Zaslal: Po jún 10, 2019 11:31:20 Predmet: |
Observations on the Audibility of Acoustic Polarity http://www.aes.org/e-lib/browse.cfm?elib=6950
Nemám přístup do AES, ale dle citace je to přesně případ výrazné asymetrie signálu:
citácia: | Excerpts:
"If asymmetry of the waveform is important in relation to hearing polarity inversion, then several precautions and warnings about loudspeaker systems are in order. HIgh values of even-order distortion, that is, second, fourth, etc., in a sound system might make polarity more audible.....
What reduces the ability to hear acoustic polarity inversion as the music signal becomes more complex? One factor is simply the complexity of the music itself. There is often too much going on to allow human concentration on subtle effects. Since the perception of inversion seems to manifest itself through changes in both timbre and pitch, the normal musical playing of a note, such as vibrato, tremolo, and instrumental filigree, may significantly obscure the inversion effects in most cases....
While polarity inversion is not easily heard with complex musical program material, as our large-scale listening tests showed, it is audible in many simplified musical settings."
https://www.head-fi.org/threads/looking-for-double-blind-test-event-about-phase-inversion.818445/page-2#post-12941361[/quote] |
