Zaslal: Pi január 19, 2024 18:05:42 Predmet: ITU-R BS.2399-0: metodika popisu atributov zvuku a definicie |
(plny nazov) "Methods for selecting and describing attributes and terms, in the preparation of subjective tests"
- https://extranet.itu.int/brdocsearch/R-REP/R-REP-BS/R-REP-BS.2399/R-REP-BS.2399-2017/R-REP-BS.2399-2017-PDF-E.pdf
Uvediem par prikladov odtial:
citácia: | Punch (dynamics): Specifies whether the strokes on drums and bass are reproduced with clout, almost as if you can feel the blow. The ability to effortlessly handle large volume excursions without compression (compression is heard as level variations that are smaller than one would expect from the perceived original sound).
Scale: A little – A lot
Boxy (bass) denotes a hollow sound, as if the sound was played inside a small box. Represents resonances in the upper bass frequency range.
Scale: None – Weak – Loud
Clarity: The impression of how clearly different elements in a scene can be spatially distinguished from each other.
Scale: Unclear-clear
A singer and a piano performing a duet in a dry acoustic, may be perceived as clear. When listening to a choir from the rear of the church, the sound of the individual signers maybe unclear. |
