vivi Hifi expert
Zaslal: Po august 24, 2009 22:11:31 Predmet: CD vs SACD/DVD-A |
Pri citani specifikacie SACD na wikipedii som narazil na jednu zaujimavu informaciu:
In the audiophile community, sound from SACD is sometimes felt to be better compared to older format Red Book CD recordings. [34] However, in controlled listening tests over stereo reproduction subjects have not been able to tell SACD recordings from their CD-quality converted version.
Po chvilke patrania som nasiel viac info o tychto testoch.
Audibility of a CD-Standard A/DA/A Loop Inserted into High-Resolution Audio Playback
[Engineering Report] Claims both published and anecdotal are regularly made for audibly superior sound quality for two-channel audio encoded with longer word lengths and/or at higher sampling rates than the 16-bit/44.1-kHz CD standard. The authors report on a series of double-blind tests comparing the analog output of high-resolution players playing high-resolution recordings with the same signal passed through a 16-bit/44.1-kHz “bottleneck.” The tests were conducted for over a year using different systems and a variety of subjects. The systems included expensive professional monitors and one high-end system with electrostatic loudspeakers and expensive components and cables. The subjects included professional recording engineers, students in a university recording program, and dedicated audiophiles. The test results show that the CD-quality A/D/A loop was undetectable at normal-to-loud listening levels, by any of the subjects, on any of the playback systems. The noise of the CD-quality loop was audible only at very elevated levels.
Viac informacii bude zrejme v platenej verzii pdf, no nasiel som aj dalsie informacie - hlavne o zeleze na ktorom sa porovnavalo.
Skusal niekto porovnavat USAMI (teda slepe testy) a urobil podobne zavery?
Viem, ze ABX testy nie su moc oblubenou temou medzi hifistami, lebo kazdy rad "vidi" co prave hra, no napriek tomu by som sa rad vedel realne rozdiely. (Nie, nepredpokladam, ze sa bude testovat CD verzia a SACD verzia hybridneho disku. Na uskutocnenie takehoto testu je potrebne stiahnut DVD-A, spravit kvalitny downsample a primiesat do povodneho zdroja medzi ostatne tracky).
Predpokladam, ze debata bude zaujimava |
Roman St Hifi expert
Zaslal: So apríl 14, 2012 10:50:56 Predmet: |
Report k tomuto testu je k dispozici zde http://drewdaniels.com/audible.pdf Možná bychom mohli některé hypotézy, proč tak test dopadl, odhadnout. |
Zaslal: So apríl 14, 2012 11:07:10 Predmet: |
Cituji výsledek:
The test results for the detectability of the 16/44.1 loop
on SACD/DVD-A playback were the same as chance:
49.82%. There were 554 trials and 276 correct answers
To je ta statistika, kterou pořád tlačím do slepých testů. Ostatní aspekty, jako technické provedení testu, použité komponenty atd lze nekonečně rozebírat a zpochybňovat. Klíčové je ale to statistické vyhodnocení. _________________ Cui bono ? |
Zaslal: So apríl 14, 2012 11:28:33 Predmet: |
To je známý článek. Jako vždy, tak platí, že výsledky popsaného testu jsou platné jen a jen pro popsaný test, jeho metodiku, jeho konkrétní podmínky, jeho HW atd. Výsledky testu nejsou přenositelné na jiné podmínky ani jinou metodiku. Totéž bude platit pro test VB + OPA.
Než hledat po netu, doporučuji si dělat vlastní názor. Autem se taky nenaučíš jezdit čtením příruček, ale musíš najezdit pořádnou porci kilometrů, abys něco o autě věděl (jeho chování v reálných situacích) a v autě uměl. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: So apríl 14, 2012 13:37:20 Predmet: |
PMA: Vždycky lze diskutovat o správnosti použité metodiky, kvalitě komponentů, zkušenosti posluchačů etc.
Ale v obecné rovině cílem správně provedeného testu je získat výsledky, které mají širší platnost, než právě jen pouze pro dané místo čas a okolnosti.
Do jaké míry se podaří tento cíl splnit, je zase věc názoru.
Postoj z principu odmítající jakoukoliv objektivizaci v oblasti "věrné reprodukce zvuku" není rozumný, odporuje obecné lidské zkušenosti. _________________ Cui bono ? |
Zaslal: So apríl 14, 2012 14:53:27 Predmet: |
opa napísal: |
To je ta statistika, kterou pořád tlačím do slepých testů. Ostatní aspekty, jako technické provedení testu, použité komponenty atd lze nekonečně rozebírat a zpochybňovat. Klíčové je ale to statistické vyhodnocení. |
Souhlasím, klíčová je statistika a slepý test. Do toho se ale mnoho hifistů asi nepohrne . |
Zaslal: So apríl 14, 2012 14:58:26 Predmet: |
PMA napísal: |
Než hledat po netu, doporučuji si dělat vlastní názor. Autem se taky nenaučíš jezdit čtením příruček, ale musíš najezdit pořádnou porci kilometrů, abys něco o autě věděl (jeho chování v reálných situacích) a v autě uměl. |
No to by mě opravdu nenapadlo . Mimochodem, zajímají mě relativně ověřené informace, což se u členů AES dá jakž takž předpokládat. Nicméně imho ten test metodicky nepovažuji za objetivní, ale spíše účelový. |
ravenman Hifista - zaslúžilec
Založený: 28 február 2009 Príspevky: 875 Bydlisko: Martin
Zaslal: Pi marec 29, 2013 09:20:21 Predmet: |
Pre mňa absolútne nevýpovedné tie testy, nutnosť zachovať masteringové štúdio a technikov ktorí spravia z hlavného mastru CD a SACD verziu a potom porovnať. Predsa hlavným prínosom SACD je priniesť vyššie rozlíšenie a ked to to technicky dobre adaptuje tak to musí zákonite byť o niečo lepšie ako CD.
CD audio považujem ako vcelku podarený formát ,ktorí určite dokáže zaznamenať muziku v plnej kráse, len i tam treba kvalitné vydavatelstvo typu Chesky Records či Verve a výsledky sú fantastické. Samozrejme kotučáky sú a vždy budú REFERENCE _________________ Raspberry Pi 4 (Arch Linux MPD) ▶ Hiface EVO ▶ BB-DAC 24/192 ▶ BB Superclock ▶ SANSUI AU 907MR ▶ Custom RG214 ▶ ISOPHON VERTIGO ▶ JA:) |
