ES9038PRO SABRE DAC
Henri
Založený: 30 marec 2015
PríspevokZaslal: St január 27, 2016 15:37:44    Predmet: ES9038PRO SABRE DAC Odpovedať s citátom
ESS PRO SABRE 32-bit, 8-channel DAC chip goes the extra mile by offering the industry's highest dynamic range (DNR) of 140dB with an impressive THD+N at -122dB.
ako vidno nahanačka za čislami pokračue...
nemate niekto datasheet/ funkčný link ? ESS zvolilo tu istu taktiku ako pri predchadzajucich modeloch Evil or Very Mad
PríspevokZaslal: St január 27, 2016 15:45:11    Predmet: Odpovedať s citátom
Nieco uz tu bolo, resp. bolo by dobre nazvat povodnu temu rozumnejsie:
- http://hifi.slovanet.sk/bb/viewtopic.php?t=21998
PríspevokZaslal: St január 27, 2016 15:52:30    Predmet: Odpovedať s citátom
Inak datasheet ti snad aj poslu ak im posles podpisanu NDA. Ale nemam.
PríspevokZaslal: St január 27, 2016 17:10:25    Predmet: Odpovedať s citátom
"For the record, release of the final datasheet and samples from ESS have pushed out to the end of March"
Zdroj: http://www.diyaudio.com/forums/twisted-pear/284924-will-there-buffalo-iv-es9038pro-sabre-dac-2.html#post4596719
Zatial to teda vyzera ako reklama pre investorov :)
PríspevokZaslal: Ut júl 12, 2016 13:08:14    Predmet: Odpovedať s citátom
SABRE ISSUES
An intriguing side issue was brought up by Strand-Bergesen when he was explaining why he chose the AKM DAC chip to sit inside his chassis. One of the DACs under consideration was the current DAC flavour of the month, the ESS Sabre. Unlike many manufacturers out there, though, Strand-Bergesen rejected the Sabre out of hand, he believes that the design of this DAC is fundamentally flawed, “It’s riddled with maths trouble. The digital maths is disappointing. It will overflow internal registers, chopping up and generating a lot of output edges. It sounds distorted around the treble area. With a high power amp, it could kill the treble. I have a friend of mine who has access to the in-house data sheets of the Sabre. He actually has a work-around for it. Well, for the 9012 and 9018 chip models. Although on the 9022 and 9023, you cannot initiate the work-around because there are no pins to access the internal registers and bypass this problem.”
Zdroj: http://www.theaudiophileman.com/#!henry-audio-dac/cdcr
PríspevokZaslal: Ut júl 12, 2016 13:10:50    Predmet: Odpovedať s citátom
Je niekde na nete viac informacii o tomto workaround? Nejak som nic nenasiel/nezaregistroval...
PríspevokZaslal: Ut júl 12, 2016 23:41:05    Predmet: Odpovedať s citátom
Resp. ci to suvisi s tymto co minule pisal Henri, alebo ci je to este nieco ine:
Henri napísal:
ES 9018S , ktorý však podľa mňa mierne dopláca na firemnú koncepciu “all in one“, pri dosiahnutí maximálneho zvukového výkonu , čo sa prejavuje určitou zvukovou sterilitou t.j. slabším podaním najnižšieho frekvenčného pásma a na opačnom konci spektra nie najčistejším podaním transientov a témbrom.Podľa tohto merania ES 9018S https://www.youtube.com/watch?v=2QySxRcuPJs
Bol zistený určitý problém s jeho analógovým výstupom pri rozlíšení nad 20bitov a zhoršením presnosti a linearity na vyšších vzorkovacích frekvenciách ako 48 kHz. Našťastie sa to dá eliminovať externým oversamplingom, čo zlepšuje rozlíšenie, znižuje šum a pomáha vyhnúť sa aliasingu a fázovému skresleniu.
Zdroj: http://hifi.slovanet.sk/bb/viewtopic.php?p=251440#251440
Zorg
Založený: 13 september 2008
PríspevokZaslal: St júl 13, 2016 09:23:45    Predmet: Odpovedať s citátom
Miero, kdyby sis nad tím chtěl udělat multikanálovýho DACana, tak 2 tyhle chipy bych doma uživil, tak se kdyžtak přidám k projektu Cool
PríspevokZaslal: St júl 13, 2016 09:47:37    Predmet: Odpovedať s citátom
Jeden uz mam doma niekolko rokov -- http://twistedpearaudio.com/digital/buffalo8.aspx
PríspevokZaslal: St júl 13, 2016 09:50:22    Predmet: Odpovedať s citátom
Ale toto by ta mohlo viac zaujimat: http://hifi.slovanet.sk/bb/viewtopic.php?t=19354
Henri
PríspevokZaslal: St júl 13, 2016 11:01:27    Predmet: Odpovedať s citátom
Henri napísal:
nie je to presne o 9018, ale mrkni si to
http://www.6moons.com/audioreviews2/henry/1.html
"In your first iterations of the DAC, you employed an ESS Sabre chip. The new DAC has gone with a different chip. Why?
"ESS don't make their products available through typical electronic parts distributors. Getting them in low volumes was a big hassle. But what made me choose another chip was the discovery of an internal math bug in the ES9022/9023. A >-1.3dB full-scale square wave played through their chip will generate great amounts of distortion. With modern compressed music, that isn't just a theoretical occurrence. I worked many years with signal conditioning and was able to see what goes on. In technical terms, the internal FIR filter does a 2's complement overflow where a very positive number actually flips around and becomes a very negative number. This occurs before the sigma-delta modulator. A digital limiter or lower gain in the FIR would solve this."
PríspevokZaslal: St júl 13, 2016 11:16:50    Predmet: Odpovedať s citátom
Aha jasne, tak o tomto probleme viem. Diky.
IMHO, korektne to nejde vyriesit ani znizenim hlasitostiv prevodniku. Standardne filtre ES9018 maju 0.5dB rezervu. Benchmark pouziva dokonca rezervu 3.5dB, ako sa pise v application notes na ich strankach.
Alternativa, ktorou to smerujem ja je resampling na 384kHz a brickwall filter 22kHz na PC a potom prehravanie na DACi s vypnutym oversamplingom.
Henri
PríspevokZaslal: St júl 13, 2016 11:44:20    Predmet: Odpovedať s citátom
ano presne tak : obísť a povypinať v čipe všektko čo sa da. Rotfl
Ešte zopar citacií z Diplomovej práce o Es9018 Pavla Krásenskeho :
„Precizní analogové rozhraní pro zpracování zvuku“ http://mtt.ieee.cz/studentska-soutez/soutez2015/Precizni%20analogove%20rozhrani%20pro%20zpracovani%20zvuku.pdf
autor piše : „... musíme podrobněji podívat na princip funkce - D/A převodníku. Po průchodu modulátorem je digitální signál teprve převeden na analogový pomocí fyzických prvků tvořících na čipu zdroje proudu s různou velikostí. Tento proces je velmi citlivý na hodnoty prvků na čipu, avšak výrobní procesy mají vždy své tolerance, které by vlastnosti převodníku degradovaly. Proto se využívá algoritmu DEM, který jednotlivé prvky (bity) v určité posloupnosti střídá, aby nedocházelo při určitých výstupních stavech ke vzniku namodulovaného šumu (korelovaného s užitečným signálem) v úzkých špičkách s velkou amplitudou. Cílem algoritmů DEM je zabránit vzniku modulovaných šumových špiček ve slyšitelném spektru a pokud možno přesunout jejich energii nad slyšitelné spektrum a frekvenčně je rozprostřít. Aby algoritmus DEM plně zachoval vlastnost noise-shapingu použitého - modulátoru, měl by být dle [22] alespoň stejného řádu jako modulátor samotný, což však zřejmě žádný z výrobců - D/A čipů nedělá, protože by to bylo realizačně neúměrně složité. Činnost DEM je tudíž více či méně kompromisní.......Pod touto úrovní stačí pouze nejméně významový bit převodníku (LSB), nad ní se začínají používat i ostatní bity. Právě tento přechod zřejmě není dost dobře ošetřen a algoritmus DEM není schopen zakrýt vzniklou chybu. Na jednotlivých kanálech se problém pravděpodobně projevuje s různou mírou z důvodu výrobních rozdílných odchylek od ideální (navržené) hodnoty proudu, kterou daný prvek generuje. Z grafu 3.2.2.9 a tabulky 3.2.2.1 vidíme, že amplituda integrovaného THD+N dosáhne až 8 µV v nejvíce problematickém kanálu a okamžiku. Proč se pak amplituda tohoto nežádoucího signálu při dalším zvyšování amplitudy užitečného signálu snižuje, když bychom čekali, že zůstane konstantní, nebo se bude dále zvyšovat, se mi osvětlit nepodařilo.
Ma tam tam vystižne grafi merani artefaktov ES 9018 , piše: „THD+N (tedy odstup všech integrovaných rušivých složek od základní frekvence) jednotlivých kanálů liší, a to v rozsahu -113,7dB (kanál 1) až po -116dB (kanál 2). THD+N ostatních kanálů leží v tomto intervalu...THD+N (tedy odstup všech integrovaných rušivých složek od základní frekvence) jednotlivých kanálů liší, a to v rozsahu -113,7dB (kanál 1) až po -116dB (kanál 2). THD+N ostatních kanálů leží v tomto intervalu. Zároveň však bylo změřeno, že šum všech kanálů bez přítomnosti výstupního signálu je téměř totožný, a to asi 1,6µVRMS. Celkové harmonické zkreslení THD (odstup integrované amplitudy všech násobků základní frekvence) se také neliší a je rovno asi -124dB při plné výstupní amplitudě (asi 1,61V) a frekvenci 1kHz. Je tedy zřejmé, že velikost tohoto šumu je závislá na amplitudě výstupního signálu. Zjevně nepochází z analogových součástek na desce, ale ze samotného D/A převodníku a souvisí s činností jeho modulátoru.
Na tento jev jsem se zaměřil v další sérii měření a zdokumentoval jsem jeho závislost na velikosti amplitudy (obrázky 3.2.2.4 až 3.2.2.7). Do následující tabulky jsou vyneseny naměřené hodnoty THD+N, ze kterých byla spočítána ...“
merania autor zhrnie: „Z uvedených měření vyplývá, že D/A čip ES9018S není tak bezchybný, jak jej výrobce popisuje a také trpí podobnými neduhy jako - převodníky jiných výrobců (modulace šumového pozadí)...
a nazaver ho ešte pochvalil Wink
Naposledy upravil Henri dňa St júl 13, 2016 19:07:43, celkom upravené 2 krát.
Zorg
PríspevokZaslal: St júl 13, 2016 11:59:40    Predmet: Odpovedať s citátom
Myslíte, že tím budou trpět i nové "38" chipy?
Henri
PríspevokZaslal: St júl 13, 2016 12:23:29    Predmet: Odpovedať s citátom
Zorg napísal:
myslim, ze nie a navyše ES9038 maju uplne prekopane registre Cool
chcelo by to datasheet bez registracie Sad
PríspevokZaslal: St júl 13, 2016 12:32:40    Predmet: Odpovedať s citátom
Mozno tie registre budu aspon trochu podobne ES9018-K2M -- verejny kod pre neho je tuto https://hifiduino.wordpress.com/code/
PríspevokZaslal: St júl 13, 2016 12:33:54    Predmet: Odpovedať s citátom
Inak zda sa, ze ES9018S ma nedokumentovany konfiguracny bit, ktory znizuje gain modulatoru o cely bit, co je uz ale celkom dost -- http://www.diyaudio.com/forums/digital-line-level/117238-ess-sabre-reference-dac-8-channel-18.html#post1492166
Zorg
PríspevokZaslal: St júl 13, 2016 12:36:07    Predmet: Odpovedať s citátom
Tak kdo se hlásí, že jim napíše o vzorky třicet osmiček? Twisted Evil
Ještě poznámka po přečtení, jak amplifire předělával finální desku na 4 vrstvou kvůli zlepšení parametrů, tak si pamatuju na diskuzi lidí od Oppa, kdy říkali, že Sabre zapojený jen 2 kanálově má lepší parametry než při využití všech 8 kanálů. A myslím, že v jejich top modelu to takhle vyřešené je - jeden čip pro stereo a druhý pro mulitkanál. Ale souvislosti mi samozřejmě unikají.
Henri
PríspevokZaslal: St júl 13, 2016 13:35:03    Predmet: Odpovedať s citátom
Zorg napísal:
Jeje Thumbs up na diyaudio fore su neskutočne vlakna o tuningu Oppo prehravačov a vysledky su velmi slušne,
Ked so videl bastlersku 3D montaž od “Corisa“, skoro som sa počural od smiechu a padol pod stol Laughing
http://www.diyaudio.com/forums/digital-line-level/196474-ess9018-try-new-try-more.html
ale chlapci našli finty (okrem už spominaneho ) na Es 9018 : super čiste napajanie , ine hodiny
a menej strmy vystupny filter tzv. „rasmussen-effect“
http://www.diyaudio.com/forums/lounge/249418-dac-filtering-rasmussen-effect.html
http://www.customanalogue.com/
PríspevokZaslal: St júl 13, 2016 13:43:55    Predmet: Odpovedať s citátom
Zorg: ten ES9018 umoznuje pouzit i vsetkych 8 vystupnych kanalov na jeden kanal, a potom potrebujes na stereo dva cipy. ESS vsade mozne uvadza parametre prave i pre tento mono rezim.
Ma to tak napriklad DAC: http://www.accuphase.com/model/dc-901.html
PríspevokZaslal: St júl 13, 2016 13:45:14    Predmet: Odpovedať s citátom
A pri pouziti toho „rasmussen-effect“ bezi DAC v napatovom, ci prudovom rezime? :-)
PríspevokZaslal: St júl 13, 2016 13:56:17    Predmet: Odpovedať s citátom
Zorg: si myslis, ze bude take jednoduche navrhnut 8 kanalovy DAC? :-)
Ale cital som, ze ten ES9038Pro ma byt pinovo kompatibilny s ES9018S, a tak by to mohlo ist ladit s tym starym. Ten sa da zohnat "lacno" na aliexprese od $50 pri kupe dvoch kusov.
Henri
PríspevokZaslal: St júl 13, 2016 14:12:35    Predmet: Odpovedať s citátom
-s velkou pravdepodobnosťou nebude, pripadne treba kontaktovať “Dohnalika“ –podielal sa na novom komerčnom projekte s ES9038PRO
http://www.audioweb.cz/viewtopic.php?pid=326736#p326736
-je tam žial len pinova kompabilita
ad „rasmussen-effect“ zrejme v napetovom, ale už si nepametam. ved ak ta to zaujima tak si prezri Idea
Zorg
PríspevokZaslal: St júl 13, 2016 14:33:08    Predmet: Odpovedať s citátom
Shocked Shocked Dohnalík jede!!! :smekacísmajlík: Zkusím ho kontaktovat.
miero: no já myslel, že když už existuje taková deska viz ta diplomka, že by se to jen přizpůsobilo.
Co vlastně to tvoje Bufallo? Myslím, že jsem zaslech nějaká pomlouvačná slova na jeho adresu, ale už si nevzpomínám proč a co by tam mělo být špatně udělané. Ale třeba to byli jen zlí jazykové...
Btw, doma mám teď dvě desky CurrymanDACu, kde je použitej 9023 - jak se to liší oproti "18"? (ani nevím, jak moc "korektně" je to udělaný, fakt tomuhle prdlajz rozumím)
PríspevokZaslal: St júl 13, 2016 14:36:31    Predmet: Odpovedať s citátom
http://www.twistedpearaudio.com/digital/buffalose.aspx
http://www.twistedpearaudio.com/forum/topics/19-Buffalo-DAC
Henri
PríspevokZaslal: St júl 13, 2016 15:10:10    Predmet: Odpovedať s citátom
Zorg napísal:
-Es 9023 je zrejme najproblemovejši: vid odkaz čo som daval hore (oscilacie, nestabilita parametrov) a bol to zrejme aj jeden z dovodov revizie Odacu. http://blog.jdslabs.com/?p=1003
ad Bufallo : na diyaudio som videl dosť ostre vymeny nazorov medzi autormi a nespokojnymi zakaznikmi : neopravene problemy na doskach, nedodržanie terminov atd. bolo to davnejšie-
Miro zaregistroval si niečo ?
PríspevokZaslal: St júl 13, 2016 15:20:09    Predmet: Odpovedať s citátom
Moje Buffalo3 stale buffaluje. Su to fajn modulky, ked sa s tym chces hrat a po zostaveni vznikaju z toho rozne 3D struktury.
U mna boli problemy so zdrojmi od TPA, ci uz tie hlavne ale i tie lokalne pre Buffalo. Napriklad to u mna veselo oscilovalo, ale tie "zaciatocnicke" problemy su uz v sucasnych verziach myslim vychytane.
Myslim ze TPA bolo jedno z prvych co mali DAC s ES9018 a domnievam sa, ze i teraz usilovne pracuju na tom, aby to bolo tak i s novymi cipmi.
No neviem ci by som to doporucil ludom, co to chcu rychlo postavit a uz na to viac nesahat. Ale hrat to urcite bude, no je mozne, ze za podobne peniaze sa teraz uz da najst i nejaky DAC od schopnejsieho cinana.
BTW: a som zaujaty, kvoli praci na BBB som od TPA som dostal nejaky ich HW zdarma.
Henri
PríspevokZaslal: St júl 13, 2016 15:34:31    Predmet: Odpovedať s citátom
ano Buffalo je vyborny detektor VF rušenia, najme z kablov Wink
-pre tych menej informovanych : Miro sa hanbi sam pochvaliť- je totiž autorom vybornych ovladačov Thumbs up
PríspevokZaslal: St júl 13, 2016 15:51:28    Predmet: Odpovedať s citátom
Njn vlastne, prijem SPDIF mi pri pouziti konverznych modulkov vypadaval pri pri vypinani kompresoru chladnicka, obcas i svetla v chladnicke. Pri priamom zapojeni Toslink prijimaca do Buffala mi to nerobi.
Vybornych ovladacov neviem, nieco to robi - i 8 kanal PCM a 4 kanal DSD. Skor mam radost z toho, ze to nakoniec zvlada 352.8/384kHz i DSD512 aj ked je to uz mimo specifikovanych parametrov procesora na BBB a ide to pouzit na obidenie oversampling filtra na ES9018.
A vlastne som zbastlil i ALSA ovladac pre ES9018. Zatial to nevie nahravat vlastne FIR filtre, ale inak to funguje slusne.
Zorg
PríspevokZaslal: St júl 13, 2016 17:05:30    Predmet: Odpovedať s citátom
To znamená co? Jakože tomu podstrčím FIR ála DSP a ono to změní adekvátně výstupní cháru?
