audio_holic Hifi obsluha
Založený: 15 august 2011 Príspevky: 38
Zaslal: Ut december 04, 2012 12:48:04 Predmet: FS: High quality PCB board for amplifier power supply |
Due canceled project, I have a larger quantity of high quality bare PCB amplifier power supply boards available. Dimensions are 83x108 mm. 105 um thick copper traces. It supports dual rectification per channel, optional snubber filter, CRC filter. Maximum capacitor diameter is 30 mm.
Price for board is 10 EUR + post costs.
Email: moonaudio (at) gmail.com
147.88 KB |
225 Time(s) |
Zaslal: Ut december 04, 2012 13:38:19 Predmet: |
Would you mind posting schematics?
Thanks,
Pavel
Zaslal: Ut december 04, 2012 14:57:23 Predmet: |
| PMA napísal: | Would you mind posting schematics?
I don`t see a need for such a simple circuit like this. More important thing is ground laying, which in this case is done as it should be.
Some recommendations: Diodes D1-D8 should be TO 220 case diodes of your choose. I have a larger quantity of NXP (Philips) BYW29E-200 too. R1&R2 could be either short circuit or MPC71 0.22 ohm. Optional snubber circuit (R3-C5; R4-C6) consist of 1 ohm resistor MPC71 and 100 nF MKT cap.
Zaslal: Pi december 07, 2012 02:05:24 Predmet: |
Bottom:
97.75 KB |
183 Time(s) |
Zaslal: St január 30, 2013 12:50:36 Predmet: |
| Still available...
Zaslal: Pi apríl 12, 2013 17:50:21 Predmet: |
Few pcbs still left.
New reduced price: 6 EUR / each pcb
contact: moonaudio (at) gmail.com
Zaslal: Št máj 16, 2013 11:43:19 Predmet: |
| Still available...
