Klipschfreak Hifista
Založený: 13 jún 2008 Príspevky: 156
Zaslal: Št jún 20, 2013 11:51:18 Predmet: B.M.C. - PureLine DAC |
http://bmc-audio.com/index.php/PureDAC-EN.html
Features:
Top-grade Digital/Analog Converter with Current Injection current-to-voltage (I/V) conversion
High-resolution asynchronous USB interface up to 24bit/384kHz
USB PCM: 16...32bit; 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384kHz.
USB DSD: DSD64, DSD128.
ASIO driver for Windows; Linux and Mac compatible
AES/EBU, coaxial and Toslink digital inputs
Balanced, reference-class headphone amplifier with digital/analog power convertion (DAPC), load-effect free (LEF) technology, a lateral MOSFET, a super-low impedance LEF output stage, and lossless Digital Intelligent Gain Management (DIGM) volume control
Balanced LEF, CI-compatible preamp that optionally operates in B.M.C. Mode, with DIGM and a vertically diffused metal oxide semiconductor (DMOS) and LEF-balanced output stage.
Separate volume controls for the line and headphone sections
Second-generation DIGM with optimized gain distribution between power amps and internal and DIGM volume levels
Optical B.M.C. Link for connecting with B.M.C. amps like the PureMono
Remote Control
Massive and stylish extruded aluminum chassis
Dimensions: 14.37 x 4.06 x 12.91 inches, W/H/D (365 x 103 x 328 mm)
Weight: 11.9 lbs (5.4 kg)
24.28 KB |
288 Time(s) |
35.39 KB |
327 Time(s) |
180.88 KB |
320 Time(s) |
