Predám DX Blame ST MKII zosilňovač
audio_holic
Založený: 15 august 2011
PríspevokZaslal: Ut august 16, 2011 16:43:59    Predmet: Predám DX Blame ST MKII zosilňovač Odpovedať s citátom
Build on beautifull Rudi Ratlos (diyaudio group buy) red pcb boards, with best components available: Panasonic FC capacitors for power supply bypass, Elna Cerafine caps for feedback and other applications, Mundorf Mcap as input cap, mica caps, Wima MKP caps for decoupling, Mills power resistors and for desert - transistors are mounted on black eloxated 40X40 5mm thick L profile with allready pre-drilled holes.
Link: www.diyaudio.com/forums/solid-state/164066-dx-blame-st-builders-thread-post-pictures-reviews-comments-here-please.html
The circuit is tested, bias is 50 mA. All documenation is available.
The price for set is 105 EUR + post costs.
You can contact me on: moonaudio@gmail.com
 Filesize:  134.85 KB
 Viewed:  152 Time(s)
