Anedio D1
knopi
Založený: 29 január 2008
PríspevokZaslal: St december 22, 2010 11:12:14    Predmet: Anedio D1 Odpovedať s citátom
pics by project86
Co na to řikáte?
Technicky netušim tomu nerozumim. ale vyúadá to moc hezky čistě precizně udělané.
Recenzi najdete tady škoda, že je to tak dlouhý, ale ten člověk má zkušenosti, pěkný systém, pěkný bedny, hodně sluchátek, píše to z nadšení a tak to má být.
Z té recenze mě přišlo taky docela zajímavý tenhle dotaz na konstruktéra:
During my very insightful exchanges with the designer, I asked him what he felt he would improve upon if he had an unlimited budget to work with. Here is his answer:
“As for the cost-no-objective design, our aim is to push the performance until we feel we have reached the point of diminishing returns, where adding more would not yield significant improvements. For the D1 DAC, we believe that we have reached such a point, but it’s more of a subjective judgment.
If we were to put more resources, it would probably be in two areas, but again, we believe that the resulting sonic improvement will be marginal:
— Use two ES9018S chips in dual mono configuration, one for each channel, for lower distortion and noise. In this mode, each channel will have 8 DACs connected in parallel (by comparison, the D1 DAC has 4 DACs in parallel per channel).
— Design a custom oscillator for the master clock for lower phase noise (jitter) and better power supply regulation. The master clock used in the D1 DAC is already of premium quality, a Crystek ultra low phase noise oscillator, so it’s not clear how much this will lower the jitter.
Personally, I know that my design will always remain a work in progress. Even if I’m not limited by resources, there will always be something to improve on. The power supplies are never perfect, the PCB layout is never perfect, and there is always something that escapes my comprehension. So the quest goes on.”
Naposledy upravil knopi dňa Ne december 23, 2012 23:12:04, celkom upravené 3 krát.
knopi
PríspevokZaslal: So december 25, 2010 10:12:59    Predmet: Odpovedať s citátom
Ani páni kontruktéři nic k obrázkům/konstrukci?
knopi
PríspevokZaslal: Pi jún 17, 2011 17:28:36    Predmet: Odpovedať s citátom
Velmi slušná informativní recenze na 6 převodníků tak ji sem šoupnu stereomojo takové články mají smysl. Nějakou dobu sleduju co se v zahraničí líbí a Eastern Electric Minimax a Anedio D1 jsou považované za top ve své kategorii. A když Eastern Electric v podstatě byl shodný vítěz testu kterého se zůčastnil i kvalitní studiový převodník Metric Halo, Lampizator tak to pravděpodobně nebudou žádná ořezávátka.
Zajímalo by mě jak by dopadl ten Eastern v konkurenci s našimi top převodníky BB a Sirius.
karfik
Založený: 21 december 2006
PríspevokZaslal: Pi jún 17, 2011 17:47:20    Predmet: Odpovedať s citátom
knopi napísal:
Všechny tyto převodníky jsou špičkové se špičkovým zvukem a rozhoduje již jen preference posluchače, zda se mu líbí zvuk takový či makový.
knopi
PríspevokZaslal: St august 03, 2011 07:33:28    Predmet: Odpovedať s citátom
Tohle taky nevypadá vůbec špatně metrum acoustics octave Embarassed
Jinak Anedio pracuje na nové verzi, snad by tam už neměly být ty modré diody a nebo pokud tam budou tak by měly jít vypnout, dále asynchronní přenos 24-192, také pracují na novém zdroji napájení a úpravy na desce budou.
palinoch
Založený: 29 december 2007
PríspevokZaslal: St august 03, 2011 13:43:11    Predmet: Odpovedať s citátom
No, ako pekne čreva.
knopi
PríspevokZaslal: St august 03, 2011 15:04:10    Predmet: Odpovedať s citátom
Nevim do jaké míry je 6moons věryhodný, ale srovnávaly tam ten Metrum Octave s francouským Totaldac Reference A1, který patří do té nejvýši kategorie minimálně cenově. Takže ten Octave vypadá taky, že by mohl být supr převodník za slušné peníze. Design skříně se jim, ale moc nepovedl v mých očích, no není to to nepodstatnější.
knopi
PríspevokZaslal: Pi október 07, 2011 15:07:26    Predmet: Odpovedať s citátom
Dobrý jak postupem času člověk ztrácí v něco důvěru teď už bych např. Anedio atd. (asi) nechtěl po tom co jsem se pár věcí dozvěděl.
Tak ať se posuneme dál. Nemá někdo zkušenosti s Metric Halo LIO-8? Osmi kanálový převodník s firewire. Dobře hodnocený, cena cca $4000.
Dále Berkley Alpha DAC asi nejpopulárnější převodník s AD1955 ve světě, cena cca $5000.
Ještě v téhle ceně velice dobře hodnocený Forssell a PS Audio Perfect Wave u nás jsou velice dobře známi jen zmiňuji.
Stále by mě zajímalo vím, že je to subjektivní, ale kéž by někdo opravdu testnul Sirius Synchro proti něčemu zmíněnému, tak jako tak jdu, ale do Casea..
Alpha
LIO-8 (lepší fotku jsem bohužel nenašel)
Naposledy upravil knopi dňa So marec 10, 2012 07:53:37, celkom upravené 3 krát.
karfik
PríspevokZaslal: Pi október 07, 2011 19:59:52    Predmet: Odpovedať s citátom
No to LIO bych vyřadil už jen kvůli použití NE5532 a 4580. To jsou v dnešní době zvukově nedostatečné OZ.
cestmir
Založený: 04 august 2011
PríspevokZaslal: Pi október 07, 2011 20:44:55    Predmet: Odpovedať s citátom
karfik napísal:
Nič v zlom, ale fakt by som ťa chcel zažiť, ako budeš v slepom teste preukazne odlišovať (správne zapojenú) NE553x od niektorej (momentálne audiofilmi uznávanej) OPA. Nehovorím o extrémoch, typu vstup prenoskového ampu, kde záleží na niektorej špecifickej vlastnosti, ale o bežnom zos./odd. stupni, kde to pracuje so zmysluplnými úrovňami a impedanciami.
Niekedy mám dojem, že celý súčasný "high-end" je čisto o autosugescii, placebe a ťahaní peňazí z naivných snobov. Racionalita tu ide komplet bokom.
palinoch
PríspevokZaslal: So október 08, 2011 07:20:48    Predmet: Odpovedať s citátom
cestmir, pekne si to napisal.
JC
Založený: 02 február 2007
PríspevokZaslal: So október 08, 2011 10:37:09    Predmet: Odpovedať s citátom
cestmir napísal:
Za slovkom súčasný by som si predstavoval už hodne rokov dozadu.
karfik
PríspevokZaslal: So október 08, 2011 21:26:35    Predmet: Odpovedať s citátom
cestmir napísal:
karfik napísal:
Česťo, až postavíš 20x externí DAC ve čtyřech verzích, otestuješ desítky operáků na pozicích I/U a výstupním filtru, jako já. Pak poznáš ve slepém testu, co hraje líp a co hůř. Samozřejmě ti neřeknu, jo teď tam hraje NE5532 a teď tam hraje AD797, ale rozhodně poznám, co je špatně a co je dobře. A v té skupině špatně bude určitě NE5532. Kór, když DAC bude používat třeba špičkový obvod jako je AD1955.
karfik
PríspevokZaslal: So október 08, 2011 21:30:11    Predmet: Odpovedať s citátom
cestmir napísal:
Ano, ve většině případů to tak opravdu je, bohužel.
babaudio
PríspevokZaslal: Ne október 09, 2011 14:59:40    Predmet: Odpovedať s citátom
dobrý, rýchly I/V je samozrejmá podmienka.
Zvuk z CD formátu robí upsampling.
Zatiaľ nepoznám nič lepšie ako SOX na usampling. Zabudnite na vstavané FIR filtre v DAC chipoch (v rátane ES9018).
karfik napísal:
cestmir napísal:
karfik napísal:
Smile Smile Smile
karfik
PríspevokZaslal: Po október 10, 2011 07:08:22    Predmet: Odpovedať s citátom
babaudio napísal:
karfik napísal:
cestmir napísal:
karfik napísal:
Smile Smile Smile
Ano, mohu potvrdit, po radách od Babaudia SOX používám také a je to krok správným směrem.
PríspevokZaslal: Po október 10, 2011 18:10:26    Predmet: Odpovedať s citátom
Jestli dobře rozumím, SOX je software pro PC. Takže nagrabuju CD, SOXem provedu upsampling a co dál ?
Přehrávat zvukovkou přímo z PC ?
Vypálit na DVD-Audio ?
cestmir
PríspevokZaslal: Po október 10, 2011 18:25:32    Predmet: Odpovedať s citátom
Obe alternatívy sú možné. Ak chceš real-time, použiješ SoX ako filter (plug-in) do Foobar-u a (resamplovaný) výstup necháš normálne streamovať na vhodný DAC, rovnako, ako keď prehrávaš hudbu bez filtra.
Ak chceš dávkovú konverziu, môžeš použiť tiež buď Foobar (dajú sa tam ukladať presety pre jednotlivé typy konverzií), alebo aj standalone volanie SoX-u cez shell (command-line). S uloženým výstupom môžeš následne robiť, čo potrebuješ, napr. napáliť.
cestmir
PríspevokZaslal: Po október 10, 2011 18:36:57    Predmet: Odpovedať s citátom
karfik napísal:
Ok, nebudem sa hádať s niekým, kto má tvrdo vydretú vlastnú skúsenosť. Ak máš tú vnútornú poctivosť, že môžeš (sám pre seba) s kľudným svedomím autosugesciu vylúčiť, tak môže byť.
Moja osobná skúsenosť je ale taká, že autosugesciu a placebo vylúči jedine poctivé slepé porovnávanie, nič iné. Žiadne, že vymením poistku (signálový koax, OZ, komponent, čokoľvek), pustím signál a "zreteľne tam počujem to zlepšenie", to sú tak neskutočné bullshity, že škoda reči. Pritom polovica debát v tomto fóre prebieha cca na tejto úrovni.
PríspevokZaslal: Po október 10, 2011 19:54:30    Predmet: Odpovedať s citátom
cestmir napísal:
To jsi tedy optimista, nebudu házet čísla, ale řeknu, že je to drtivá většina. Pokusů o slepý test bylo několik, nevím o žádném úspěšném.
karfik
PríspevokZaslal: Ut október 11, 2011 06:53:40    Predmet: Odpovedať s citátom
Já to používám jako realtime plugin ve Foobaru. Jednou to nastavíš a nic neřešíš. Nečekej obrovskou změnu. Ale je to jasně slyšitelné, jakoby se zvuk uklidní. Já to nejvíce poznal na hlase. Určitě přínos a zadarmo, teda pokud posloucháš z PC.
knopi
PríspevokZaslal: Ne január 15, 2012 13:09:19    Predmet: Odpovedať s citátom
Tak ta nová verze bude zanedlouho venku, udělali slibovaný USB/spdif transport U2 ($400) a nový nebo-li vylepšený DAC D2 ($1500), také sláva bez těch modrých blikaček dizajnově to je podle mě moc moc pěkná provedená krabička od nožiček, roury pro sluchátka až po barvu! Vypadá to zajímavě pravděpodobně dobrá mašina za dostupné peníze, ale jelikož nejsem kontruktér člověk toho moc nepozná, USB v asynchroním režimu...
http://www.anedio.com/index.php/audio/gandalf
knopi
PríspevokZaslal: St február 29, 2012 12:24:16    Predmet: Odpovedať s citátom
Tady ještě vnitřky dalších populárních DACů s ESS co tu byly zmiňovány. Konkrétně ten Wyred by měl být od konstruktéra, který dělal oblíbený Cullen mody pro PS Audio jeden čas, ale nejsem si na stopro jistý. Až bude Anedio D2 venku tak pak sem šoupnu vnitřek i toho když bude foto.
Wyred4Sound DAC2 ($1500)
Eastern Electric Minimax Plus ($1100)
knopi
PríspevokZaslal: So marec 03, 2012 21:53:33    Predmet: Odpovedať s citátom
Anedio D2 ($1500)
knopi
PríspevokZaslal: So marec 10, 2012 07:47:10    Predmet: Odpovedať s citátom
Tak jsem ještě dám nějaký info do tohodle šílenýho vlákna Laughing , údajně tenhle uživatel vlastník si D2 donesl do nějakého studia a porovnával to s Berkly Alpha 2 DAC a podle něj to hraje trošičku jinak, ale ve stejné lize.
By Viper2001
Power rectification section. James has incorporated my advice to him last year in using the Cree Silicon Carbide Schottky (SiC) rectifiers (the 8 square devices you see between the transformer and the caps). Cree SiC has lower switching noise and a very harmonic rich sonic signature like tube rectification. The only other DAC I know of using SiC is the MSB Diamond DAC IV's power base, which retails for $4495 (price for the power base only).
In addition, there a RC network on the secondary side of the transformers. This is to damp out the high freq ringing noise when the transformer/rectifiers are switched off. The transformers used here have high leakage inductance, so the RC damping network is necessary. This is a well thought out design few designers would do.
D2 has separate power rails for DAC (3.3v and 1.2v derived from a 5v regulator), op-amps (+/-12V). The +/-12v regulators are nothing special (7912 and 340), my guess is that it is relying on the op-amp's high PSRR and CMRR so it is not necessary to use low noise regulators. The 5v regulator is a low noise one from Burr Brown (33uV). There are additional regulator circuitries to provide power to the DAC chip and clock module.
Capacitors in used are the new Panasonic FR low ESR caps (all electrolytic caps are FR).
The U2 board inside D2. You can barely see the red and black wires going from U2 to D2's main PCB. The wires carries the S/PDIF digital audio signal. I'd have used a piece of RG179 coax to minimize signal reflections induced jitter in this position. But I guess James is counting on D2's ability to reject jitter as it reclocks the S/PDIF signal on the receiver chip.
The output op-amp section. Burr Brown opa1611 op-amps are used here.
The DAC chip and ultra low jitter clock are under the shield. James has increased the capacitance from 100uF in D1 to 1600uF per cap in D2 around the DAC chip/clock section.
The heaphone amp section. James told me that he has improved the buffer IC's output damping network in order to achieve low impedance for the headphone output. D1 has a more conservative damping network design.
All in all, D2 is a piece of well engineered DAC. My hats off to James!
Finally lifted the top of the EMI/RFI shield for the ESS9018 DAC chip and clock. It is still using a Crystek CCHD-950 crystal oscillator (XO). The ppm on the XO is 25ppm. I believe the clock freq here is 80MHz, which is exactly the same used in D1. So I'm not sure why Anedio claims a lower jitter clock in D2. Maybe D1 had 50ppm CCHD-950 instead? But ppm is only meaningful for long term accuracy, not short term accuracy, like jitter
I read in DIY Audio that the ESS9018 does sound better with a higher freq engine clock. I suspect this is the reason why James decided to use 80MHz, instead of 50 or 54MHz in other ESS9018 designs I've seen.
palinoch
PríspevokZaslal: Št marec 22, 2012 19:12:29    Predmet: Odpovedať s citátom
Diky Tomasi za info.
knopi
PríspevokZaslal: Ne apríl 01, 2012 09:46:45    Predmet: Odpovedať s citátom
Lynx Hilo
http://www.lynxstudio.com/product_detail.asp?i=59
