Zaslal: Št február 09, 2023 15:15:12 Predmet: |
Ale tatko, mluv spisovně, do riti _________________ Das ganze tschechische Volk ist eine Simulantenbande ! |
tatko Tom Hifi expert
Založený: 21 február 2016 Príspevky: 2994 Bydlisko: Prievidza
Zaslal: Št február 09, 2023 18:28:10 Predmet: |
Nemám prečo svoj post upraviť a nie len skrz spisovnosť hoci ostal zdanlivo mimo kontext - keď svoje príspevky upravil niekto iný. _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
ZbynekB Hifi obsluha
Založený: 16 máj 2009 Príspevky: 32
Zaslal: Št február 09, 2023 18:44:37 Predmet: ja |
Ano příspěvek jsem upravil aby někoho nepohoršoval a já se nenechal urážet od
nějakého truhlíka z horní dolní |
Založený: 21 november 2007 Príspevky: 12859
Zaslal: Pi marec 03, 2023 09:40:05 Predmet: |
"To znamená, že generál Mráz neodvedl svou práci,"
Spalovanim "prebytocneho" plynu minuly rok Mrazovi pracu neulahcili...
citácia: | Meanwhile, there is growing concern over a Russian gas flare, which has been burning close to the Finnish border for two months. Experts say it’s burning an estimated $10 million worth of gas every day, sending the equivalent of 9,000 tons of carbon dioxide into the atmosphere. |
Zdroj: https://www.voanews.com/a/russia-shuts-key-pipeline-burns-off-gas-as-west-accuses-putin-of-weaponizing-energy-/6727221.html
A tazko odhadnut, kolko metanu este pri tom uniklo...
citácia: | In addition to the CO2 the flare is releasing into the atmosphere, it is also likely damaging the environment in other ways.
Davis said that the flaring would likely be producing soot which is particularly destructive to the Arctic region. Much of the soot will end up on Arctic ice and absorb more heat from the sun, accelerating the melting of ice.
“Almost certainly, the flare is not operating with 100% efficiency, and so it’s also emitting methane which is 80 times more potent as a greenhouse gas than carbon dioxide,” Davis said. |
Zdroj: https://edition.cnn.com/2022/08/26/energy/russia-burning-natural-gas/index.html |
cubic Hifi obsluha
Založený: 24 marec 2016 Príspevky: 15 Bydlisko: HK
Zaslal: Ut marec 07, 2023 18:52:48 Predmet: |
cubic - koľko nôh máš dostrieľaných? Všetkých osem?
Pod ruskou bagandžou by si tak akurád držžal pič...-hubu. O čo Ti ide, že sem grcáš sračky?
Páľ s tým do velebnej píííííípči!!! _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
janik1971 Hifi expert
cubic Hifi obsluha
Zaslal: Ut marec 07, 2023 22:15:50 Predmet: |
Tatko - trafena hus zagagala?
To, ze nase vlady bezhlavo opakuju hluposti, ktore prijimaju USA a EU, je grcanie sraciek?
Vlada vymeni lacny a overeny zdroj plynu za plyn, ktory nie je vyskusany ani nijako overeny. Az novinari musia povedat, po upozorneniach od ludi, ze to moze byt pre odberatelov nebezpecne. Bud to vlada vobec nevedela alebo sa na to vykaslala, vsak mozno sa nic nestane. Neviem, co je horsie.
Aky by to bol problem povedat ludom, rozhodli sme o prechode na iny plyn, ale ma to hacik, je potrebny filter, ktory zamedzi nebezpecenstvu vybuchu plynu alebo uduseniu sa plynom.
My vlada vam to zaplatime, lebo my sme rozhodli o zmene plynu.
O toto mi ide, vsetci prikyvujete, lebo zly Putin.
A pritom nam nase vlady seru na hlavy, im vobec nejde o dobro ludi.
Janik, Ty si genius |
godz Hifi expert
Zaslal: Ut marec 07, 2023 22:59:53 Predmet: |
Cubic, a to nevieš ako sa teraz predáva plyn? Spotová cena plynu je pod 43 dolárov za MWh. čo je rozhodne menej ako pýtajú Rusi. Apropo, Rusi majú pri predaji energonosičov v porovnaní z januárom 2022 deficit 12 mld dolárov. Ke´d zoberieš k tomu odhadované mesačné náklady na vedenie vojny cca 12 miliárd dolárov, tak to nebude len taká sranda rozchodiť. to. A ty považuješ za stabilný zdroj energie ten, ktorý ti prestane dodávať plyn pred a počas vykurovacej sezóny a vyšpikuje ceny do nebeských výšin - ďakujem neprosím ! |
Zaslal: St marec 08, 2023 07:40:11 Predmet: |
cubic napísal: | Tatko - trafena hus zagagala?
Prepac. Ja som si neuvedomil, ze tebe vlastne ide o blaho naroda ako takeho. A ,ze zmyslom tvojej registracie nie je vobec hejtovat. |
Zakk Hifista
Založený: 06 marec 2009 Príspevky: 248 Bydlisko: praha
Zaslal: Po marec 20, 2023 05:41:03 Predmet: |
Ked to tu teraz citam, tak sa mi chce vrhnout, co tu tatko kom píše, vyzera to že je mimo realitu.
Je zaujimave Kolko kokotou tu žije mezi námi. |
Zaslal: Po marec 20, 2023 06:22:44 Predmet: |
J Hifi expert
Založený: 24 september 2007 Príspevky: 1358 Bydlisko: Bratislava
Zaslal: Po marec 20, 2023 07:24:31 Predmet: |
Najnovšie mám problém ako sa baviť so setrou a jej odnožou famílie. Zdá sa že už sa celkom preklopili na stranu "chcimírovcov". Ono istý proruský sentiment tam bol vždy, ale tak nejak som dúfal že ako inteligentné, vzdelané a scestované bytosti po tom, čo uvidia zločiny tej lúpežníckej hordy sadistických a úchylných mužíkov trochu prehodnotia svoje zmýšlanie. Ale zdá sa že ich dezinfoscéna zomlela dokonale. A to mali neďaleko bydliska za bolševika ruskú posádku a videli čo sú zač a aký bordel po nich ostal. Toto mi naozaj hlava neberie.
Každopádne sa mi darí zatial vyhýbať citlivým témam, len neviem dokedy to pôjde. S našou mamou sa už stihla pochytiť. |
Zaslal: Po marec 20, 2023 08:08:50 Predmet: |
Vyhýbať sa debatám v ktorých sa nezhodnete pokiaľ je to len trochu možné. Názor nezmenia a zbytočne si pokazíte vzťahy. _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
Zaslal: Po marec 20, 2023 11:54:43 Predmet: |
Putin o Ukrajine v časovej postupnosti - stojí za pozretie, vypočutie:
https://www.facebook.com/alexander.kaduc/videos/1278893066199974/ _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
J Hifi expert
Zaslal: Po marec 20, 2023 13:39:48 Predmet: |
To je dobré! Pekné zhrnutie.
Na jednu stranu uznávam že človek môže zmeniť názor na niektoré veci na základe nových poznatkov, ale to nemá nič spoločné s touto ruSSko-dezolé scénou, kde si dokážu odporovať v jednej vete. A vôbec im nevadí že to vidí celý svet.
Najviac ma fascinujú naši náckovia - vedla obrázku Tisa, ktorý bol oficiálne vo vojne so Sovietskym zväzom, má obrázok putlera, ktorý sa netají zámermi obnoviť sovietske impérium. To je schiza ako autobus. |
Zaslal: Po marec 20, 2023 14:03:52 Predmet: |
Chybný predpoklad je, že myslia, nie to ešte analyticky uvažujú. Svet nie je čiernobiely ani jednoduchý - to sú tí, ktorý ho tak vnímajú. Niekedy tie reakcie nazývam odrazom od miechy. _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
J Hifi expert
Zaslal: Po marec 27, 2023 05:48:09 Predmet: |
tatko Tom napísal: | Vyhýbať sa debatám v ktorých sa nezhodnete pokiaľ je to len trochu možné. Názor nezmenia a zbytočne si pokazíte vzťahy. |
Hlásim že úloha splnená - mali sme na návšteve sestru so švagrom. Čosi sme pojedli, čosi popili a až na 2 - 3 švagrove poznámky prešlo všetko korektne a celkom fajn sme sa zabavili.
Zaujal ma ale jeden aspekt a to je to značné protirečenie si tejto skupiny ludí (v našich kruhoch hádzanej do jedného vreca a hanlivo, ale výstižne, označovaných ako dezolé).
V tomto prípade na jednu stranu nadávanie na Fica, Danka a podobné sociálno-národovecké "kleptokratické elity" s ktorými si ako pomerne vysokopostavený človek vo verejnej správe užil svoje a je si jasne vedomý toho že z ich úst iné ako klamstvá a manipulačné sračky nevylezie. Na druhú stranu, čo sa zahraničnej politiky týka, tak papagájuje rovnaké nezmysli ako oni a vôbec mu to nie je čudné.
To je podobné ako keď našej fašisticko-národnej úderke visia doma portréty Tisa, ktorý bol prezidentom republiky čo vyhlásila rusákom vojnu a nemajú pritom problém pobehovať s putinom na hrudi a kladivokosákovou vlajkou v rukách.
A takýchto príkladov rozpoltenosti by sa asi našlo ... |
Zaslal: Po marec 27, 2023 07:16:40 Predmet: |
Nič neobvyklé - väčšina ľudí sa poriadne neorientuje a neuvažujú v koplexných súvislostiach (360-stupňový pohľad). Sám som bol taký polku života.
K tomu nekazeniu si vzťahov - ja som si so sestrou pokazil, prežila väčšinu života v Rusku, pustila sa do mňa keďže vidí moje príspevky niekde že vraj nenávidím Rusov a som zblbnutý USA propagandou. Uzemnil som ju námietkou, či jej nie je ľúto štvrť milóna aj ruských mužov, ktorých niekto zabil alebo poslal na smrť. A k propagande som sa opýtal, či niekedy videla podobné "motivačné" video, vytvorené na tom zlom Západe: https://www.youtube.com/watch?v=_ISVnLVH-Xk
Ostalo ticho.
Tým naznačujem, že ľudia veria tomu, v čom každodenne žijú. Málokto hľadá pokial možno nezávislý pohľad. Vo všetkom. Mnohí hľadajú veľkého múdreho silného, ktorý bude rozhodovať za nich a vyrieši ich problémy. Vo všetkom _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
moses Hifi expert
Založený: 17 november 2012 Príspevky: 1907
Zaslal: Po marec 27, 2023 09:31:47 Predmet: |
Ja som mal teraz kvoli novorodencovi navstevu svokrovcov a co ma neprestava fascinovat je ich neustala potreba zacinat temy tykajuce sa ruSSka a obhajovat ich za kazdu cenu. Bavime sa o niecom a zrazu nasilu zacne svokor jebat sracky o ruSSakoch, pritom ani naznakom nebola ziadna zmienka o vojne...
Kedze su to svokrovci, tak sa to snazim vzdy nejako diplomaticky zakecat ale inak mi obcas z toho stupne tlak, ze by som im najradsej povedal nech uz konecne drzia hubu. _________________ SET01: PC + CA DacMagic Plus + KRK Rokit 4 G3 SET02: NTB + Echo Indigo IOx + Beyerdynamic DT 831 SET03: HTPC + ASUS Xonar STX + Bryston BP4 + Behringer TRUTH B3030A SET04: MP + AudioQuest Dragonfly Black + Sennheiser HD 25-C II |
J Hifi expert
Zaslal: Št marec 30, 2023 08:14:41 Predmet: |
Som si práve prečítal:
K Matovicovej 500E za ucast vo volbach, by mal Sulik podat pozmenujuci navrh a to:
500E by sa nevyplatilo volicovi, ale sa poslalo na transparentny ucet, z ktoreho by sa hradilo dalsie vyzbrojovanie Ukrajiny + humanitarna pomoc pre Ukrajinu.
Za to by sa dalo zahlasovat, nie?
To by mohlo krásne znížiť počet dezolé pri urnách a hneď by bola väčšia šanca na nejakú príčetnejšiu vládu. |
Zaslal: Št marec 30, 2023 09:22:09 Predmet: |
Ako mu to navrhnúť?
Rusku sa výnimočne darí, ani sankcie mu neškodia, ale pomáhajú.
Len taká maličkosť - centrálna banka Ruskej federácie vykázala rekordnú stratu 722 miliárd rubľov. _________________ AKAI AM-69, AKAI CD-62, Thorens TD 115, Philips 70fs363, Topping D10s, UMM380 "TLU"
Zaslal: Št marec 30, 2023 12:54:15 Predmet: |
"Moskva oznámila, že zařadila Maďarsko mezi nepřátelské země"
Chá chá!
Kde jsou ty časy, kdy jsme tam byli jenom my a Amíci... _________________ www.at-horns.eu | "ATH - the best waveguide designs possible" - Earl Geddes |
J Hifi expert
Zaslal: Št marec 30, 2023 13:12:19 Predmet: |
Chudák Orbi - nikto ho už nemá rád.
Zaslal: Št marec 30, 2023 13:16:40 Predmet: |
To už je osud kolaborantů... _________________ www.at-horns.eu | "ATH - the best waveguide designs possible" - Earl Geddes |
