Low End 1000W Alan Kraus
PríspevokZaslal: Pi október 12, 2018 13:50:36    Predmet: Odpovedať s citátom
Nevím zdali to víte, ale tyto zesilovače jsou dílo z " kanadského obdoní " Jirky Krampery...Osobně mi ohehdá vyprávěl o své kariéře u této fimy : když přišel do Kanady, sháněl práci a zde jej pozvali na pohovor....přišel a měli pak s majitelem firmy dlouhý rozhovor, jehož výsledkem bylo následující : závěrem mu majitel firmy řekl...zcela jsi mě přesvědčil, chceš-li, můžeš zítra nastoupit, zde máš klíče od skladu a zítra budeš mít podpisové právo na dokumenty...na vše máš volnou ruku... a Jirka svěřenou důvěru nezklamal, vzniklé zesilovače jsou nádherný dodnes... Laughing
PríspevokZaslal: Pi október 12, 2018 14:19:28    Predmet: Odpovedať s citátom
V historii firmy Yorkville spisanej Mike Holmanom je i par historiek pripisanych priamo JK:
George Krampera could speak enough English to make himself more or less
understood. He, his wife and their child had escaped from behind the Iron Curtain a few
years earlier and thereafter travelled to Canada. Now he was at Yorkville Sound looking
for a job. During an interview with the bearded Czech, lab chief Paul Ierymenko
concluded that George was probably way over-qualified to be employed as a repairman
and there didn’t seem to be much of an opening in R&D.
That might have been the end of it, however George spotted a Bloc-100G guitar amp
and commented that back home in Czechoslovakia he had hot-rodded similar amps
from another manufacturer to provide a better rock & roll sound. If there was one thing
lacking in the early Bloc guitar amps, that was it. Paul invited him to show what he could
do and shortly George presented him with a really good-sounding amp. George was
promptly hired and his circuit modifications were adopted for all future guitar Bloc
production.
With the Bloc-100K completed and off to a good start, Paul asked George what else he
would like to design. George’s reply went something like this, “I like mehk leettle
speakers mehk beeg sound.” George was given the go-ahead and, a few weeks later,
demonstrated a small prototype PA enclosure with a ten-inch RCF woofer and an
aluminum RCF horn/driver. There was also a black-box electronic processor to regulate
the amplifier.
Comparisons with competitive products were impressive so George happily set about
making what he termed, “Leetle bit beeger, kick-ess speaker”.
Zdroj: https://medias.audiofanzine.com/files/yorkvillehistory-471231.pdf
ickx
Založený: 12 december 2009
PríspevokZaslal: Pi október 12, 2018 14:22:33    Predmet: Odpovedať s citátom
To je sice hezké, ale jak to souvisí se zesilovačem od Alana Krause?
Tímto všem velice děkuji
PríspevokZaslal: Pi október 12, 2018 14:29:33    Predmet: Odpovedať s citátom
Kontext mas predsa v predchadzajucich prispevkoch... :-)
Ako vlastne budes pokracovat? Neskusis to hodit do simulatora a odladit to aspon v nom skor nez sa pustit do stavby? S nim by si jednoduchsie zaintegroval ziskane rady a odsimuloval ze to este nejako teoreticky funguje.
PríspevokZaslal: Pi október 12, 2018 16:05:37    Predmet: Odpovedať s citátom
Kontext mas predsa v predchadzajucich prispevkoch... Smile
Pokud to začne podle těch zdejších zaručených rad upravovat, tak výsledek bude tak leda průšvih, slušně řečeno. Nebylo by to tak na slovanetu poprvé, s dobrými radami. Riziko nese jen stavitel. Opakuju, pokud tomu moc nerozumí, jako že evidentně ne, tak je nejlepší postavit originál a nevrtat se v tom. Tam aspoň víme, že fungoval.
PríspevokZaslal: Pi október 12, 2018 16:07:05    Predmet: Odpovedať s citátom
production.
the amplifier.
Škoda že někdy nepřijdeš s nějakým vlastním názorem nebo nápadem, místo těch věčných odkazů.
ickx
PríspevokZaslal: Pi október 12, 2018 16:15:53    Predmet: Odpovedať s citátom
Měl jsem v plánu to postavit podle toho jak to je, pak ale mi napsal Leoš M. že to postavil a je tam spoustu chyb kvůli kterým to nefungovalo a musel to celý predělat. Když jsem se ho ptal přestal semnou komunikovat.
Proto jsem napsal tady,a jelikož tam není žádná fatalní chyba tak to postavím.
To,že zesilovač fungoval není jistý,jak už jsem psal na dps jsou špatně vývody tranzistorů mje340/350.
PríspevokZaslal: Pi október 12, 2018 16:59:53    Predmet: Odpovedať s citátom
A nelze zvolit nějaké ověřené řešení třeba z diyaudio.com, které třeba ještě lidi pořád staví, diskutují, řeší? Nedíval jsem se, ale určitě nějaké na internetu bude...
PríspevokZaslal: Pi október 12, 2018 18:04:33    Predmet: Odpovedať s citátom
Těch Tvejch 10Mohm se zaručeně nepozná, to je bezpečí takovejch rad na hovno Rolling Eyes
PríspevokZaslal: Pi október 12, 2018 19:51:00    Predmet: Odpovedať s citátom
Neviem ci danhard a dalsi pri tomto navrhu nevyskocia z koze, ale nebol by lepsi a odladenejsi nez tento zosilnovac nejaky ten od majstra z Roznova p. R.?
Alebo ani on to este nepostavil a ma len vizualizaciu?
jmd
PríspevokZaslal: Pi október 12, 2018 20:48:28    Predmet: Odpovedať s citátom
Nakladáš?
PríspevokZaslal: So október 13, 2018 11:22:26    Predmet: Odpovedať s citátom
Můj pocit je, že právě toto vůbec nevíme. Už jenom ty přehozené vývody tranzistorů, to Ti uniklo ?
jmd
PríspevokZaslal: So október 13, 2018 12:04:00    Predmet: Odpovedať s citátom
BV napísal:
R3 dať 27k "devil is in detail" Smile
nie je to zo strany autora zosilňovača zámer mať to celé rozladené, keď už sú aj R12 až R15 rovnakej hodnoty 1k ? Dať všade 100p je tiež gól.
PríspevokZaslal: So október 13, 2018 12:53:15    Predmet: Odpovedať s citátom
Jsou 1k8 Smile Proud tranzistory v differáku á 1mA, VAS 2x10mA.
MJE340 je pohrobek tranzistoru 2N3440, když dám 2 paralelně, tak tam můžu dát rovnou jeden 2SC4793 a ten je v TO220 pouzdře, které je omylem na PCB.
Kromtoho MJE340 dělá několik výrobců a některý mají mzernou betu.
jmd
PríspevokZaslal: So október 13, 2018 13:07:17    Predmet: Odpovedať s citátom
Pozerám, že dnes s cenou a dostupnosťou MJ15003/4 v TO3 to už nie je kritické a dá sa nájsť aj u dobrého dodávateľa. Čakal som 2x takú cenu a mesiac čakania.
PríspevokZaslal: So október 13, 2018 20:28:46    Predmet: Odpovedať s citátom
Když to budeš kupovat, tak jdi do něčeho z poslední doby, stojí to stejně, je to lepší a hlavně to bude od slušného výrobce.
A taky bych opustil TO-3 pouzdro, za to se už platí, ještě tak před 15-lety to v něm bylo levnější Smile
jmd
PríspevokZaslal: So október 13, 2018 22:25:03    Predmet: Odpovedať s citátom
Ked uz doba pokrocila, nedali by sa kupovat rovno tie male chipsy ? Hoci neviem ako je to lepene na zakladnu C. To je taka vecerna myslienka alebo pochod nezmyselnych myslienok.
ickx
PríspevokZaslal: Ne október 14, 2018 12:46:45    Predmet: Odpovedať s citátom
Asi bude lepší jít touto cestou http://www.ezk.cz/stavebnice_moduly/kmd7666.htm
Předek oprásknutej z DPA880 a na konci 6 paralelních páru MJL1302A/MJL3281A napájení 90V Wink
PríspevokZaslal: Ne október 14, 2018 12:55:37    Predmet: Odpovedať s citátom
a co tak nieco hotove z druhej ruky? napr. QSC RMX-2450 za 4500Kc
- https://hudba.bazos.cz/inzerat/95597231/zesilovace.php
PríspevokZaslal: Ne október 14, 2018 14:36:40    Predmet: Odpovedať s citátom
Je mnoho výrazně lepších zapojení, který by stály za pořádný rozbor, abyste se na takovým příkladu něco pořádnýho naučili, ale vy si jako na potvoru vyberete tuhle ptákovinu...má to pro mě nějakou skrytou logiku ? Laughing
PríspevokZaslal: Ne október 14, 2018 16:23:03    Predmet: Odpovedať s citátom
ake napriklad? DPA1000?
PríspevokZaslal: Ne október 14, 2018 17:13:39    Predmet: Odpovedať s citátom
Tak proč jim neporadíš ?
jmd
PríspevokZaslal: Ne október 14, 2018 18:36:45    Predmet: Odpovedať s citátom
Druhy navrh KMD7666 sa mi viac paci, len sa mi zda zbytocny prepich osadzat ho MJL1302A/MJL3281A. Pouzil by som kludne pomalsie a zarovan odolnejsie typy MJL21193-6
PríspevokZaslal: Ne október 14, 2018 18:37:52    Predmet: Odpovedať s citátom
Tisícovka je v podstatě dost podobný řešení ( viz to sériovo paralelní zapojení ), ale je to taky podobně stará mršba, jen to nemělo žádný evidentní chyby, protože před publikováním to bylo odladěný ( bylo postaveno cca deset kompletních přístrojů, čili čtyřicet kanálů )...ale nějaký rady ode mě nečekejte, už nemám iluze....
PríspevokZaslal: Ne október 14, 2018 18:52:55    Predmet: Odpovedať s citátom
Mnoho byste se naučili z třeba Kramperových zapojení, neboť ty jsou vskutku moderní a originální, ale nejsou moje a já nemám tudíž právo něco zveřejňovat...
PríspevokZaslal: Ne október 14, 2018 18:58:05    Predmet: Odpovedať s citátom
Proto jsem to sem dával, protože nad nima nebudeš prskat Very Happy
Pár nejasností tam ale je, nadproud se snímá na jednom konci na 0R15, ostatní konce mají ale 0R1 Question
jmd
PríspevokZaslal: Ne október 14, 2018 20:08:46    Predmet: Odpovedať s citátom
danhard napísal:
Třeba, nebo tady aspoň můstek, zjednodušší se napájení, jištění stačí jen v jedné polaritě, v druhé se dají snížit emit. odpory.
Nebo aspoň vynechat emit odpory v horním patře a samozřejmě jinak propojit.
Mne sa páči ako nad tým uvažuješ a predpokladám, že to k niečomu je aj u toho Yorkville AP4040.
PríspevokZaslal: Ne október 14, 2018 20:23:13    Predmet: Odpovedať s citátom
No jistě, do 200W to nějak uchladíš, při 1kW už musíš sakra dávat bacha, aby jsi někde zbytečně nevytápěl.
A můstek Ti může zjednodušit napájení a zlepšit využití trafa.
Ale první bych doporučil, aby si půjčil zesilovač, kterej ty výkony skutečně má a vyzkoušel si, jestli to tak potřebuje.
Domací karaoke Laughing
Co se týče kvality, tak to Alanovo 1kW za moc stát nebude, na to je to dost ošizený a pomalý.
Třeba kdyby na VAS použil jen jednu MJE... při 10mA a za ní druhou jako emit. sledovač, tak je to o třídu jinde.
ickx
PríspevokZaslal: Po október 15, 2018 11:09:07    Predmet: Odpovedať s citátom
Koukám na Yorkville AP2020
http://yorkville.com/legacy/product/ap2020/
http://yorkville.com/downloads/servman/sm_ap2020.pdf?v=1440085107
Je to třída H, takže dvě napěťové hladiny 51V a 91V a se ctyři páry MJ21195/96 to dává: 600w do 2 nebo 4 ohmů nebo 1200W do 4 nebo 8ohmů v můstku. Což je to co hledám
Smile
Je k tomu komplet servis. dokumentace včetně DPS, takže by se to dalo za dlouhým zimních večerů obšlehnout.
Je v tom ale použito dost špatně sehnatelných součástek :
Diody MR854
Mosfety MTP23P06
tranzistory MJF6388/6668
OZ LM13600N
Jinak ta dokumentace je pěkně precizně přehledná, ne jako to většinou prasí amící. Je vidět Kramperovo rukopis.
PríspevokZaslal: Po október 15, 2018 14:29:19    Predmet: Odpovedať s citátom
Abysme toho Kramperu zas nepřechválili, tohle je do 2R dost neduživý.
Všimněte si, že o stupeň silnější AP2020 tam má hned čtyři paralelně.
Ale jde o výkonový dimenzování koncových tranzistorů, ne aby si to celý opráskl.
Hlásil jsem jen, že to má Alan 2x předimenzovaný, jelikož to počítal pro dc.
Strana 3 z 4
