sluchátkový zosilňovač S.M.S.L.
easy
Založený: 03 december 2006
PríspevokZaslal: Ne jún 16, 2019 10:15:01    Predmet: sluchátkový zosilňovač S.M.S.L. Odpovedať s citátom
Predám sluchátkový zosilňovač.Minimálne používaný,výborný zvuk.
Cena:60€
easy@atlas.sk
Bratislava 2
Podrobnejšie info:
S.M.S.L. SAP2
sApII PRO circuit design as Texas Instruments (TI) top-TPA6120A2 headphone driver chip as core, TPA6120A2 is a current feedback amplifier circuit, conversion rates up 1300V/μs. Distortion of only 0.00014% THD + N, 120dB dynamic range, 120dB SNR. TPA6120A2 very powerful driving force, the maximum output current up to 700mA. Meet the large impedance headphones. With see above indicators, TPA6120A2 is positioned as HI-FI TI class headphone amplifier chip.
Therefore, sApII positioned as a professional high-power headphone amplifier.
2:
sApII PRO circuit design as a front end to Burr Brown OPA2604AP enlarge.
OPA2604AP for high-performance audio system design special op amp。low harmonic distortion, low noise, high gain bandwidth characteristics.
Dual FET-input OPA2604 provides a wider dynamic range, the sound is more resistant to listen. Generally used in professional audio equipment, spectrum analyzers and other high-end devices. (Old version without this part circuit)
3:
sApII PRO use Texas Instruments (TI) high-performance op amp NE5534 as headphone protection circuit, high sensitivity headphones starting voltage protection circuit protection is 0.7V, than ordinary amp protection circuit sensitivity doubled. Protect your headphones, we are more professional. (Earlier versions do not have this part circuit)
4:
sApII PRO power supply using partial pressure techniques,Use high precision potentiometers for balance calibration, a high degree of positive and negative voltage balance. Another specialized high capacity filter capacitor filter, power quite clean. Maximum inhibition of low-noise, so that the headset can be heard almost no noise, let your ears more comfortable.
FEATURES
80 mW into 600Ω From a ±12-V Supply at 0.00014% THD + N
Current-Feedback Architecture
Greater than 120 dB of Dynamic Range
SNR of 120 dB
Output Voltage Noise of 5 µVrms at Gain = 2 V/V
Power Supply Range: ±5 V to ±24 V
1300 V/µs Slew Rate
Differential Inputs
Independent Power Supplies for Low Crosstalk
Short Circuit and Thermal Protection
Input interface: 3.5mm/RCA, stereo input (with switch)
Output interface: 6.35mm headphone Block
Shell color: black
Panel Color: black / silver / gold (purchase please specify)
Input Level: 400mv to 2V
Output power: 150mw / 250Ω, 300mW / 120Ω, 1000mw / 32Ω
Machine size: 126mm x 74mm x30mm (including protruding parts)
Package weight: 500G (subject to actual shipping weight outside packaging structure)
Configuration list: sAp II of × 1 , DC24V Japan PSE certification power × 1
Voltage :100-240ACV global universal power supply
 Filesize:  68.41 KB
 Viewed:  9 Time(s)
 Filesize:  66.36 KB
 Viewed:  15 Time(s)
Pioneer BDP-150,Sony DVP-NS955V,LG MS400,Pioneer N-50A,Marantz PM6006,XTZ 99.26MK2,AKG K702
