Zaslal: Po november 21, 2011 15:27:45 Predmet: NUFORCE DAC-9 |
* 6 digital inputs (USB, XLR AES/EBU, RCA Coaxial or BNC, RCA Coaxial, Toslink, 3.5mm Optical*):
o Transformer or optical isolated, AC coupled.
o Maximum bit depth: 24 bit
o Maximum S/PDIF sample rate: 192kHz
o Maximum USB sample rate: 44.1, 48, 96 kHz
o A small plugged-in USB module allows for future upgradeability to a higher-bit-rate USB interface card.
o Coaxial or BNC S/PDIF input: Only one of these inputs can be used when Input 3 is selected. To achieve optimum performance, we recommend a 75-ohm BNC cable (available from NuForce) with a BNC connector.
o On the front panel, a 3.5mm optical S/PDIF input.
* Outputs: XLR, RCA, 3.5mm and 6.3mm headphone output*.
o Output Impedance: RCA, 0.01 Ohm; XLR, 50 Ohm; Headphone, 10 Ohm
o Output voltage 0dB, 1kHz: RCA 2.0/4.0Vrms, XLR 4.0/8.0Vrms (Low output/High output versions, low output version has to be custom ordered)
o Headphone power spec.:
+ 288mW rms @ 30 Ohm
+ 210mW rms @ 120 Ohm
+ 152mW rms @ 300 Ohm
o THD+N: 0.01, 0dB, 1kHz
o SNR: 103dB, 1kHz, A-weighted
o Frequency Response: 20-20kHz +/- 0.25dB
o The true-balanced XLR output produces twice the gain of the RCA output. The remote and front panel controls allow for fixed and variable voltages.
* Touch panel control
* Remote control: volume, input select, dim, mute
* Volume and sample rate display
* Power consumption: 9W
* AC voltage: 100V/110V/220V/230V
* Dimension: 215mm (w) x 400mm (d) x 60mm (h)
* Weight: 3.2Kg net, 4.5Kg shipped
* * The headphone output and optical input share the 3.5mm connector.
štandard cena: 1,699.- Euro, do 15.12.2011 1,500.- Euro
23.62 KB |
467 Time(s) |
Linecur Hifista
Založený: 01 marec 2009 Príspevky: 119 Bydlisko: Brno
Zaslal: Po november 21, 2011 21:20:40 Predmet: |
Vynikající přístroj!!! Mohu jen doporučit Porovnával jsem ho s vícero DACany, ale jednoznačně nejpříjemnější, nevtíravý zvuk...
Zaslal: Po november 21, 2011 22:23:14 Predmet: inside |
inside
83.04 KB |
510 Time(s) |
Zaslal: Po november 21, 2011 22:27:05 Predmet: outside |
outside
49.4 KB |
518 Time(s) |
Zaslal: Po november 21, 2011 22:30:09 Predmet: v poslednom čase |
| v poslednom čase sme vyskúšali pár DAC-ov (Cambridge, Furutech, Musical Fidelity...atď) ale kvalitou je po dCS Puccini v režime DAC.... potom dlho nič a pokračujú ostatný od cenovej kategórie 2,000.- EURO. Treba vyskúšať!!! Keď to chcete u nás, prineste so sebou vaše sluchátka.
Zaslal: Po november 21, 2011 22:38:06 Predmet: rear panel |
rear panel
58.49 KB |
537 Time(s) |
KAYKO Hifi obsluha
Založený: 06 február 2010 Príspevky: 30 Bydlisko: BA
Zaslal: Po november 21, 2011 22:46:38 Predmet: |
| Zaujimalo by ma porovnanie s Benchmarkom, skusali ste?
Zaslal: Po november 21, 2011 23:30:05 Predmet: |
| KAYKO napísal: | | Zaujimalo by ma porovnanie s Benchmarkom, skusali ste? |
žial nie, mali sme prislubené že prinese jeden náš zákazník ale neprišiel, sorry....
Linecur Hifista
Zaslal: St november 23, 2011 13:40:33 Predmet: |
| Já jsem to zkoušel - hraje to podle subjektivního názoru lépe. Ten projev je o něco příjemnější, není tak výrazný ve výškách a trochu se mi jevila lepší prostorovost. Mám benchmarka doma, ale nuforce se mi zdál být přínosem - možná o fous, ale jo... jen ta cena:(
Zaslal: St november 23, 2011 14:13:42 Predmet: žiaľ lepšiu |
žial lepšiu zľavu nedokážem poskytnúť
KAYKO Hifi obsluha
Zaslal: Št november 24, 2011 10:32:17 Predmet: |
Britishaudio, Linecur, dik za reakciu.
Ja som rozmyslal o co najlepsom moznom DACe s regulaciou hlasitosti, na prepojenie s aktivnymi bednami a padli mi do oka prave tieto dva.
Zaslal: Št november 24, 2011 11:08:50 Predmet: skladové zásoby |
| sú vypredané. od pondelka sme predali 5 kusov, záväzné objednávky prijímame do 28.11.2011 s tým, že ak záloha bude uhradená do 2.12.2011, cena bude nezmenená (1,500.- Euro).
