adeo Hifi obsluha
Založený: 15 október 2008 Príspevky: 11
Zaslal: Po november 05, 2012 14:13:06 Predmet: OPPO BDP-83 SPECIAL EDITION Blu-ray Player - PREDAJ !!! |
CENA: 500 EUR - PISTE DOHODNEME SA, ODCHADZAM DO ZAHRANICIA, TAKZE TO POTREBUJEM RIESIT!
Dovod: budem kupovat novu BDP 105, cena dohodou, mam ho par mesiacov, je este v zaruke, komplet so vsetkym, akurat zahorety, nebol velmi pouzivany, uz 3/4 roka doma lezi zabaleny, kedze som pracoval mimo republiky.
kontakt:
mannimario@gmail.com
Features
The OPPO BDP-83 Special Edition Blu-ray Disc Player is an exciting upgrade based on the highly acclaimed BDP-83. Already well known for its exceptional audio and video performance, the BDP-83 is upgraded with an all new analog audio stage and improved power supply to become the Special Edition. Designed for the discerning audio enthusiast, the OPPO BDP-83 Special Edition Blu-ray Disc Player delivers an exceptionally wide dynamic range, ultra low distortion, accurate sound stage and jitter-free music clarity via its dedicated stereo and 7.1ch analog audio output.
The OPPO BDP-83 Special Edition uses the state-of-the-art Sabre32 family of Digital-to-Analog Converters (DAC) from ESS Technology. The Sabre32 family is known as one of the industry's highest performance audio DACs and are often found in high-end audiophile and professional equipments. The OPPO BDP-83 Special Edition uses an 8-channel Sabre Premier (ES9006) DAC chip for its 7.1 multi-channel output. The dedicated stereo output uses another 8-channel Sabre32 Ultra (ES9016) DAC chip by stacking 4 DACs for each of the Left and Right channels to achieve even greater audio performance.
Just like the BDP-83 it is based on, the OPPO BDP-83 Special Edition is a Profile 2.0 Blu-ray player featuring bit-stream and full decoding capability for high resolution audio tracks such as Dolby TrueHD and DTS-HD Master Audio. Designed for both home theater viewers and music listeners, it plays DVD-Video, DVD-Audio, Super Audio CD (SACD) and standard CD with excellent video and audio performance in addition to Blu-ray Discs. For a detailed list of features, please refer to the BDP-83 Features and Specifications page.
OPPO Digital recommends the BDP-83 Special Edition to customers who primarily use the analog audio output to connect to either a dedicated stereo or a multi-channel surround system. For customers who primarily use the HDMI output to connect to an A/V receiver or directly to a TV/projector, and for customers who primarily use the optical/coaxial digital audio output, the standard BDP-83 is recommended.
Specifications
Designs and specifications are subject to change without notice.
Disc Types* BD-Video, DVD-Video, AVCHD, DVD-Audio, SACD, CD, HDCD, Kodak Picture CD
CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
BD Profile BD-ROM Version 2 Profile 2 (also compatible with Profile 1 Version 1.0 and 1.1)
Internal Storage 1GB (Actual available storage varies due to system usage)
Output Analog Audio: 7.1ch or 5.1ch, stereo
Digital Audio: Coaxial, Optical
HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
Analog Video: Composite, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content only)
Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)
Video Characteristics Composite Video Amplitude: 1.0Vp-p (75Ω)
Component Video: Y: 1.0Vp-p (75Ω), Pb/Pr: 0.7Vp-p (75Ω)
Audio Characteristics** Frequency: Stereo 20Hz - 44kHz (±0.2dB), 20kHz - 96kHz (±1.1dB)
7.1CH 20Hz - 44kHz (±0.4dB)
Signal-to-Noise Ratio: >117dB (A-weighted, auto-mute off)
THD+N: < 0.002% (1kHz at 0dBFS, 20kHz LPF)
Dynamic Range: >104dB (24-bit unweighted)
Channel Separation: >106dB (24-bit unweighted)
General Specification Power Supply: ~ 100V - 240V, 50/60Hz AC
Power Consumption: 35W (0.5W Standby)
Dimensions: 430mm x 336mm x 77mm, 16-7/8 x 13-1/4 x 3 inches
Mass: 5.1kg / 11.2 lbs
Operating Temperature 5°C - 35°C
41°F - 95°F
Operating Humidity 15% - 75%
No condensationCENA
Naposledy upravil adeo dňa Ne november 11, 2012 15:18:47, celkom upravené 2 krát. |
Kuba4 Hifi inventar
Zaslal: Po november 05, 2012 14:28:39 Predmet: |
| Jakou máš na něm verzi firmware? |
Michal Majerčík Hifi obsluha
Založený: 22 november 2012 Príspevky: 1 Bydlisko: Brezno
Zaslal: Št november 22, 2012 18:18:36 Predmet: Záujem o prehrávač |
Dobrý večer,
mal by som záujem o prehrávač; napíšte mi či ho ešte máte.
S pozdravom, Majerčík _________________ mišo |
Fifino Nádejný hifista
Založený: 11 marec 2010 Príspevky: 86
Zaslal: So november 24, 2012 07:49:24 Predmet: |
adeo,
která vlastně z těch cen platí, máš to tady jak na tržišti..  _________________ Pioneer DV-757+vanity, Casea SiriusXLR, pasivní regulace, 2xCopland CTA-520, Audio physic Scorpio. |
