Zaslal: Po december 03, 2018 10:15:38 Predmet: Lampy se vrací :-) |
Chytré a vlastně úplně jednoduché https://www.rmit.edu.au/news/all-news/2018/nov/Nanochips-out-of-thin-air
citácia: | Research team leader Associate Professor Sharath Sriram said the design solved a major flaw in traditional solid channel transistors – they are packed with atoms - which meant electrons passing through them collided, slowed down and wasted energy as heat.
“Travelling in a vacuum on the other hand is like an empty highway where you can drive faster with higher energy efficiency.”
But while this concept is obvious, vacuum packaging solutions around transistors to make them faster would also make them much bigger, so are not viable.
“We address this by creating a nanoscale gap between two metal points. The gap is only a few tens of nanometers, or 50,000 times smaller than the width of a human hair, but it’s enough to fool electrons into thinking that they are travelling through a vacuum and re-create a virtual outer-space for electrons within the nanoscale air gap,” he said.
The nanoscale device is designed to be compatible with modern industry fabrication and development processes. It also has applications in space – both as electronics resistant to radiation and to use electron emission for steering and positioning ‘nano-satellites’. |
check Martin Vitvar
Zaslal: Po december 03, 2018 10:45:43 Predmet: |
Je zajímavé sledovat, jak se téměř zapomenuté technologie vracejí do života.
Kamarád mi minulý týden ukazoval starý svitkový středoformátový fotoaparát z roku 1986, který měl ovšem automatické ostření podle toho kam se koukáte do hledáčku. Kalibrováno na vaše oko, funguje perfektně. Ostření přes dotykovou obrazovku v ten moment vypadá jako hračka pro děti. A tohle šlo přes 32 lety, jenom se na to ve spotřební elektronice zapomělo. _________________ http://vmaudio.cz/ |
Zaslal: Po december 03, 2018 10:54:25 Predmet: |
Dřív neuměli vyrobit <35nm mezeru. IMO se pořád hledají cesty pro stejné fyzikální jevy, jenom se mění technické možnosti, jak je využít. |
Založený: 18 január 2007 Príspevky: 20471
Zaslal: Po december 03, 2018 11:02:33 Predmet: |
check napísal: | Je zajímavé sledovat, jak se téměř zapomenuté technologie vracejí do života.
Kamarád mi minulý týden ukazoval starý svitkový středoformátový fotoaparát z roku 1986, |
Hehe, starý . Mám dodnes funkční Rolleicord Ia z roku 1937 (6 x 6). _________________ mám rád hifi, ale víte, jak je to dál ..... |
check Martin Vitvar
Zaslal: Po december 03, 2018 19:51:36 Predmet: |
A on má výběr ostřícího bodu v hledáčku podle pohledu oka? Nebo jak to souvisí? _________________ http://vmaudio.cz/ |
Zaslal: Po december 03, 2018 22:36:20 Predmet: |
Na to si odpověz sám. _________________ mám rád hifi, ale víte, jak je to dál ..... |
check Martin Vitvar
Zaslal: St december 05, 2018 11:37:57 Predmet: |
PMA napísal: | check napísal: | Je zajímavé sledovat, jak se téměř zapomenuté technologie vracejí do života.
Hehe, starý . Mám dodnes funkční Rolleicord Ia z roku 1937 (6 x 6). |
Hehe, starý . Mám dodnes reprodukci autoportrétu Leonarda z roku 1512 ( 24 x 38 ). _________________ http://vmaudio.cz/ |
JHradec Hifista - zaslúžilec
Zaslal: Št december 06, 2018 09:14:23 Predmet: |
reprodukce = fake pořiď si originál |
check Martin Vitvar
Zaslal: Št december 06, 2018 10:46:39 Predmet: |
Ve stejném duchu prosím vyházej reproduktory z domu a pořiď si domu originál .
Jako vážně si tady musíme poměřovat ocásky? Kvůli tomu sem nepíšu. _________________ http://vmaudio.cz/ |
Založený: 08 september 2010 Príspevky: 11543 Bydlisko: Praha
