Otravny vodoznak v streamovanej hudbe (posluchovy test)
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Resampling, upsampling, komprimacia zvuku
PríspevokZaslal: Po marec 06, 2017 11:35:54    Predmet: Otravny vodoznak v streamovanej hudbe (posluchovy test) Odpovedať s citátom
http://mattmontag.com/audio-listening-test/
Digital audio watermarks hide extra information in an audio signal, usually for copyright enforcement purposes. The watermarks are designed to be inaudible, but necessarily add some distortion to the original audio.
Naposledy upravil miero dňa Št september 13, 2018 07:57:53, celkom upravené 1 krát.
PríspevokZaslal: St marec 08, 2017 09:33:34    Predmet: Odpovedať s citátom
este clanok k tomuto a vysledky testu v odkaze hore
http://www.mattmontag.com/music/universals-audible-watermark
http://www.mattmontag.com/music/listening-test-results
A while ago, I wrote about my confusion regarding Weird Spotify Compression Artifacts. It turns out the artifacts I was hearing are not due to compression, but a result of audio watermarks that Universal Music Group embeds in digitally distributed tracks. This watermark is embedded in UMG tracks on Rdio, Spotify, iTunes, Tidal, and others. The watermark can also be heard in Universal tracks broadcast over FM radio. Universal Music recordings make up about 25% of most online catalogs, and its labels include Interscope, The Island Def Jam, Universal Republic, Verve, GRP, Impulse!, Decca, Deutsche Grammophon, Geffen, etc.
PríspevokZaslal: St september 12, 2018 12:52:01    Predmet: Odpovedať s citátom
Additionally, I think there is a Tidal playlist of 4 selections called UMG watermark:
https://listen.tidal.com/playlist/a26b6652-6eb4-4519-bb7c-ca395da27e0e
and a spotify one:
https://open.spotify.com/user/ivionday/playlist/3ZbRKMGb8nqXqZziwtC5ZY
Zdroj: https://community.roonlabs.com/t/umg-watermark-true-or-false/21435/7
PríspevokZaslal: Št september 13, 2018 07:35:05    Predmet: Odpovedať s citátom
Kto vodoznak zo streamingu nepocuje, tak zrejme ani moc poriadne nepocuva... (alebo ma stastie na hudbu bez vodoznaku)
Red Sea - The Prince Of Egypt/Soundrack Version
https://open.spotify.com/track/58uem87EElJobfMa1jR20B
(15 sekundove ukazky)
http://mr.ieero.com/pub/audio-watermark/
Na Tidale zda sa tento album vobec nie je.
Naposledy upravil miero dňa Št september 13, 2018 12:28:16, celkom upravené 2 krát.
JHradec
Založený: 29 január 2007
PríspevokZaslal: Št september 13, 2018 08:35:17    Predmet: Odpovedať s citátom
nedělal jsem ABX, ale je to slyšet v té tišší části cca 3 s od začátku. na sluchátka z notebooku. V hlasitějším závěru jsem neregistroval nic. Pokud nebudu poslouchat soustředěně, klidně bych s tím dokázal žít.
PríspevokZaslal: Št september 13, 2018 09:37:41    Predmet: Odpovedať s citátom
Pridal som este nahravku Spotify normal kvality a original komprimovany do MP3 128kbps, MP3 V0, Vorbis q5 a Vorbis q9.
Kto si to stiahne, prezrie a vypocuje zrejme nieco veelmi zaujimave odhali...
Necham to tu par dni bez komentara.
Lukaso
Založený: 15 január 2009
PríspevokZaslal: St september 19, 2018 19:07:39    Predmet: Odpovedať s citátom
Miero, díky, že jsi téma watermarkingu znovu vytáhnul a zveřejnil i soubory. Je to praktika, která mi opravdu na streamované hudbě vadí. Na souborech v ABX testu rozdíl slyším. S albama postiženýma vodoznakem jsem se setkal i u Tidalu (např. Hiromi - Voice). Nepříjemné je, že není předvídatelné, u kterých alb je vodoznak slyšet.
Ten rozdíl mezi Spotify normal a high je překvapivý. Doufám, že to je jen náhoda.
PríspevokZaslal: St september 19, 2018 19:46:47    Predmet: Odpovedať s citátom
Diky za reakciu!
Podla analyzy spektra rozdieloveho signalu mi pride, ze spotify-normal je (v tomto pripade) vorbis kodovany s parametrom q9 (320kbps).
Verzia spotify-high je divna, lebo sa mi nepodarilo najst parametre pre oggenc, ktore by dali podobne rozdielove spektrum (skusal som q10, 320, 320 managed). Takze odhadujem, ze v tom signale je okrem jasneho vodoznaku medzi 1-5kHz este nejaky dalsi (zrejme nepocutelny) vodoznak v celom spektre.
Chcelo by to zanalyzovat este dalsie tracky...
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Resampling, upsampling, komprimacia zvuku Časy uvádzané v GMT + 1 hodina
