O čom sa píše inde a stojí to za zmienku
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Hi-Fi čitáreň
PríspevokZaslal: So február 03, 2018 14:49:44    Predmet: Odpovedať s citátom
Multi-Driver Balanced Armature Earphones & IEMs - AES@NAMM 2018 (29 mins)
https://vimeo.com/253957119
PríspevokZaslal: Ut február 20, 2018 08:58:50    Predmet: Odpovedať s citátom
When Your Eyes Move, So Do Your Eardrums
https://www.theatlantic.com/science/archive/2018/01/when-your-eyes-move-so-do-your-eardrums/551237/
They also found that the eardrums start to wobble about 10 milliseconds before the eyes. This suggest that the ears aren’t reacting to what’s happening in the eyes. Instead, Groh says, “the brain is saying: I am about to move the eyes; ears, get ready.”
PríspevokZaslal: Št február 22, 2018 12:54:33    Predmet: Odpovedať s citátom
http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
The Musical Audio Frequency Spectrum (Item #: FCP-MX)
The full frequency ranges generated by 28 different instruments grouped into 5 instrument categories.
A frequency-aligned overlay of an extended-range piano keyboard, with the note and octave for each key labeled.
The frequency domains for sonic characteristics such as “rumble”, “warmth”, “sibilance”, etc.
Location of the 31-bands in a standard ISO-defined 1/3rd-octave graphic equalizer.
A color-coded breakdown of the full audio frequency spectrum into 5 ranges from sub-bass to the high-frequencies.
Color-coded “data boxes” for each frequency range containing specific ranges and characteristics.
N.A.
PríspevokZaslal: So marec 10, 2018 13:12:03    Predmet: DNA Odpovedať s citátom
http://www.rozhlas.cz/plus/svet/_zprava/dna-poprve-poslouzilo-jako-hudebni-nosic-data-uchova-i-na-tisice-let--1759130
Noble Audio
PríspevokZaslal: Po máj 07, 2018 12:52:23    Predmet: Odpovedať s citátom
Music Instrument Frequency Cheatsheet
https://www.sweetwater.com/insync/music-instrument-frequency-cheatsheet/
PríspevokZaslal: St máj 16, 2018 13:40:58    Predmet: Odpovedať s citátom
Tyll Hertsens konci s recenziami sluchadiel na InnerFidelity a ide si uzivat dochodok jazdenim v karavane...
https://www.innerfidelity.com/content/thats-itim-out
PríspevokZaslal: St máj 23, 2018 15:46:43    Predmet: Odpovedať s citátom
O tom, ako pridanim druhej harmonickej do signalu meni subjektivnu kvalitu zvuku.
https://www.innerfidelity.com/content/katzs-corner-episode-25-adventures-distortion
tatko Tom
Založený: 21 február 2016
PríspevokZaslal: St máj 23, 2018 16:36:55    Predmet: Odpovedať s citátom
"Žiadne skreslenie neznie lepšie než elektrónkové skreslenie" Very Happy
Prečo pre nás hodne starších znie ten zvuk príjemne?
Proste sme ho počúvali od mala. A tá farba vlákna je krásna - atavizmus z hľadenia do žeravých uhlíkov životodarného ohňa Smile
PríspevokZaslal: Št máj 24, 2018 14:08:54    Predmet: Odpovedať s citátom
PERCEPTION & MEASUREMENT OF HEADPHONE SOUND QUALITY: IS THERE A PREFERRED TARGET RESPONSE?
SEAN OLIVE, TODD WELTI, OMID KHONSARIPOUR
OCTOBER 16 2017
https://www.listeninc.com/wp/media/Perception_and_-Measurement_of_Headphones_Sean_Olive.pdf
tatko Tom
PríspevokZaslal: Št máj 24, 2018 14:13:53    Predmet: Odpovedať s citátom
Kto to má študoveť bez znalosti angličtiny? Very Happy
Nejaký výcuc - uzáver by nebol?
PríspevokZaslal: Št máj 24, 2018 14:33:27    Predmet: Odpovedať s citátom
no ale aj anglictinu je treba studovat :-))
prezri si zaverecne stranky ... z grafov nieco urcite vycitas :-)
PríspevokZaslal: Št máj 24, 2018 15:11:32    Predmet: Odpovedať s citátom
zaujimave pre mna je ze so spravnou ekvalizaciou dosiahli zlepsenie subjektivneho hodnotenia lacnych i drahych sluchatok ... a to testovali i "virtualne sluchatka" ked nasimulovali frekvencnu odozvu nejakych sluchatok na inych sluchatkach ... pozri stranky 29 a 30 a ako to simulovali stranka 33
a z grafov na strane 45 sa da vyvodit, ze audeze lcd2 boli hodnotene lepsie nez sennheiser hd-800 a tie uplne zle vpravu su dre studio beats
PríspevokZaslal: Št jún 14, 2018 13:57:47    Predmet: Odpovedať s citátom
https://medicalxpress.com/news/2018-06-people-deeply-grasp-pain-happiness.html
People with higher empathy differ from others in the way their brains process music, according to a study by researchers at Southern Methodist University, Dallas and UCLA.
SvoP
Založený: 08 december 2013
PríspevokZaslal: Pi jún 15, 2018 07:21:23    Predmet: Odpovedať s citátom
Já to mám vyzkoušené na laciných Koss Porta Pro, vhodná equalizace (nastavení na: https://premsvo.wordpress.com/2014/11/29/koss-porta-pro/ ) je dostane subjektivně skoro na úroveň Beyerdynamic DT 990 Pro a přitom méně tlačí na uši a jsou příjemnější na hlavě.
Přidávání harmonických se často používá pro nabízené (volitelné) vylepšení zvuku v ovladačích komerčních zvukových karet. Použitelnější jsou specializované programy, kde se dá vše nastavit, např. Calf Exciter pro vyšší harmonické a Calf Bass Enhancer pro nižší.
Uvedené programy používám pro úpravu zvuku starých nahrávek (např. prvotní Elvis) a nejsou zatím remasterované. Je to lepší než marné pokusy s EQ, protože na těch starých nahrávkách od určité frekvence prostě nic není a EQ nepomůže.
tatko Tom
PríspevokZaslal: So jún 16, 2018 21:00:42    Predmet: Odpovedať s citátom
Tak neviem no pre moje uši proti Superlux HD681 EVO Koss Porta Pro hrajú s akoukoľvek ekvalizáciou na hov.....
Naposledy upravil tatko Tom dňa So jún 16, 2018 21:54:02, celkom upravené 1 krát.
bacil2
Založený: 29 marec 2013
PríspevokZaslal: So jún 16, 2018 21:52:33    Predmet: Odpovedať s citátom
... no z hovna bič neupletieš ... a mimochodom DT990 nie sú až taký veľký zvukový zázrak v porovnaní s KPP aj bez ekvalizéra Laughing
Suchý ňúter mokrý ven
želáme vám dobrý den
PríspevokZaslal: Po august 20, 2018 19:40:26    Predmet: Odpovedať s citátom
I raised one finger "One minute. That's how long they (my family) can listen to my system before they start yapping over the music," I said. "They don't care about my hi-fi."
She chuckled hoarsely. "This isn't about your hi-fi. It's about creating family moments around your hi-fi. To do so, you have to follow three rules."
Zdroj: THE BASICS ABOUT DISTORTION IN MICS
- https://www.dpamicrophones.com/mic-university/the-basics-about-distortion-in-mics
Naposledy upravil miero dňa St január 16, 2019 08:47:08, celkom upravené 1 krát.
PríspevokZaslal: St január 16, 2019 08:45:45    Predmet: Odpovedať s citátom
When the sound pressure level exceeds 194 dB SPL, there are no more air molecules to form the negative part of the soundwave as it reaches the point of a total vacuum.
Viac: https://www.dpamicrophones.com/mic-university/the-basics-about-distortion-in-mics
PríspevokZaslal: So február 09, 2019 08:38:55    Predmet: Odpovedať s citátom
Uz je to tu sice v inom vlakne, ale tam by to zapadlo :)
https://www.idnes.cz/technet/audio-foto-video/allen-sides-rozhovor-o-hudbe-a-zvuku-s-allenem-sidesem-nejvehlasnejsim-zvukarem-na-planete.A190123_102357_audio-foto-video_nyv
a toto je zvlastne:
Za tři týdny budu v studiu Abbey Road natáčet stočlenný orchestr pro jeden film, vše budu dělat na 192 kHz / 24 bit, ale pak to převedu na analog a zdigitalizuju na 48kHz/24 bit, což je filmový formát.
Sendy
Založený: 29 november 2008
PríspevokZaslal: St február 13, 2019 20:17:22    Predmet: Odpovedať s citátom
Zajímavé, že takový studioman a mj. tvůrce reprobeden vůbec v celém textu nezmínil kabeli Laughing
PríspevokZaslal: St február 27, 2019 08:08:07    Predmet: Odpovedať s citátom
Jeden starsi a dlhsi, ale dobry rozhovor:
- http://ukiro.com/2011/05/12/interview-daniel-weiss/
PríspevokZaslal: Po marec 11, 2019 08:19:30    Predmet: Odpovedať s citátom
Ed Meitner:
- https://www.stereophile.com/content/meitner-emm-dv2-dsd-mqa-digital-audio
PríspevokZaslal: Po marec 11, 2019 08:35:28    Predmet: Odpovedať s citátom
Jo, (konkurenční/nekompatibilní) DSD je (cituji) bullshit, zatímco (jejich proprietární uzavřené) MQA je super. Klasika.
merhaut
Založený: 12 október 2006
PríspevokZaslal: Po marec 11, 2019 09:40:02    Predmet: Odpovedať s citátom
Nic takového neřekl.
PríspevokZaslal: Po marec 11, 2019 09:42:13    Predmet: Odpovedať s citátom
Jo, sorry, "bullshit" byla ta rivalita mezi formáty. Omlouvám se.
PríspevokZaslal: Po marec 11, 2019 09:59:38    Predmet: Odpovedať s citátom
Som nepochopil, preco podla neho ma byt taka vyhoda, ze sa highres MQA prenesie s 1fs, t.j. 44100kHz. A o tom, ze bitova hlbka tych komprimovanych dat je 24bit a nie 16bit uz pomlci.
Jedine ak to, ze "staci" mat jeden format. Ale i tak je to blbost, kedze streamovacie sluzby maju viac streamov s roznov kvalitou. Napr. Spotify ma minimalne 3.
PríspevokZaslal: Po marec 11, 2019 10:12:28    Predmet: Odpovedať s citátom
Výhoda pro něj je, že si implementátor musí od něj koupit licenci na MQA.
PríspevokZaslal: Po marec 11, 2019 10:51:01    Predmet: Odpovedať s citátom
Ten rozhovor je s vyrobcom DACu. Ale chapem, ze vyrobca sa snazi vyrabat a predavat to co chcu zakaznici...
PríspevokZaslal: Po marec 11, 2019 10:56:50    Predmet: Odpovedať s citátom
No jo, jsem zmatenej, už jsem zticha...
PríspevokZaslal: Ut marec 19, 2019 15:12:05    Predmet: Odpovedať s citátom
As hard as it is for me to admit being a long time supporter and producer of real high-resolution music, whatever differences there are between a real 96/24-bit ultra high fidelity original and a version carefully downconverted to CD-spec are so slight that they don’t matter — even on the most expensive, “high resolving” systems. Deal with it.
Zdroj: http://www.realhd-audio.com/?p=6448
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Hi-Fi čitáreň Časy uvádzané v GMT + 1 hodina
Strana 2 z 3
