KEF LS50, black
Peter2
Založený: 13 október 2013
PríspevokZaslal: Ne apríl 15, 2018 20:09:53    Predmet: KEF LS50, black Odpovedať s citátom
predam skvele regalovky KEF LS50 v 98% stave. Vek cca 4 roky, Komplet prepravne boxy, papiere. Nefajciarske prostredie, nevyuzite - prechod na stlpy.
Cena 700e
Description: Two-way, reflex-loaded, stand-mounted loudspeaker. Drive-units: Uni-Q driver array with 1" (25mm) vented aluminum-dome tweeter, 5.25" (130mm) magnesium/aluminum alloy-cone woofer. Crossover frequency: 2.2kHz. Frequency range (–6dB): 47Hz–45kHz. Frequency response: 79Hz–28kHz, ±3dB. Sensitivity: 85dB/2.83V/m. Nominal impedance: 8 ohms. Minimum impedance: 3.2 ohms. Harmonic distortion (second and third harmonics, 90dB, 1m):
NAD M3, CA Magic Stream 6, Synology DS416play, Chord Carnival SilverScreen, Chord Chameleon VEE 3 stereo RCA interconnect, Velodyne SPL-1200R, Focal chord 826W
Peter2
PríspevokZaslal: Ne apríl 29, 2018 21:52:01    Predmet: KEF LS50, black Odpovedať s citátom
Predane. Dakujem za priestor
