subwoofer JBL L8400P
Papolius
Založený: 08 február 2011
PríspevokZaslal: St apríl 09, 2014 11:20:14    Predmet: subwoofer JBL L8400P Odpovedať s citátom
Ahoj Všem. Prodám tetnto skvělý subwoofer. Sloužil skvěle na hudbu i domácí kino, ale po přestěhování do nového bytového domu nemohu využívat jeho výkon(sousedi)
Hraje opravdu skvěle a 30cm membrána s brutálním zesilovačem opravdu rozhýbe celé tělo Smile
Amplifier Power (RMS) 600 Watts
Peak Dynamic Power 1200 Watts The Peak Dynamic Power is measured by recording the highest peak-to-centre voltage produced by the power amplifier with its limiters disabled, across the output of a resistive load equal to minimum impedance of the transducer, using a 50Hz sine wave burst, 3 cycles on, 17 cycles off.
Frequency Response (–3dB) 22Hz – Low-pass crossover frequency
Low-Pass Crossover Frequencies 50Hz – 150Hz, continuously adjustable; 150Hz when using speaker-level connection
Low-Frequency Transducer 12" (300mm) PolyPlas™ cone with rubber surround and cast-aluminum chassis; HeatScape™ motor structure; Symmetrical Field Geometry™ (SFG™); oversized fiberglass voice coil; magnetic shorting ring
Baffle Low diffraction, IsoPower™
Enclosure Design Sealed
Inputs Gold-plated 5-way binding-post speaker-level; left and right line-level, switchable to LFE
Outputs Gold-plated 5-way binding-post speaker-level
Dimensions (H x W x D) 16-1/2" (15-1/2" without feet) x 15-1/2" x 15-1/2"
(419mm [394mm without feet] x 394mm x 394mm)
Weight 58 lb (26.4kg)
http://www.jbl.com/estore/jbl/us/products/L8400P/L8400P_JBL_US?searchMode=refurbishedProductOnly
MStokr zavinac seznam.cz
 Filesize:  4.84 KB
 Viewed:  1438 Time(s)
