aretax Hifista - pokročilec
Založený: 08 september 2010 Príspevky: 11520 Bydlisko: Praha
Zaslal: Št september 17, 2020 07:38:00 Predmet: |
Neskusal si pisat Troelsovi, aspon na jeho nazor na taku zmenu?
seas Hifi expert
Zaslal: Št september 17, 2020 08:02:17 Predmet: |
Pfizer Spolu UA forum
Naposledy upravil seas dňa So december 31, 2022 01:09:35, celkom upravené 1 krát. |
Založený: 06 október 2006 Príspevky: 5944 Bydlisko: Trnava
Zaslal: Št september 17, 2020 09:25:36 Predmet: |
citácia: | If you want to modify the constructions shown here, please read "crossovers" before doing so. In most cases you will need a new crossover and I would need your speaker on my test bench to tell you how. DIY SERVICE is provided in case you live in driving distance of Aarhus, Denmark. This for your up-grade of existing speakers or crossover design for your own construction.
Should you run into problems with the constructions presented here, I'll do all I can to assist in the successful implementation.
Sorry, but time doesn't allow assisting in any hypothetical combination of drivers of your own choice, |
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
matulo_g Hifista
Zaslal: Št september 17, 2020 15:10:24 Predmet: |
Basova sekcia je typu TL, takze uprava vyhybky stacit nebude.
Co ma byt cielom "upgrade"?
Martin
_________________ PC/iPad/BR/TV > DENON AVR (multi-amp) > LinkwitzLab ORION (ASP)
Naposledy upravil matulo_g dňa Št september 17, 2020 18:40:27, celkom upravené 1 krát. |
Zaslal: Št september 17, 2020 15:47:45 Predmet: |
Vymen kable, alebo hroty
moses Hifi expert
Zaslal: Št september 17, 2020 16:08:59 Predmet: |
Zaslal: Št september 17, 2020 18:35:45 Predmet: |
Pred upgrade by za pokus by stala este softverova ekvalizacia resp. room correction pre nizke frekvencie.
Zaslal: Št september 17, 2020 19:03:46 Predmet: |
miero napísal: | Neskusal si pisat Troelsovi, aspon na jeho nazor na taku zmenu? |
Aj som s ním telefonoval, je veľmi ochotný, ale podmienkou je priniesť k nemu bedne. A to je vylúčené.
K ostatným príspevkom: vzhľadom k odbornosti, ktorú tu väčšina deklaruje, som sa nič nedozvedel. Čo sa týka stavby ozvučnice, tak Troels navrhol presne rovnaké ozvučnice pre Scan Speak aj AudioTechnology.
Odar, Moses: ďakujem za "odbornú" radu, ktorá Vašu odbornosť presne vystihuje. Pokiaľ viac k tomu nemáte, venujte sa radšej "odbornému" komentovaniu príspevkov z vedľajšieho fóra. Na to ste naslovovzatý odborníci.
_________________ 112233 |
Zaslal: Št september 17, 2020 20:57:38 Predmet: |
Nie je za čo. Aj nabudúce. Spýtaj sa odborníkov na highendfore. Tí ti isto poradia, akú kabeláž a koncovky máš použiť Tu píšu už len skrachovaní dôchodcovia a spamboti
Zaslal: Pi september 18, 2020 07:37:09 Predmet: |
Odar napísal: | Nie je za čo. Aj nabudúce. Spýtaj sa odborníkov na highendfore. Tí ti isto poradia, akú kabeláž a koncovky máš použiť Tu píšu už len skrachovaní dôchodcovia a spamboti |
Konečne si napísal aj niečo múdre.
Zaslal: Pi september 18, 2020 08:17:27 Predmet: |
Ja by som sa na to aj dal. Ale podmienkou je doviesť prerobenú bedňu ku mne. Len neviem či som hoden. Odborník určite nie.
Zaslal: Pi september 18, 2020 08:38:50 Predmet: |
Je ťažké niečo rozumné navrhnúť , keď už majiteľ vopred vie, čo bude podľa neho nutné,
citácia: | Zvažujem upgrade týchto sústav výmenou basového meniča. Potreboval by som navrhnúť úpravu výhybky |
že je nutné vymeniť basový menič, upraviť výhybku a vie presne , ktorý menič tam treba dať.. Prečo?? Jediný dôvod? Čo sa má zlepšiť, kde je v súčasnosti objektívne deficit?
A úprava výhybky vôbec nemusí byť nutná (možno len sériový RLC paralelne k meniču..), skôr bude potrebná úprava TML boxu (dĺžka rezonátora, jeho tlmenie..) v spojitosti s výmenou basového meniča. A to je prakticky výroba nového boxu..Toto sa výhybkou "doladiť" nedá..Asi tak
Zaslal: Pi september 18, 2020 18:30:54 Predmet: |
BV napísal: | Je ťažké niečo rozumné navrhnúť , keď už majiteľ vopred vie, čo bude podľa neho nutné,
A úprava výhybky vôbec nemusí byť nutná (možno len sériový RLC paralelne k meniču..), skôr bude potrebná úprava TML boxu (dĺžka rezonátora, jeho tlmenie..) v spojitosti s výmenou basového meniča. A to je prakticky výroba nového boxu..Toto sa výhybkou "doladiť" nedá..Asi tak |
Asi Ti ani nemá zmysel odpovedať. Ale ak si pozrieš linky, ktoré som uviedol a otvoríš si projekty Troesl, tak zistíš, že na obidva basáky použil Troels ten istý box (Jenzen Illuminator a Jenzen Accu), teda v boxoch to nie je. Ja som chcel iba vedieť, za akých podmienok by bolo možné vymeniť basové meniče. Troels mi povedal, že je možné upraviť výhybku, sle k jej návrhu potrebuje moje bedne, čo je dosť ťažko realizovateľné. Ja tam menič mám a naozaj viem presne, ktorý by som tam chcel, ak to pôjde !!! Keď sa to podľa Teba nedá, aj tak ďakujem za odpoveď. Na otázku prečo Ti poviem iba toľko, že je to iba moja zvedavosť. Ale to asi ťažko pochopíš.
Zaslal: So september 19, 2020 05:33:56 Predmet: |
Ďakujem, potvrdil si mi môj názor. Nechcel som dopredu, bez toho, aby mi niekto môj názor ptotvrdil skúšať, pretože AudioTechnology je dosť drahý a navyše je potrebné upraviť otvor.
Zaslal: So september 19, 2020 05:53:28 Predmet: |
Aj tak si myslím, že sa objektívne nič nezlepší a nestojí to za námahu, ale pocity budú určite úplne iné (práca, investícia, očakávanie..)
Zaslal: So september 19, 2020 08:20:46 Predmet: |
Myslím, že na zlepšenie, alebo zhoršenia zvuku máme rôzne názory, ale to je OK. Podľa toho, ako Troels popisuje zvuk AudioTechnology, ja osobne očakávam spevnenie basov v nízkych frekvenciách. Okrem toho tomu zodpovedajú aj grafy. Ale - uvidíme. možno máš pravdu Ty. Čo sa týka financií a investícií - moja záľuba je "hrať sa" a reprobedňami. Predtým, ako pristúpim k výmene basákov, idem spevniť predné ozvučnice 8 mm duralovými plátmi. Materiál už mám, idem ho frézovať. Aj to by malo priniesť mierne spevnenie basov, ale aj "prečistenie" stredov a výšok. Myslím tým posluchovo. Zmerať sa to asi nebude dať. To práve tvrdím ja - zmerať sa dajú základné parametre, ale zvuk, ako taky, jeho charakter asi nie. Ale ešte raz Ti ďakujem za Tvoj názor.
Henri Hifista - zaslúžilec
Zaslal: Ut september 22, 2020 12:37:49 Predmet: |
BV napísal: | Aj tak si myslím, že sa objektívne nič nezlepší a nestojí to za námahu, ale pocity budú určite úplne iné (práca, investícia, očakávanie..) |
Zdravím, na tejto stranke http://www.troelsgravesen.dk/10C77.htm ma Troels Gravesen porovnanie, aj zakladne meranie AudioTechnology 10C77-25-10-KAP a ScanSpeak 26W . (+SEAS W26FX002)
AudioTechnology mu vyšla najlepšie. Čisto teoreticky- ked si pozriete frekvenčku a zohladnite nižší VAS aj Qts ( namerane ma 0,27) AT-čka, by mohlo mať AT dôraznejší (“PA“) bas a SS zase mäkší, hifisticky bas ?
nebude potrebne aj mierne preladiť bassreflex ?
BlackBerry Hifi inventar
Zaslal: Ut september 22, 2020 12:58:03 Predmet: |
Aký?
Tam je Transmission Line horn čo má aretax.
Zaslal: Ut september 22, 2020 13:00:04 Predmet: |
To nie je basreflex, ale TML..A má to fungovať v rovnakom boxe, úprava(ladenie) TML je nereálna.
Možno by bol nejaký skutočne počuteľný rozdiel pri aktívnom delení (budenie z malej impedancie), kedy by sa viac uplatnilo vyššie Bl ale cez pasívnu výhybku sa rozdiely "zmažú"..
Zaslal: Ut september 22, 2020 16:16:51 Predmet: |
BV napísal: | To nie je basreflex, ale TML..A má to fungovať v rovnakom boxe, úprava(ladenie) TML je nereálna.
Možno by bol nejaký skutočne počuteľný rozdiel pri aktívnom delení (budenie z malej impedancie), kedy by sa viac uplatnilo vyššie Bl ale cez pasívnu výhybku sa rozdiely "zmažú".. |
Ok, nestudoval som konkretny projekt -ano u TML je pokles 12 dB na oktávu a u bassreflexu 24 dB na oktávu. Išlo mi hlavne o porovnanie zvukoveho charakteru oboch meničov, napr. Rog Mogale opisuje vplyv Q a EBP, asi takto: Použitie nižšieho / vyššieho Qes / Qts -je do istej miery otázkou voľby aký charakteru zvuku chceme docieliť. Zvuk reproduktora s vyšším Qes, pripadne nižším EBP je na ucho príjemnejši, taký teplejši bass, (viac "hifi" ). Naopak reproduktor s nižším Qes a vyššia EBP je zvukovo tvrdší, kopavejší (viac Profi zvuk) -Ono nejde až tak o celkove Qts ale o pomer Qms/ Qes, - čím je nižšie Qms tým je menší prúd v mag. medzere v okolí Fs. Z to vyplýva, že sa skor prejavi Roloff na nízkych frekvenciách. Čiže s reproduktorom, ktorý má vyššie Qes, je možne dosiahnuť rovnejšiu charakteristiku
