OPPO BDP-83 SPECIAL EDITION Blu-ray Player - PREDAJ !!!
adeo
Založený: 15 október 2008
PríspevokZaslal: Št november 15, 2012 21:16:48    Predmet: OPPO BDP-83 SPECIAL EDITION Blu-ray Player - PREDAJ !!! Odpovedať s citátom
NOVA CENA: 450 EUR - PISTE DOHODNEME SA, ODCHADZAM DO ZAHRANICIA, TAKZE TO POTREBUJEM RIESIT!
Dovod: budem kupovat novu BDP 105, cena dohodou, komplet so vsetkym, akurat zahorety, nebol velmi pouzivany, uz 1 rok doma lezi zabaleny, kedze som pracoval mimo republiky a znova odchadzam.
kontakt:
mannimario@gmail.com
Features
The OPPO BDP-83 Special Edition Blu-ray Disc Player is an exciting upgrade based on the highly acclaimed BDP-83. Already well known for its exceptional audio and video performance, the BDP-83 is upgraded with an all new analog audio stage and improved power supply to become the Special Edition. Designed for the discerning audio enthusiast, the OPPO BDP-83 Special Edition Blu-ray Disc Player delivers an exceptionally wide dynamic range, ultra low distortion, accurate sound stage and jitter-free music clarity via its dedicated stereo and 7.1ch analog audio output.
The OPPO BDP-83 Special Edition uses the state-of-the-art Sabre32 family of Digital-to-Analog Converters (DAC) from ESS Technology. The Sabre32 family is known as one of the industry's highest performance audio DACs and are often found in high-end audiophile and professional equipments. The OPPO BDP-83 Special Edition uses an 8-channel Sabre Premier (ES9006) DAC chip for its 7.1 multi-channel output. The dedicated stereo output uses another 8-channel Sabre32 Ultra (ES9016) DAC chip by stacking 4 DACs for each of the Left and Right channels to achieve even greater audio performance.
Just like the BDP-83 it is based on, the OPPO BDP-83 Special Edition is a Profile 2.0 Blu-ray player featuring bit-stream and full decoding capability for high resolution audio tracks such as Dolby TrueHD and DTS-HD Master Audio. Designed for both home theater viewers and music listeners, it plays DVD-Video, DVD-Audio, Super Audio CD (SACD) and standard CD with excellent video and audio performance in addition to Blu-ray Discs. For a detailed list of features, please refer to the BDP-83 Features and Specifications page.
OPPO Digital recommends the BDP-83 Special Edition to customers who primarily use the analog audio output to connect to either a dedicated stereo or a multi-channel surround system. For customers who primarily use the HDMI output to connect to an A/V receiver or directly to a TV/projector, and for customers who primarily use the optical/coaxial digital audio output, the standard BDP-83 is recommended.
Specifications
Designs and specifications are subject to change without notice.
Disc Types* BD-Video, DVD-Video, AVCHD, DVD-Audio, SACD, CD, HDCD, Kodak Picture CD
CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE
BD Profile BD-ROM Version 2 Profile 2 (also compatible with Profile 1 Version 1.0 and 1.1)
Internal Storage 1GB (Actual available storage varies due to system usage)
Output Analog Audio: 7.1ch or 5.1ch, stereo
Digital Audio: Coaxial, Optical
HDMI Audio: Stereo, up to 7.1ch high-resolution PCM, up to 5.1ch DSD, bitstream or LPCM conversion of Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution Audio, and DTS-HD Master Audio.
Analog Video: Composite, Component Video (Y/Pb/Pr, 480i/480p, 720p/1080i available for non-restricted content only)
Digital Video: HDMI with HDCP (NTSC: 480i/480p/720p/1080i/1080p/1080p24, PAL 576i/576p/720p/1080i/1080p/1080p24)
Video Characteristics Composite Video Amplitude: 1.0Vp-p (75Ω)
Component Video: Y: 1.0Vp-p (75Ω), Pb/Pr: 0.7Vp-p (75Ω)
Audio Characteristics** Frequency: Stereo 20Hz - 44kHz (±0.2dB), 20kHz - 96kHz (±1.1dB)
7.1CH 20Hz - 44kHz (±0.4dB)
Signal-to-Noise Ratio: >117dB (A-weighted, auto-mute off)
THD+N: < 0.002% (1kHz at 0dBFS, 20kHz LPF)
Dynamic Range: >104dB (24-bit unweighted)
Channel Separation: >106dB (24-bit unweighted)
General Specification Power Supply: ~ 100V - 240V, 50/60Hz AC
Power Consumption: 35W (0.5W Standby)
Dimensions: 430mm x 336mm x 77mm, 16-7/8 x 13-1/4 x 3 inches
Mass: 5.1kg / 11.2 lbs
Operating Temperature 5°C - 35°C
41°F - 95°F
Operating Humidity 15% - 75%
No condensation
 Filesize:  24.92 KB
 Viewed:  275 Time(s)
jeremysk
Založený: 28 november 2010
PríspevokZaslal: Št november 15, 2012 21:59:38    Predmet: Odpovedať s citátom
idu sacd iso image? alebo uz je to bloknute?
Vo výstavbe: KT88 SE, Jensen Troels
Meditujem pri:pasiv HTPC, Primare CD31, Gustard x22, DAC1794 NOS 8xPCM1794, SPX2010, 2xDPA380MK2, Hypa17,2x SPX A40, Ekta Grande
Streamer: Htpc, Intel NUC-RoonRock
adeo
PríspevokZaslal: Št november 15, 2012 22:08:55    Predmet: Odpovedať s citátom
jeremysk napísal:
Mam kopu palenych SACD ale formou Hi-Res Flac a to fungovalo fajne. Pytas sa ci cita priamo ISO?
jeremysk
PríspevokZaslal: Št november 15, 2012 22:59:12    Predmet: Odpovedať s citátom
ano priamo iso image, lebo v nov39ch firmweroch je to blokovan0
adeo
PríspevokZaslal: Št november 15, 2012 23:08:55    Predmet: Odpovedať s citátom
jeremysk napísal:
Toto uprimne nemam vyskusane, lebo som nemusel, neviem tento krat odpovedat. Tento stroj je vynimocny hlavne vo zvuku cez analog audio output. Tak ho pouzivam ja lebo je to SE. Nemam pre teba relevantnu odpoved.
Kuba4
Založený: 08 október 2006
PríspevokZaslal: Pi november 16, 2012 17:12:12    Predmet: Odpovedať s citátom
Adeo i v SZ odpovídá zvláštně. Buď opravdu neví oč jde nebo to naopak ví velmi dobře.
adeo
PríspevokZaslal: Pi november 16, 2012 17:27:17    Predmet: Odpovedať s citátom
Kuba, nieco mi uchadza? Neviem o com tocis, teraz pristroj nepouzivam tak s tym ISO fakt neviem, lebo som to neskusal. Mas otazku pytaj sa.
jeremysk
PríspevokZaslal: Pi november 16, 2012 17:53:18    Predmet: Odpovedať s citátom
Tak to vyskušaj, stiahnum SACD ISO no problem.
adeo
PríspevokZaslal: Po november 19, 2012 15:30:56    Predmet: Ahoj Odpovedať s citátom
jeremysk napísal:
Ako som pisal, ja teraz pristroj nepouzivam, takze to nevyskusam, kedze cela moja aparatura je "packed". Napalene ISO som nikdy neskusal, lebo nebola potreba, ved vacsinou som si palil - Vinyl rip v 24-bit/96 Khz | FLAC, ktore maju bajecnu kvalitu. Ak ISO slo tak asi pojde. Ak mate zaujem a chcete kupit, jasne pridite, vyskusame aj to, to samozrejme nie je problem sa dohodnut. Piste ss, hodim aj cislo.
Fifino
Založený: 11 marec 2010
PríspevokZaslal: So november 24, 2012 07:46:23    Predmet: Odpovedať s citátom
adeo,
která vlastně z těch cen platí, máš to tady jak na tržišti.. Rolling Eyes
Pioneer DV-757+vanity, Casea SiriusXLR, pasivní regulace, 2xCopland CTA-520, Audio physic Scorpio.
ja-kub
Založený: 30 december 2007
PríspevokZaslal: So november 24, 2012 10:42:03    Predmet: Odpovedať s citátom
adeo je problém sem napísať aký tam máš firmvér??
adeo
PríspevokZaslal: So november 24, 2012 17:16:43    Predmet: INFO Odpovedať s citátom
ja-kub napísal:
Som presvedceny ze ste obaja dost bystri, ze fifino - jakub.
Nevyskusam, ktory tam je firmware, lebo je to zabalene. Ak mate seriozny zaujem samozrejme mozete prist a pozrieme sa na to.
pekny den
Roman_U
Založený: 07 január 2013
PríspevokZaslal: Po január 07, 2013 21:50:35    Predmet: Odpovedať s citátom
je oppo 83se este na predaj?
