Dynaudio Contour 1.8 MK II
Hyri
Založený: 21 február 2014
PríspevokZaslal: Ut február 10, 2015 15:41:59    Predmet: Dynaudio Contour 1.8 MK II Odpovedať s citátom
Predam Krasne, v stave ako nove repro Dynaudio contour 1.8 MK2.Farba Maple.Po prvom majitelovi, nefajciar. k dispozicii papiere a zaslebky bassreflexov, pripadne pridam aj hroty a podlozky.
Cena : 1390 alebo dohoda
Contour 1.8 MK II
http://www.dynaudio.com/int/home_loudspeaker_systems/archive/contour/contour18II.php
Music lovers looking for beauty and pure sensitivity in a freestanding floor monitor should look no further than the Contour 1.8 MK II.
Designed specifically for mid-sized rooms, this two-way speaker features dual active bass drivers incorporating 75 mm (3 inch) woofer voice coils and long throw progressive spiders for improved membrane control. Our renowned soft dome tweeters are the secret behind the Contour 1.8 MKII's incredible sensitivity and dynamic range. These ferrofluid-cooled and damped tweeters are purposely moulded in one piece to provide the listener a perfectly integrated sound.
With a double magnet system on all drivers, and heavy duty cabling for durability and strength, the Contour 1.8 MKII is a floor mounted speaker that is really going places.
However, to ensure your speaker stays just where you want it, we're equipping each one with a spiked MDF base. It's the ideal way to keep these little beauties under control!
Technical Specification
Sensitivity (2.83 V/1 m) 86 dB
IEC Long Term Power Handling 250 W
Impedance 4 Ohms
Frequency Response 28 Hz - 30 kHz
Weight 19 kg
Dimensions (W x H x D) 204 x 935 x 294 mm
B&W 604 S3 , Onkyo TX SR 600E
Hyri
PríspevokZaslal: Ne február 15, 2015 00:18:45    Predmet: Odpovedať s citátom
prajem vela prijemnych chvil novemu majitelovi, budu mi chybat...
