Malá návštěva u Audio Precision
Roman St
PríspevokZaslal: So marec 29, 2008 12:32:45    Predmet: Malá návštěva u Audio Precision Odpovedať s citátom
Možná by někoho z vás zajímalo jak vypadá a co říká člověk, který v AP pracuje velmi dlouho a adjustuje či kalibruje výrobky.
Neznáte-li firmu AP, tak vězte, že se jedná o špičku v měřící technice pro audio a video.
Rozhovor je převzat z jejich emailového News.
Well Adjusted
Tom Williams interviews AP’s Service Supervisor John Payne as he performs a Factory Adjust on a SYS-2712 audio analyzer. John has been with AP almost since the company began in 1984. There is very little he doesn’t know about audio analyzers.
Q: Why should AP customers get an adjustment?
The short answer is more accurate measurements. All high precision instruments drift to some degree: we have to send our scopes and other equipment out to Tek and Agilent to get adjusted, and it’s the same for AP gear. We also install ECOs when the instrument is back at the Factory, so in fact, you can end up with an instrument that’s even better than before.
Q: What do the ECOs do?
The Engineers are constantly working on ways to improve performance, even on older instrument families, plus certain components go End of Life, and we need to find alternatives. Engineering Change Orders let the Service Department know what updates to install on analyzers when they come in for service.
Q: How often should a customer get an adjustment?
We generally recommend getting your instrument Factory Adjusted once a year. Of course, if your Performance Check is telling you something is wrong, send it in sooner.
Q: How long does a typical adjustment take?
It depends on the instrument, but several hours at least. A SYS-2722 has at least 50 adjustment points that each need to be measured and tweaked, plus the time it takes to install any outstanding ECOs.
Q: What’s the difference between an Adjustment and a Calibration?
Adjustment is the process of restoring optimum instrument performance by resetting internal electrical components and stored software constants to correct for the inevitable effects of aging and drift. But you don't get all the documentation of certified Accredited Calibration with an Adjustment.
For a Calibration, we put the instrument through our ISO:17025 A2LA-accredited Cal Lab so you get documented and traceable verification in the form of an official Certificate of Calibration and an accompanying Performance Report.
Adjustment does not imply Calibration and Calibration does not necessarily require adjustment; however some instruments will require adjustment before passing Calibration.
The Calibration Services page of the website has more info.
What's on John's bench
Agilent 3440A Multimeter
Agilent 53131A Frequency Counter
Tektronix 3032B Oscilloscope
Coilcraft Tweak tool
Better than spec’d
AP instruments have the best performance of any T&M gear in the industry, and often our specs are more demanding than the instruments we use to adjust your AP analyzers.
To accommodate variances in the instruments on our benches, each technician’s voltmeter and oscilloscope are characterized in our Calibration Lab so the tiniest variations in each instrument can be accounted for in our Factory Adjustments.
Q: Why don’t customers adjust their own instruments?
There are lots of reasons, but basically it comes down to time, expertise, and equipment. We get a lot of units sent to us by independent Calibration Houses who have no idea how to adjust our analyzers. They’re complicated instruments. We also have some software that we’ve developed in-house over the years that speeds up the process. The other big consideration is that if a repair is necessary, it saves the customer a lot of time if the instrument is here already. We can just repair it and get back on the customer’s bench where it belongs.
Q: What should customers do before they send in their units?
Call us first! Customers have to get a RMA before sending in their units. Other than that, we recommend running a Performance Check before sending in your unit. It gives our technicians an idea of where to look if there are any issues, and it gives the customer a reference of the state of the instrument before it was shipped.
Q: Thank you for your time John. Any last comments?
There is more hand-selection of parts for the 2700 than I’ve ever seen in my 35 years of electronics. It’s truly a hand-crafted instrument.
AP's Service Supervisor John Payne at his bench
John Payne with his trusty Coilcraft tweak tool and voltmeter characterization table
kuki
Založený: 12 máj 2008
PríspevokZaslal: Po jún 16, 2008 22:17:10    Predmet: Vďaka za článok:-) Odpovedať s citátom
pracuješ taktiež s AP? potreboval by som prístroj (je to starší typ) na kalibráciu kotúčových magnetofónov (stereo typ) bez digital, vyslovene na analog techniku. vedel by si mi pomocť kde by som to zohnal a kolko by to stálo? Ten typ na fotke je Audio precision System One, pravdepodobne konfigurácia 322G (ale nie som si istý, lebo je tam aj floppy mechanika). Vdaka za info a za príspevok.
music forever
Roman St
PríspevokZaslal: Ut jún 17, 2008 07:03:27    Predmet: Odpovedať s citátom
Mám starší AP One. Použité AP lze koupit nejlépe v USA, tam jich je nejvíce a vzhledem ke kurzu je to ideální. AP One je stále vynikající jako generátor signálu, jako analyzátor je možné použít i daleko levnější a lepší stroje (karty). Nabídka použitých je např. zde: http://www.used-line.com/cgi-bin/equipment/audioprecision.cfm?ds=34&p_n=1
kuki
PríspevokZaslal: Ut jún 17, 2008 09:18:18    Predmet: Vdaka za odpoved Odpovedať s citátom
music forever
Naposledy upravil kuki dňa St december 23, 2009 00:50:24, celkom upravené 1 krát.
gabik
Založený: 26 november 2007
PríspevokZaslal: Ut jún 17, 2008 10:03:30    Predmet: Odpovedať s citátom
Jenom dopnim - ECO znamena Engineering Change Order, termin pouzivany zejmena v USA. ECO znamena normlani zmenu (v protypu, hotovem vyrobku, beta verzi, apod.).
Roman St
PríspevokZaslal: Ut jún 17, 2008 11:06:12    Predmet: Odpovedať s citátom
Co všechno se skrývá za pojmem kalibrace koučového magnetofonu ?
Roman St
PríspevokZaslal: So jún 28, 2008 08:38:58    Predmet: Odpovedať s citátom
Od 1.1. 2009 již nebude Audio Precision poskytovat servis na systémy AP One.
Roman St
PríspevokZaslal: Pi október 23, 2009 07:36:08    Predmet: Odpovedať s citátom
Hello Roman,
now that everyone is back from AES, I’d like to share the latest “first” we introduced at the show: a 1 MHz FFT with 24-bit A/D resolution and less than 2.5 Hz bin width.
No one has been able to look at out-of-band noise with this level of clarity before. And it’s noisy out there. With more Class D amps than ever going into designs, I can’t think of a more useful addition to an audio engineer’s tool kit.
The customers I spoke with agreed, as did the press: we were honored to receive the PAR Excellence Award from Pro Audio Review for this work on FFT analysis.
It wasn’t all ultra-high bandwidth analysis though. The cake and champagne of our 25th Anniversary celebration earned some attention too.
Bruce
Out-of-band noise is a significant issue for designers of Class-D, converters and other modern audio devices. The new APx BW52 ultra-high bandwidth option provides unprecedented detail with full 1 MHz bandwidth, 24-bit A/D resolution, and less than 2.5 Hz bin width. This latest achievement marks AP’s 25th anniversary as the recognized standard in audio test.
Class D amplifiers, switching power supplies, and D/A converters all produce spurious signals well outside of the 100 kHz bandwidth limit of most audio analyzers. These out-of band switching spikes, along with their harmonics and intermodulation products, can wreak havoc on audio gear and adjacent equipment. Audio signals combined with this noise can cause even more problems.
Noise that is reflected into the audible range will directly degrade the sound. Noise that remains above the audible range can also degrade the sound by causing problems such as oscillation, overheating and damage to components, loss of headroom, and interference with connected or adjacent equipment.
The new BW52 Ultra-high Bandwidth option for the APx525 family extends the APx’s FFT capability all the way to 1 MHz, with 24-bit A/D resolution, making APx ideal for looking at out-of-band noise in Class-D amplifiers, sigma-delta converters, and other modern audio devices.
By comparison, other audio analyzers have a maximum high-resolution FFT bandwidth of 100 kHz or less, making them unsuitable for looking at switching frequencies that often center around 300–500 kHz. RF spectrum analyzers can have much wider bandwidth, but their low impedance, low resolution, and low tolerance to high input levels make them unsuitable for audio design.
http://ap.com/products/apx/bw52
http://ap.com/display/file/423
PríspevokZaslal: Pi október 23, 2009 08:14:52    Predmet: Odpovedať s citátom
Roman St napísal:
Hello Roman,
Skvělá zpráva.
Sendy
Založený: 29 november 2008
PríspevokZaslal: Pi október 23, 2009 22:27:59    Predmet: Odpovedať s citátom
V poslední době jsem se vrhnul na probádání informací k Systemu One. Celkem mne překvapilo, jak AP mají precizně propracovanou koncepci, spousta věcí je řešena nadčasově. Zmíněný Sys One se udržel ve výrobním programu od roku 1985 do roku 2002 (samozřejmě jednotlivé bloky byly v průběhu let inovovány, existuje např. 5-6 verzí od každého modulu), samozřejmě se vyvíjel i obslužný soft - tyhle přístroje potřebují master PC pro ovládání.
Jelikož výroba byla skončena, a před časem uťali i podporu, je na webu kompletní servisní dokumentace včetně schémat na celou sérii System One, což by mohlo některé z nás, Vláďo Smile třeba zajímat, jak to dělali jinde. Je to 56MB pdf, přístupné po registraci. Pokud by někoho zajímala další špionáž, daly by se detaily některých přístrojů staršího data i vyfotit Wink .
PríspevokZaslal: So október 24, 2009 01:38:24    Predmet: Odpovedať s citátom
No to si piš, že mě to zajímá!
Už to sosám...
Sendy
PríspevokZaslal: So október 24, 2009 19:45:59    Predmet: Odpovedať s citátom
Mám pocit, že Vláďa pilně studuje Very Happy .
Pokud by náhodou chtěl někdo postavit desku DSP optionu, jednu bych si taky rád zamluvil Smile
PríspevokZaslal: Ne október 25, 2009 08:37:25    Predmet: Odpovedať s citátom
Je to spíš ze zvědavosti, rozhodně nebudu stavět nic komplexního. Jde spíš o vychytání drobných detailů, inspiraci. Dvě podstatné informace jsou už delší dobu k dispozici v podobě patentů.
PríspevokZaslal: Ne október 25, 2009 08:52:49    Predmet: Odpovedať s citátom
Použiješ trafo?
PríspevokZaslal: Ne október 25, 2009 09:15:03    Predmet: Odpovedať s citátom
Použiješ trafo?
Vidím, že máš dobrý přehled. Thumb up
Druhý patent je rejekční filtr.
Ale s tím trafem je to v rovině zájmu o zajímavé řešení. Kromě zapojení by muselo být k dispozici opravdu kvalitní signálové trafo. Zatím se mi jeví jako dostupnější řešení symetrický vstup měřicí karty a galvanicky oddělený zdroj signálu (externí D/A převodník).
Sendy
PríspevokZaslal: Ne október 25, 2009 12:39:05    Predmet: Odpovedať s citátom
Doufám, že fotografie potěšila. Mne kdosi před časem mystifikoval, že AP má toroidní trafa, navíc dvě u dvoukanálu, a zatím je tam jen jedno a navíc vypadá jak vypadá Wink . Jestli chceš, podívám se na tenhle detail i do Portable, ten je novější generace.
BTW, kdysi jsem potkal rack s 8x DI trafy firmy Canford, chlubili se tenkrát (1995) tím, že ty trafa jsou stejné kvality, jako užívá AP. Ten osmi DI stál tenkrát televizi 96K bez daně Sad
Sendy
PríspevokZaslal: St november 18, 2009 23:25:30    Predmet: Odpovedať s citátom
Není mezi náma někdo, kdo vlastní (používá) SYS322 ?
Roman St
PríspevokZaslal: St november 25, 2009 09:28:14    Predmet: Square wave Odpovedať s citátom
Nový generátor a analyzátor od AP. Text s grafy jsem rozkouskoval, aby to všechno nebylo v jenom příspěvku, ale jde o souvislou část z posledních news.
Naposledy upravil Roman St dňa St november 25, 2009 09:30:41, celkom upravené 1 krát.
Roman St
PríspevokZaslal: St november 25, 2009 09:28:47    Predmet: Odpovedať s citátom
část 2
Roman St
PríspevokZaslal: St november 25, 2009 09:29:10    Predmet: Odpovedať s citátom
část 3
Roman St
PríspevokZaslal: St november 25, 2009 09:29:35    Predmet: Odpovedať s citátom
část 4
Roman St
PríspevokZaslal: St november 25, 2009 09:30:02    Predmet: Odpovedať s citátom
závěr.
PríspevokZaslal: St november 25, 2009 19:36:31    Predmet: Odpovedať s citátom
Jsou to krásné hračky. Nezlobil bych se, mít to na stole. Ale zrovna na ten obdélník se dá kouknout dobrým osciloskopem taky.
Mnohem důležitější je rozšíření FFT k 1MHz. Tm se dějí věci... (Viz DVD Panasonic..) Crying or Very sad
Roman St
PríspevokZaslal: Ne apríl 25, 2010 20:00:01    Predmet: Odpovedať s citátom
Ahoj všichni. Možná jste si všimli, že jsem poslední měsíce moc nechodím. Velmi mě to mrzí, ani nevíte jak, Crying or Very sad . Začátkem února mě dostihly jisté zdravotní potíže, které mě degradovaly zejména psychicky a čekal jsem (a stále čekám) až zmizí, izoloval jsem se, neměl jsem ani sílu. Je to ovšem chybné jednání, ale vysvětlujte to postiženému, de facto zatím v šoku. Mnoho lidí tyto potíže zvládá, mě se to ovšem daří velmi pomalu. Stále věřím v uzdravení, ale zároveň se začínám učit tím žít. Souvisí to se sluchem a budete-li chtít napíšu to sem otevřeně.
Omlouvám se za netechnický příspěvek, ale moje zmizení jsem považoval za vhodné objasnit. Mějte se krásně.
Roman
JC
Založený: 02 február 2007
PríspevokZaslal: Ne apríl 25, 2010 20:16:43    Predmet: Odpovedať s citátom
Roman:
Želám veľa síl a skoré uzdravenie!
PríspevokZaslal: Ne apríl 25, 2010 21:37:20    Predmet: Odpovedať s citátom
Taktéž se připojuju...drž se...
PríspevokZaslal: Ne apríl 25, 2010 22:00:51    Predmet: Odpovedať s citátom
Držím palce! A určitě je nás víc...
dhfool
Založený: 26 december 2006
PríspevokZaslal: Ne apríl 25, 2010 22:16:21    Predmet: Odpovedať s citátom
Ať všechno dobře dopadne. Držím pěsti.
AlesK
Založený: 31 január 2007
PríspevokZaslal: Ne apríl 25, 2010 22:27:19    Predmet: Odpovedať s citátom
Věř a víra tvá tě uzdraví, nevzdávej to a bojuj!!! Držím palce...
tomtom
PríspevokZaslal: Ne apríl 25, 2010 22:40:48    Predmet: Odpovedať s citátom
Trapi ta tinitus? Pytam sa lebo mam s tym problem. Drzim palce!
