MUSICAl FIDELITY M6DAC
britishaudio
Založený: 14 marec 2009
PríspevokZaslal: Ne december 16, 2012 19:52:56    Predmet: MUSICAl FIDELITY M6DAC Odpovedať s citátom
5 digitálnych vstupov
- 2 koax
- 1 optika
- 1 AES/EBU
- 1 USB 24bit/192kHz
2 výstupy
- 1 pár RCA
- 1 pár XLR
BLUETOOTH !!!
Choke Power supply
V predaji od januára 2013
Performance
Jitter: <12 picoseconds peak to peak
THD(+ noise): <0.0012% 10Hz to 20 kHz
Frequency Response: +0, –3dB, <2Hz to 90 kHz (192kHz sample rate)
Signal to Noise ratio: >120dB A”- wtd.
Channel seperation: >105dB
DAC
Type: 24 bit Delta-Sigma (bit stream) dual differential 8x over-sampling with asynchronous up sampling on all inputs to 192 kHz
Digital filter (fast roll off): -3dB @ 0.49 x sampling frequency, ±0.0002dB pass band ripple
Digital filter (slow roll off): -3dB @ 0.45 x sampling frequency, ±0.001dB pass band ripple
 Filesize:  65.46 KB
 Viewed:  637 Time(s)
