gucino Hifista
Založený: 18 máj 2011 Príspevky: 194 Bydlisko: Čachtice
Zaslal: Ne marec 18, 2012 13:31:16 Predmet: Paradigm monitor 7 v. 5 |
Predám troj ročné stĺpové repro,komplet balenie,super stav,450 eur,alebo výmena za regálovky(stojany potešia)
Specifications
Design: 4-driver, 2-1/2-way bass reflex,quasi-3rd-order resistive port, MagneShield
Crossover(s): 3rd-order electro-acoustic at 2.0 kHz, 2nd-order electro-acoustic at 700 Hz (lower bass drivers)
High-Frequency Driver(s): 25-mm (1 in) H-PTD dome,ferro-fluid cooled
Bass / Midrange Driver(s): 140-mm (5-1/2 in) M-ICP cone,25-mm (1 in) voice coil, GRIP chassis
Bass Driver(s): Two 140-mm (5-1/2 in) carbon-infused polypropylene cones, 25-mm (1 in) voice coils, GRIP chassis
Low-Frequency Extension: 41 Hz (DIN)
Frequency Response On-Axis: ±2 dB from 54 Hz - 20 kHz
Frequency Response 30° Off-Axis: ±2 dB from 54 Hz - 15 kHz
Sensitivity - Room / Anechoic: 94 dB / 91 dB
Suitable Amplifier Power Range: 15 - 180 watts
Maximum Input Power†: 130 watts
Impedance: Compatible with 8 ohms
Internal Volume: 25.7 L / 0.90 cu ft
Height, Width, Depth: 93.8 cm x 16.5 cm x 29.8 cm (36-15/16 in x 6-1/2 in x 11-3/4 in)
Weight (Unpacked): 33.6 kg / 74 lb per pair
Finishes: Cherry, Rosenut, Black Ash
5.02 KB |
5684 Time(s) |
46.1 KB |
262 Time(s) |
gucino Hifista
Zaslal: Št marec 22, 2012 10:13:55 Predmet: |
| 430+dohoda/vymena
gucino Hifista
Zaslal: Pi marec 23, 2012 16:24:27 Predmet: |
| 420+dohoda/vymena
AveMaria32 Hifi obsluha
Založený: 22 marec 2012 Príspevky: 16
Zaslal: So marec 24, 2012 06:34:22 Predmet: reprobedne |
| Sú ešte aktualne. Marián
gucino Hifista
Zaslal: So marec 24, 2012 10:47:42 Predmet: |
| Aktualne
gucino Hifista
Zaslal: Ut marec 27, 2012 07:48:57 Predmet: |
400 + dohoda / výmena za integrovaný zosik s do +/- doplatok,alebo sub VELODYNE CHT 10q
Naposledy upravil gucino dňa St marec 28, 2012 12:02:05, celkom upravené 1 krát. |
Zaslal: Ut marec 27, 2012 16:26:30 Predmet: repro |
| Dobrý deň, pýtal som sa na zvuk vážnej hudby, ako sú na tom repro.Ďakujem. Marián.
gucino Hifista
Zaslal: So apríl 14, 2012 16:55:58 Predmet: |
| Aktuálne-výmena za regalovky
gucino Hifista
Zaslal: Št apríl 19, 2012 10:51:09 Predmet: |
| Aktuálne
gucino Hifista
Zaslal: St máj 02, 2012 12:11:02 Predmet: |
350 eur+dohoda
Pri kúpe s receiverom akai aa 1050,spolu za 500
Naposledy upravil gucino dňa Št máj 10, 2012 15:28:08, celkom upravené 1 krát. |
gucino Hifista
Zaslal: Pi máj 11, 2012 09:18:42 Predmet: |
Koniec predaja,bedne dedí brat
bobi Cinan
Založený: 11 máj 2012 Príspevky: 2
Zaslal: Pi máj 11, 2012 09:41:41 Predmet: |
http://x.vu/253584
Wow, to 8GB MD-MS01 mashimaro štýl je tak roztomilý.
nikdy som nevidel tak krásny a krásne reproduktor.
