ROCKFORD FOSGATE T1500-1BD MONO CHANNEL 1500W
pmaster
Založený: 12 marec 2012
PríspevokZaslal: Po marec 12, 2012 15:01:28    Predmet: ROCKFORD FOSGATE T1500-1BD MONO CHANNEL 1500W Odpovedať s citátom
Features:
RMS Output @ 4 ohm: 500W x 4
RMS Output @ 2 ohm: 1000W x 4
RMS Output @ 1 ohm: 1500W x 4
CEA-2006 compliant
24dB/octave crossover
4 Gauge power/ground terminals
Audiophile grade speaker connections
Infrasonic filter
MOSFET output stage
MOSFET power supply
RCA pass-thru
Cast aluminum heat sink
Dynamic thermal magnet
MEHSA(3) to reduce MOSFET temperatures, lower distortion, and increase durability and lifespan
Punch Bass EQ
DSM to increase circuit efficiency and eliminate cross-talk from other components
Power, Thermal, Protect visual indicators
Class bd circuit topology
2.14" x 8.14" x 14.91"
Specifications:
RMS Power Range: 500-1500 Watts
Number Of Channels: 1
Low Frequency response: 20 Hz
High Frequency Response: 250000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
na cene sa dohodneme Wink
 Filesize:  32.13 KB
 Viewed:  123 Time(s)
