Sony STR-DE435 Surround Receiver
Tonci20
Založený: 14 december 2010
PríspevokZaslal: Ut december 14, 2010 12:55:11    Predmet: Sony STR-DE435 Surround Receiver Odpovedať s citátom
Sony STR DE435 - AV receiver - 5.1 channel specifications
* General
* Product Type AV receiver
* Dimensions (WxDxH) / Weight AV receiver : 17.0 in x 14.5 in x 6.3 in / 20.1 lbs
* Width 17.0 in
* Depth 14.5 in
* Height 6.3 in
* Weight 20.1 lbs
* Enclosure Color Black
* Enclosure Material Plastic , Metal
* Audio System
* Sound Output Mode Surround Sound
* Built-in Decoders Dolby Digital , Dolby Pro Logic , DTS decoder
* Surround Sound Effects Virtual Dolby Surround , Digital Cinema Sound Virtual 3D
* Digital Sound Processor (DSP) Yes
* DSP Preset Qty 9.0
* Surround System Class 5.1 channel
* Output Channel Qty 5.0
* Output Power / Total 400.0 Watt
* Total Harmonic Distortion 0.09 %
* Amplifier Output Details 100.0 Watt - 8.0 Ohm - THD 0.8 % - 2.0 channel(s) ( Rear ) , 100.0 Watt - 8.0 Ohm - THD 0.8 % - 1.0 channel(s) ( Front ) , 100.0 Watt - 8.0 Ohm - THD 0.8 % - 2.0 channel(s) ( Center )
* Built-in Display Fluorescent
* Additional Features 4-ohm/8-ohm switch
* Radio
* Type Radio tuner - AM/FM - Digital
* Tuner Frequency Range FM: 87.5 - 108 MHz , AM: 530 - 1710 kHz
* Tuning Display Fluorescent display
* Preset Station Qty 30.0
* Response Bandwidth -14970.0 Hz
* Signal-To-Noise Ratio 70.0 dB
* Turntable
* Type None
* Cassette System
* Type None
* DVD
* Type None
* CD System
* Type None
* MD System
* MD system type None
* Headphones
* Headphones Type None
* Microphone
* Type None
* Remote Control
* Remote Control Universal remote control - Infrared
* Supported Devices DVD player , Satellite TV system , AV receiver
* Features Multi-brand compatibility
* Connections
* Connector Type 1.0 x Audio line-in ( RCA phono x 2 ) - Rear , 1.0 x Front speakers output ( RCA phono x 3 ) - Rear , 1.0 x Center speaker output ( RCA phono x 3 ) - Rear , 1.0 x SPDIF input ( RCA phono ) - Rear , 1.0 x Subwoofer output ( Banana x 2 ) - Rear , 2.0 x 5.1 channel audio line-in ( Banana x 2 ) - Rear , 2.0 x Headphones ( RCA phono x 6 ) - Front , 1.0 x Rear speakers output ( RCA phono ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 2 ) - Rear , 1.0 x Composite video/audio output - Rear , 3.0 x Audio line-out - Rear , 1.0 x SPDIF input - Rear
cena:100e
kontakt: 0915 134 774
