NO TOTO!
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Resampling, upsampling, komprimacia zvuku
moses
Založený: 17 november 2012
PríspevokZaslal: Pi december 16, 2016 21:46:10    Predmet: NO TOTO! Odpovedať s citátom
http://tech.sme.sk/c/20411702/pocuvate-hudbu-v-mp3-budete-menej-stastni.html
Nepocuvaju tu poniektori iba komprimovanu hudbu??? Rotfl
moses
PríspevokZaslal: Pi december 16, 2016 21:48:20    Predmet: Odpovedať s citátom
Tu este pridavam cele dielo:
http://www.aes.org/tmpFiles/elib/20161216/18523.pdf
bacil2
Založený: 29 marec 2013
PríspevokZaslal: So december 17, 2016 02:09:37    Predmet: Odpovedať s citátom
http://www.innerfidelity.com/content/paper-review-effects-mp3-compression-perceived-emotional-characteristics-musical-instruments#POprOKqVq6ompVCh.97
Suchý ňúter mokrý ven
želáme vám dobrý den
PríspevokZaslal: So december 17, 2016 04:51:50    Predmet: Odpovedať s citátom
hej, ale odpoved na zasadnu otazku si sem nedal:
Compressed sounds were encoded and decoded using the LAME MP3 encoder [49]. Instrument sounds were compressed with three different bit rates. As a preliminary step, we listened to the sounds compressed at different bit rates and judged that 112 Kbps sounds were the lowest bit rate that sounded nearly indistinguishable from the original sounds. Sounds at 32 Kbps had obvious artifacts. We selected 56 Kbps as an intermediate bit rate, representing medium quality between indistinguishable and obvious artifacts (i.e., some artifacts). Though theseparticular bit rates may not be as common in practice, they are representative of the basic levels of compression. These three bit rates also gavenear-perfect (for32Kbps),intermediate(for56Kbps), and near-random (for 112 Kbps) discrimination results in a previous discrimination study of these MP3-compressed musical instrument sounds [40], meaning listeners in that study could nearly always notice a difference between the original sound and a 32 Kbps compression, sometime notice a difference for 56 Kbps, and were unable to reliably notice a difference for 112 Kbps.
Vyskum jak repa...
moses
PríspevokZaslal: So december 17, 2016 07:26:54    Predmet: Odpovedať s citátom
Inak pre vacsiu objektivnost mohli pouzit aj ine bitrate-y a enkodery...
RedBaron
Založený: 30 apríl 2015
PríspevokZaslal: So december 17, 2016 10:20:25    Predmet: Odpovedať s citátom
U čehokoli pod 192kbps zní výšky jako šustění papírem od sekaný, ale pravdou je, že rozdíl mezi kvalitní 320kbps a flacem už jsou jen nuance v nejnáročnějších pasážích. Pokud je kvalitní nahrávka, 320kbps MP3 rozhodně neodrazuje od vychutnání hudby, alespoň já to tak mám.
PítrsPraha
Založený: 20 august 2014
PríspevokZaslal: So december 17, 2016 11:06:09    Predmet: Odpovedať s citátom
Souhlasím, mám to stejně.
Pořád platí, že alfou a omegou je kvalitní původní záznam a mastering. Umím si celkem bez uzardění představit, že dobře udělaná mp3 320 kbps vytvořená ze špičkové nahrávky zní zásadně líp než CD s průměrnou či mizernou nahrávkou.
tatko Tom
Založený: 21 február 2016
PríspevokZaslal: So december 17, 2016 11:38:50    Predmet: Odpovedať s citátom
192kbps wma(2) tiež v pohode, myslím.
moses
PríspevokZaslal: So december 17, 2016 11:45:31    Predmet: Odpovedať s citátom
Ja pouzivam v mobile 320kbs LAME robene z CD cez dBpoweramp a je to uplna pohoda. Von aj tak netreba nic lepsie .
Pridať novú tému   Zaslať odpoveď    Obsah fóra hifi.slovanet.sk -> Resampling, upsampling, komprimacia zvuku Časy uvádzané v GMT + 1 hodina
