Zaslal: St január 04, 2023 10:33:02 Predmet: Equium: hifi reprak(?) v novom druhu tepelneho cerpadla |
Nejake cudo sa chysta...
citácia: | It works with a high-fidelity (Hi-Fi) speaker powered by electricity that creates an acoustic wave in a closed-pressure vessel filled with helium at a pressure of 30 bars. The acoustic wave causes the gas to compress or expand, displacing heat from a lower temperature to a higher temperature, or vice versa. The heat pump core is filled with water, which absorbs or releases that heat.
“The output regulation of a classical heat pump is very energy consuming. On our acoustic system, the regulation is very easy,” Loyer explained. “If you want less power, you can just decrease the volume of the Hi-Fi speaker.”
Equium claims that the heat pump system is completely silent, despite the use of a speaker to generate the acoustic wave. The level of noise is reportedly lower than 30 dB – the equivalent of a whisper.
“The sound our system produces stays confined inside the core, so you cannot hear it from outside,” said Loyer. |
Zdroj: https://www.pv-magazine.com/2023/01/02/residential-thermo-acoustic-heat-pump-produces-water-up-to-80-c/
Oficialne stranky startupu: https://www.equium.fr/en/home |
