ALEX Hifista - pokročilec
Založený: 30 október 2006 Príspevky: 386
Zaslal: Št február 01, 2007 12:10:31 Predmet: návrh na voodoo roku |
xxxxx
Naposledy upravil ALEX dňa Po október 21, 2013 16:21:29, celkom upravené 1 krát. |
vladimir Hifi obsluha
Založený: 14 január 2007 Príspevky: 1
Zaslal: Št február 01, 2007 13:05:11 Predmet: |
Ta stránka je celá dobrá
mě se líbí toto:
http://www.acoustic-revive.com/english/rd3/rd3_01.html
citácia: |
The effects on DVD and Laser Disc
The RD-3 has also remarkable effects on DVD and Laser Disc.
Picture quality: The RD-3 removes flicker noise leaving clearer and shaper image. A brighter color becomes brighter, a darker color becomes darker, so the contrast of the image becomes clear and more vivid. In addition, each single color becomes more extremely vivid, especially red. Moreover, the natural tone of the human skin is superb.
Sound quality:The RD-3 improves audio quality, and increases the level of surround separation and dynamics. You are able to listen to detailed sounds that you never heard before and the human voice is more realistic.
Lepší barvy, kontrast v MPEG-2 videu, a surround separation. Geniální. |
ferenc Hifi expert
Zaslal: Št február 01, 2007 13:35:39 Predmet: |
staci sa pozriet k napoleonkovi, teraz stavia ten slavny filter ...
ludi ktori sa do toho vyznaju posiela studovat ...
alebo ta chujovina so zulovou doskou na cd playeri ... |
Zaslal: Št február 01, 2007 14:26:51 Predmet: druhý kandidát na voodoo roku. |
drevený nábytok Torlyte len za 1500 libier UK
http://www.russandrews.com/category.asp?lookup=1®ion=UK¤cy=GBP&customer_id=PAA0160027407036RHICLDUWPJHWLQGT&cat_id=Pnewtor
www.russandrews.com
všetko znie lepšie.
Torlyte has an original and functional beauty all of its own. Made from wood, the unique contruction of Torlyte offers a clean, extended, tuneful bass, a more realistic mid-range especially on voices, less 'splash' and more information in the treble, and improvements in the three-dimensional stereo image. The front-to-back depth snaps into focus, the recording acoustic becomes much easier to discern and those subtle, mysterios sounds made by the musicians can be identified with ease. |
MSW Hifista - zaslúžilec
Zaslal: Št február 15, 2007 13:03:22 Predmet: |
Voodoo roku je přeci Mundorf, je jasné, nic jiného to být nemůže. _________________ Nothing is best |
Skipy stepná kengura
velky bobo Big Audio Druid
Zaslal: Št február 15, 2007 21:05:01 Predmet: |
Naprosto bezkonkureční voodoo všech epoch byl TUBISTOR - škoda, že upadl v zapomnění. _________________ Nemám nic proti hifi, vadí mi jen hifisti. Ale technokraty taky zrovna nemiluju.
http://www.kvakeri.cz/ |
philo Hifista
Založený: 30 október 2006 Príspevky: 122
Zaslal: Št február 15, 2007 23:44:25 Predmet: |
The tubistor is a device which incorporates features of both electron tubes and solid state devices such as a transistor and includes extremely close spacing between the multiple conducting elements of the device. The tubistor comprises a section of an oxide-metal composite that has been ion milled to produce inverted cones in the oxide with the emitting metal fibers at the bottom. A conducting layer deposited on the insulating layer surface forms a type of grid. A collector or anode disposed above the grid collects electrons emitted from the emitter when the appropriate potentials are applied to the device.
je to ono? _________________ len sa neunáliť |
philo Hifista
Zaslal: Št február 15, 2007 23:54:41 Predmet: |
tubistor asi neupadol tak celkom do zabudnutia
http://www.ampzilla2000.de/e_son_of_a2k.htm
Audio Asylum Thread Printer... as the transistor...he called it the "tubistor"...it turned out that this device was nothing more than a transistor dipped into some magic potion. ... _________________ len sa neunáliť |
Zaslal: Pi február 16, 2007 01:49:01 Predmet: |
To, co jsem měl na mysli, odpovídá spíš té druhé variantě - narazil jsem totiž kdysi na jakýsi list, ve kterém se nabízalo předělání jakéhokoli zařízení na tubistory s tím, že se firmě pošle příslušné zařízení (třeba i CD přehrávač - na integrované obvody to funguje taky), oni s ním něco udělají, vyinkasují cca 400 dolarů a vrátí ho proměněné s tím, že se ani nenaruší záruční podmínky, tj. že ani nepovolí šroubky. Ale zvuk se zázračně zlepší.
philo Hifista
AlienCZ N/A
Založený: 30 november 2006 Príspevky: 928 Bydlisko: Brno - venkov
Zaslal: Pi február 16, 2007 08:50:22 Predmet: |
Chlopi, kde je Vaše příslovečná odvaha, nejvyšším kandidátem na Voodoo roku je přece naše: forum _________________ Lyngdorf, Lyngdorf, Lyngdorf ... a pak už nic, hraje to. |
coffee Hifi expert
Zaslal: Pi február 16, 2007 14:13:42 Predmet: |
Naposledy upravil coffee dňa Pi jún 04, 2010 21:22:37, celkom upravené 1 krát. |
AlienCZ N/A
Zaslal: Pi február 16, 2007 14:30:34 Predmet: |
coffee napísal: | myslíš spíš století ne? |
Na to je ještě brzy, jsme teprve v sedmém roku století, za 93 let se může objevit ještě něco lepšího. Sázím se, že nás s Maritnem někdo určo trumfne. _________________ Lyngdorf, Lyngdorf, Lyngdorf ... a pak už nic, hraje to. |
Zaslal: Pi február 16, 2007 14:39:42 Predmet: |
-ako môže byť fórum voodoo???
-to snáď niektoré príspevky vo svojom konkrétnom obsahu - to áno - ale celé fórum??? Veď to je len platforma...
Alebo mi niečo ušlo? |
suK Hifista - pokročilec
Založený: 16 október 2006 Príspevky: 259 Bydlisko: Plzeň
Zaslal: Pi február 16, 2007 15:00:59 Predmet: |
Skipy napísal: | -ako môže byť fórum voodoo??? |
Myslím, že to přirovnání funguje velmi dobře:
Voodoo je považováno za kult či náboženství.
Má své šamany, rituály, své dobré a špatné stránky.
A když se šamanovi někdo znelíbí, udělá z něj zombie.
Ale abych také přispěl, můj návrh na "voodoo" roku je Energy saver případně na západě oblíbený Atomizer - nástroj, který odfiltruje z elektrické sítě elektřinu z atomových elektráren. |
Pucmeloud Hifi obsluha
Založený: 08 február 2007 Príspevky: 19 Bydlisko: Rožnov p.Radh.
Zaslal: Ne február 18, 2007 12:41:49 Predmet: |
No jsou-li "Alien" a "Martin" tytéž identity, co dříve erudovaně radily na diskusi časopisu Stere&Video a taky tady, tak je to jasné... |
moses Hifi expert
Založený: 17 november 2012 Príspevky: 1907
Zaslal: Ut október 04, 2022 15:32:54 Predmet: |
Trosku to tu ozivim
https://www.youtube.com/watch?v=mH4v8b1tGSQ
Je to sice "iba" RD-1 ale predpokladm, ze oproti verzii RD-3 bude rozdiel minimalny _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
