Hlava Hifi expert
Zaslal: Ne december 23, 2007 12:46:40 Predmet: Yamaha S2000 ... retro jak má být? |
Svým vzhledem mě zaujala nová (?) kombinace SACD/zes od Yamahy s označením S2000 ...
Mi osobně přijde ten design moc povedený, podlouhé době něco netradičního, co nevypadá jak tuctová plastová škatule, k dispozici v černé nebo stříbrné variantě, vzhledem k hmotnostem 15 a 23 kg se dá očekávat snad i solidní provedení. Ceny 33.190,- a 41.800,-
A co zvuk, slyšeli jste to někdo? |
Kuba4 Hifi inventar
Zaslal: Ne december 23, 2007 13:13:06 Predmet: |
Taky jsem toho všiml. Další krok správným směrem. Nejsem příznivcem staromilství, ale všechny ty AVR X.X mi už lezou krkem. |
587sk Hifista
Založený: 19 december 2006 Príspevky: 161
Zaslal: Ne december 23, 2007 14:37:40 Predmet: |
YAMAHA: Many music friends look back wistfully to the stereo era when amplifiers had only two channels and listening to records was as much a part of the evening ritual as a glass of red wine and a good book. The A-S2000 amplifier gives you back this experience. Just touching the solid handles brings back memories of the Yamaha legends of the seventies. The aluminium front and wood-finished sides reflect the quality of workmanship that made good HiFi sets the status symbol of a whole generation.
But when it comes down to the interior of this high-quality housing, Yamaha has gone off in a completely new direction: a revolutionary circuitry concept with completely balanced alignment from the input until just before the loudspeaker clamps exploits analog amplifier technology to the full. Professional recording studios have long been providing interference free sound by using balanced transmission, the A-S2000 gives it a signal-to-noise ratio of 98 dB. Because conventional volume and tone controls do not function accurately enough in such a finely bal-anced environment, the A-S2000 uses a total of three circuits per channel. The required precision in the signal path can only be achieved in this way. Only components of the highest quality are used, these include powerful trans-formers, extra heavy feet and selected blocking capacitors with 24,000 microfarad each. In addition, the use of independent amplifier units for the right and left channel ensure maximum channel separation. |
Franta Hifista
Založený: 15 október 2006 Príspevky: 206
Zaslal: Ne december 23, 2007 19:59:27 Predmet: |
Tak vidíte, že nejsme v tom postižení sami. Už se to zase obrací i ke klasickému stereu. A ta symetrická koncepce může být velmi zajímavá, zvlášť, když mám s Yamahou vyzkoušenu jednu značku reproduktorů, kdy to opravdu exceluje. |
Franta Hifista
Zaslal: Ne december 23, 2007 20:00:29 Predmet: |
587sk Hifista
Zaslal: Ne december 23, 2007 20:28:27 Predmet: |
Načo tie tajnosti, prezraď. |
Kuba4 Hifi inventar
Zaslal: Po december 24, 2007 14:29:11 Predmet: |
Jsou i v černé.
Zaslal: Po december 24, 2007 14:51:36 Predmet: |
černá je lepší... _________________ Omluvte mé hloupé otázky, jsem jen zvídavý tetřev hlušec. |
seas Hifi expert
Zaslal: Po december 24, 2007 17:56:42 Predmet: |
Pfizer Spolu UA forum
Naposledy upravil seas dňa Pi december 23, 2022 23:58:55, celkom upravené 1 krát. |
587sk Hifista
Zaslal: So január 19, 2008 14:31:24 Predmet: |
Test Audio.de |
ferenc Hifi expert
Zaslal: So január 19, 2008 14:51:19 Predmet: |
ja len dodam ze v tom audiu je ten test trosku obsiahlejsi a zaroven test tychto istych komponentov sa nachadza aj v aktualnom cisle stereoplay, co je nemecky casopis z toho isteho vydavatelstva ako audio. |
seas Hifi expert
Zaslal: St apríl 30, 2008 20:25:17 Predmet: |
Naposledy upravil seas dňa Št december 29, 2022 23:12:02, celkom upravené 1 krát. |
Timerobber Banned
Zaslal: St apríl 30, 2008 21:10:44 Predmet: |
Naposledy upravil Timerobber dňa So marec 28, 2009 20:22:32, celkom upravené 1 krát. |
Mih Hifista - pokročilec
Založený: 08 december 2006 Príspevky: 346 Bydlisko: Pribram
Zaslal: Št máj 01, 2008 07:46:12 Predmet: |
I když nerad (vzhledově je to povedená sestava) musím konstatovat - nehraje to dobře. Vzhledem k ceně a slušnému vybavení to hraje asi jako zesík do 10t. |
Kuba4 Hifi inventar
Zaslal: Ne júl 06, 2008 14:02:06 Predmet: |
A co téměř na polovinu levnější série 1000?
Zesík A-S1000
a
CD přehrávač CD-S1000
ja-kub Hifista - zaslúžilec
Založený: 30 december 2007 Príspevky: 507 Bydlisko: Dolný Kubín
Zaslal: Po júl 14, 2008 17:14:24 Predmet: |
komponenty velmi pekné SACD sa mi velmi páči, ale zosik by som si kupil iny a tým pádom to stráca zmysel si kupovať len 1 komponent... |
korys Hifista
Založený: 12 február 2008 Príspevky: 137 Bydlisko: ČR Ostrava
Zaslal: Po júl 14, 2008 21:33:57 Predmet: |
seas napísal: | http://www.highfidelity.pl/artykuly/0805/yamaha.html
pokud to někdo shrne do tří vět v češtině budu rád |
Těžký úkol,ale pokus: Dospěle znějící systém s univerzálním použitím,nehrající sice jak o hodně dražší sestavy,ale ne že by něco výrazně chybělo.Velmi solidní(vyvážený)zvuk.V porovnání s jinými ve stejné ceně, hutný s výbornýma vyškama a hlubokým basem,ale ten s menší definicí.Tolik Poláci. _________________ USHER V-601,DENON PMA1500AE,Marantz CD-67SE,KimberKablePBJ,2x4PR
Tak oblečtě si dresy... |
J Hifi expert
Založený: 24 september 2007 Príspevky: 1350 Bydlisko: Bratislava
Zaslal: Ne jún 07, 2009 11:07:58 Predmet: |
Nedávno som si všimol že je v predaji aj rada 700 - dizajn viac-menej ten istý, ale bez "bočníc" a bohužial aj bez SACD (bez toho sa dá žiť), ale zato je to už relatívne zaplatitelnejšej cenovej úrovni.
Niečo podrobnejšie a linky tu:
http://www.hifinazory.cz/forum/viewtopic.php?f=2&t=2738 |
man.earth Hifista - pokročilec
Založený: 02 február 2009 Príspevky: 277 Bydlisko: Bratislava
Zaslal: Ne marec 07, 2010 16:41:22 Predmet: yamaha as-1000, cds-1000 |
obnovym tuto diskusiu...je krasne napisat, ze tie Yamahy hraju v cenovej relacii 10t byvalych korun... Osobne som pocuval 1000ky na svojich repro a porovnaval s yamahou zosikom 497, ktory je za tych cca 9000 byvalych korun, a nebudme smiesny, 1000ka hra transparentne, priestorovo, cisto, s detailnymi vyskami a velmi hlbokym basom, ktory je makky ale stale vyborny a uvolneny. Cd player som neporovnaval, hrala vzdy 1000ka. _________________ SCAN SPEAK 26W+SEAS W18NX+SCAN SPEAK 2904/9800 DIY 3 WAY |
Stug Nádejný hifista
Založený: 21 júl 2009 Príspevky: 71
Zaslal: Ne marec 07, 2010 20:22:20 Predmet: |
citácia: | I když nerad (vzhledově je to povedená sestava) musím konstatovat - nehraje to dobře. Vzhledem k ceně a slušnému vybavení to hraje asi jako zesík do 10t. |
Prepáč Mih ale mne suché konštatovanie " nehraje to dobře" proste nestačí.
Ak nevieš popísať čo presne ti vadí na AS1000 napíš aspoň tri zosíky
ktoré hrajú lepšie, ešte sa stále vyrábajú a predávajú ich do 1050,- eur??? |
Zaslal: Pi marec 26, 2010 20:36:49 Predmet: |
Ná niekto skúsenosť (alebo počul ho hrať vie to porovnať) so zosíkom Yamaha AS 1000 alebo CD playerom Yamaha CD-S 700? |
