym padom mam k dizpozicii ten rozsirenejsi Control Panel + aj TUSBAudio Spy Tool na detailnejsi nahlad na stav aktualnej komunikacie a nejake statistiky.
Ak mas o nu zaujem, niekam ti ju upnem. _________________ Moje testy: http://headaudio.weebly.com |
Henri Hifista - zaslúžilec
Zaslal: Po marec 30, 2015 17:52:13 Predmet: konverzia z PCM do DSD |
x
Naposledy upravil Henri dňa St jún 17, 2015 18:04:19, celkom upravené 1 krát. |
Zaslal: Po marec 30, 2015 20:34:25 Predmet: |
Po rusky viem citat, tak som si ten odkaz pozrel. Podla mojho celkom laickeho pochopenia to vyzera najskor na analogovy stupen (analogovy rekonstrukcny filter) za prevodnikom. Ale na mna laika je to moc silne tvrdenie.
Modely DAC-X10 a DAC-X12 sa lisia prave v tomto analogovom stupni. Tie merania sa tykaju DAC-X12. Bolo by zaujimave vidiet podobne merania aj pre DAC-X10 a ine DAC. Prip. aj pre iny kus DAC-X12. Prip. aj s roznymi nastaveniami digitalneho filtra v DAC chipe (50, 60, 70 kHz). A tiez by bolo zaujimave posluchove porovnanie. _________________ Moje testy: http://headaudio.weebly.com |
Zaslal: Po marec 30, 2015 22:18:13 Predmet: |
x
Naposledy upravil Henri dňa St jún 17, 2015 18:04:43, celkom upravené 1 krát. |
Zaslal: Po marec 30, 2015 22:53:44 Predmet: |
Co som cital, analogovy stupen je hlavnym dovodom, preco rozne DACy so tym istym Sabre chipom nezneju rovnako. _________________ Moje testy: http://headaudio.weebly.com |
Zaslal: Ut marec 31, 2015 05:54:36 Predmet: |
| Cinan da na skatulku nalepku s pismenami DSD, napise sa par siahodlhych ooood na head-fi a highend za hubicku je na svete. Podla poucky - cim blbsie, tym sa to viac paci. |
Zaslal: Ut marec 31, 2015 06:45:19 Predmet: |
To boli slova hodne krcmovej urovne hifi.slovanetu. _________________ Moje testy: http://headaudio.weebly.com |
Zaslal: Ut marec 31, 2015 07:17:14 Predmet: |
Ked ti vadi uroven tohto fora, nik ta nenuti sem chodit, nebodaj prispievat  |
Zaslal: Ut marec 31, 2015 07:45:59 Predmet: |
| Stále mě udivuje jak se lidi nechají snadno zblbnout. Ačkoliv většina dac používá čipy jež jsou dobře zdokumentované a v doporučeném osázení podávají slušné výsledky, tak velká část výrobců nedovede bezchybně použit ani to výrobcem doporučené osazení. Výsledky potom hovoří samy za sebe. Bohužel, stačí se chytit nějaké módní vlny a odpad se prodává sám. Jakmile to nemá samolepku USB tak je to neprodejné, je-li to opravdový odpad tak přidáme ještě DSD a lidé nám i ruce utrhají. Ale je to tak levné, no nákup to! |
Slimak Hifi expert
Zaslal: Ut marec 31, 2015 08:01:32 Predmet: |
| ZdeNek II napísal: | | Ačkoliv většina dac používá čipy jež jsou dobře zdokumentované a v doporučeném osázení podávají slušné výsledky, tak velká část výrobců nedovede bezchybně použit ani to výrobcem doporučené osazení. Výsledky potom hovoří samy za sebe. |
Áno. Hoci nepovedal by som, že "nedovede", robia to kvôli nákladom. Značky a typy DACov so Sabre, ktoré sa tu preberajú majú rovnako naimplementovaný Sabre chip, teda rovnako špatne. Veď načo niečo riadne zapojiť, keď stačí použiť ani nie pár eurový modul so Sabre vyrobený v číne. A to sa osadí do rôznych (teda skoro do všetkých tuná spomínaných) DACov. Šetrí to náklady. |
Zaslal: Ut marec 31, 2015 10:12:40 Predmet: |
x
Naposledy upravil Henri dňa St jún 17, 2015 18:05:31, celkom upravené 1 krát. |
Zaslal: Ut marec 31, 2015 10:30:05 Predmet: |
| oh :( |
Slimak Hifi expert
Zaslal: Ut marec 31, 2015 11:07:03 Predmet: |
| Gustard pri rozsiahlejšom tuningu, t.j. vyhodiť celý DAC a urobiť niečo úplne iné bude naozaj dobrý DAC. |
šeďour Hifista - zaslúžilec
Zaslal: Ut marec 31, 2015 11:40:31 Predmet: |
| Přístrojovou skříňku nevyhazuj...ta je dobrá ! |
Zaslal: Ut marec 31, 2015 14:14:30 Predmet: |
| Henri napísal: | Lenže aj Matrix X-Sabre s ES9018 Sabre je „Číňan“ a je v pohode, tieto nedostatky nemá.
Takže pre potenciálnych záujemcov o kúpu si dovolím zosumarizovať DAC Gusterd
Klady
-Cena
-Pre niekoho prijemný a kludny zvuk
-Široké pole vstupov (aj I2S ) a výstupov (XLR)
-ES 9018 Sabre
-novy „audio“ USB XMOS
Po rozsiahlejšom tuningu t.j. zmene výstupných filtrov ,nahradení tantalov, použití slušnejších stabilizátorov v napájaní, prerobení napájania XMOS atd... Gustard hra celkom slušne
Zápory
-Zmršené výstupné obvody
-Tantalove SMD kondenzátory v signálovej ceste
-Pri konverzii na DSD dochádza ku prehodeniu stereo kanálov, ak použijeme bežne ASIO alebo WASAPI, stereo je správne
-SNR s ES9018! : cca 96 dB (Matrix X-Sabre 124dB)
-galvanická izolácia nie je riešená čipovo priamo v DAC pred I2S zbernicou
-V porovnaní s USB transportom U 12, pre samplovacie frekvencie 45.1584 MHz aj 49.152 MHz používa len jeden oscillator (transportom U 12 dva) |
To je tvoj nazor na DAC-X12, ktory vlastnis a nemam ziaden dovod ti ho brat ...
Ku DAC-X10 pridavam:
- DAC-X10 ma iny analogovy stupen, nez DAC-X12
- Pri konverzii do DSD nedochádza ku prehodeniu stereo kanálov
- Merania su k dispozicii od vyrobcu a z jedneho ruskeho fora, davam obrazky resp. linky na ne.
Vyrobca:
Z ruskeho fora http://forum.vegalab.ru/showthread.php?t=65717&s=b822ec869d2f3fa5b1a74228bb578386&p=1865928&viewfull=1#post1865928
http://forum.vegalab.ru/attachment.php?attachmentid=202607&d=1386096668
http://forum.vegalab.ru/attachment.php?attachmentid=202606&d=1386096682
Komentar autora merani:
Не сказать, что результаты выдающиеся, но для девайса за 450 у.е. вполне прилично. Учитывая, что имеется полный набор цифровых входов и аналоговых выходов, а также поддержка DSD - найти конкурента за такую цену будет сложно.
Neda sa povedat, ze vysledky merani su vynikajuce, ale na zariadenie za 450 EUR celkom slusne. Zahrnajuc vsetky typy digitalnych vstupov a analogovych vystupov a tiez podpora DSD - najst konkurenta za taku cenu bude zlozite.
Ja vlastnim DAC-X10. Porovnaval som ho s Yulong Sabre DA8, Oppo HA-1 aj Denon DA-300USB. Mne z toho nevyslo, zeby DAC-X10 vyzadoval rozsiahlejsi tuning. Vnimam ich zvukovo ako DACy tej istej triedy, nehodnotim teraz uroven sluch. zos. v niektorych z nich. Poznam cloveka, co Arcam rDac vymenil za DAC-X10, pretoze DAC-X10 znamena vyrazne zlepsenie. Porovnavali sme to spolu. Voci tomu, co som vlastnil predtym (hiFace2 + HK HD 970) hra DAC-X10 tiez o triedu lepsie.
Niektori nasli v tejto teme lacnu prilezitost ukajat sa na meraniach jedneho kusu DAC-X12. Stavaju sa z nich razom krcmovi odbornici na merania, analogove rekonstrukcne filtre a na vsetky modely Gustard. Ze nemaju so ziadnym tu spominanym zariadenim konkretnu skusenost, im zjavne nevadi. Proste krcmove forum, na ktore zrejme nema zmysel davat seriozne myslene prispevky. Odar ma pravdu, zbytocne je pre mna brat toto forum vazne. _________________ Moje testy: http://headaudio.weebly.com |
Zaslal: Ut marec 31, 2015 15:32:19 Predmet: |
Smutne je, ze pointa ti usla. Ale hned rano si nevahal so zalepenymi ocami zhodnotit moj psychologicky profil a stanovit moju diagnozu (a netvar sa, ze o nicom nevies, v RSS to stale mam). Male bezvyznamne plus mas za to, ze si tu diagnozu neskor prehodnotil
Netreba to tak prezivat. Nejde o zivot, iba o nalestene skatule To, ci pokecas lepsie s ruskymi kamosmi pri flasi mineralky, alebo na krcmovom fore - to si musis zvazit sam  |
Zaslal: Ut marec 31, 2015 15:59:11 Predmet: |
| Já si naopak myslím že to smutné není ale poučné. V tomto vlákně máme ukázku "úžasných výrobků" i ukázku jejich neméně "úžasných" majitelů (jednoho majitele). |
Slimak Hifi expert
Zaslal: Ut marec 31, 2015 16:37:51 Predmet: |
Pokial niekto tvrdi ze Yulong a spominane Dacy su tej istej triedy, tak spominany Yulong bol u mna na posluch asi 4x, bol aj na zraze v Hradisti. Konkretne u Yulongu je jeden fatalny problem, meniaca sa kvalita zvuku v case. Je to velmi dobre pocutelne. Problem sposobuje zla implementacia dac chipu. Dochadza tam ku zvyseniu skreslenia o jeden rad pri istych prilezitostiach. Riesi sa to aj na forach, chlapci zo Sabre zatial stiahli chvost. Tak ako ma implementovany chip Yulong, tak ho maju aj vsetky Dacy tejto kategorie. Zbytocne vyhodenych 1000 eur. Zial je to tak, ci uz si niekto mysli, ze su to krcmove reci alebo nie.
Naposledy upravil Slimak dňa Ut marec 31, 2015 19:22:51, celkom upravené 1 krát. |
Zaslal: Ut marec 31, 2015 18:53:47 Predmet: |
Slimak, obavam sa, ze sa tvoje uvazovanie nepohybuje v cenovej relacii 450 EUR, za ktore DAC-X10 mam. Hodnotit nejaky vyrobok je treba v jeho cenovej relacii. Mozes mi ponuknut zoznam niekolkych DACov do 450, ktore su podla tvojho nazoru lepsie?
Inak Yulong, nie Youlong. _________________ Moje testy: http://headaudio.weebly.com |
Slimak Hifi expert
Zaslal: Ut marec 31, 2015 19:21:46 Predmet: |
Písal som o probléme Sabre chipu, ak je implementovaný tak, ako v DACoch spomínaných v tomto vlákne. Je jedno, či je to kategória 500 alebo 1000 EUR, implementácia je žiaľ rovnako "blbá".
Mistra "Youlonga" som v predch. príspevku opravil
Ešte snáď na záver - Sabre je momentálne moderná záležitosť. Osobne som dal prednosť inému, starému a overenému AD1955. Výsledky sú určite lepšie než všetky tuná spomínané DACy s ESS Sabre. Ale je to aj iná cenová kategória, ak sa to má zapojiť dobre a nekompromisne, tak len súčiastky stoja "majland". |
Zaslal: Ut marec 31, 2015 19:28:54 Predmet: |
Naposledy upravil Henri dňa St jún 17, 2015 18:07:32, celkom upravené 1 krát. |
Zaslal: Ut marec 31, 2015 19:52:05 Predmet: |
OK, vselico ste Henri a Slimak napisali, ale nedali ste mi odpoved - par lepsich DACov do 450 EUR. Aby sme boli v jednej kategorii s DAC-X10, ostanme pri USB DACoch. _________________ Moje testy: http://headaudio.weebly.com |
Slimak Hifi expert
Zaslal: Ut marec 31, 2015 20:18:08 Predmet: |
Neviem dať odpoveď. Moje kritériá na DAC žiaľ nesplňuje nič komerčné do 450 EUR.
Moje príspevky ani nemali účel niečo porovnávať lepšie/horšie. |
