Zaslal: Po júl 13, 2015 19:26:20 Predmet: ANSI/CEA-2034 Method of Measurement for In-Home Loudspeakers |
Tak máme štandard na meranie domácich reprosústav:
| citácia: | | This standard describes how to determine the frequency response, directivity and maximum output capability of a residential loudspeaker. It is intended to determine the audio performance of a loudspeaker, not the loudspeaker’s ability to survive a given input signal. This standard applies only to loudspeaker systems, and not to raw transducers. |
| citácia: | 4 Directivity Response – Standalone Loudspeakers ................................................................. 4
4.1 Data Acquisition .................................................................................................................. 5
4.2 Post Processing of Data ..................................................................................................... 8
4.3 Data Presentation ................................................................................................................ 9
5 Directivity Response – In-Wall, In-Ceiling, On-Wall and On-Ceiling Loudspeakers .......... 10
5.1 Data Acquisition – Stationary Microphone ..................................................................... 11
5.2 Data Acquisition – Rotating Microphone ........................................................................ 11
5.3 Data Presentation .............................................................................................................. 11
6 On-Axis Maximum Usable Sound Pressure Level ................................................................ 11
6.1 On-Axis Maximum Usable Sound Pressure Level – Continuous ................................. 11
6.1.1 Input Signal .................................................................................................................. 11
6.1.2 Data Acquisition .......................................................................................................... 13
6.1.2.1 Measurement Set-up ................................................................................................ 13
6.1.2.2 Measurement Procedure ......................................................................................... 14
6.2 On-Axis Maximum Sound Pressure Level – Peak ......................................................... 16
6.2.1 Input Signal .................................................................................................................. 16
6.2.2 Data Acquisition .......................................................................................................... 16
6.2.3 Max Peak SPL Data Post-Processing ........................................................................ 21
6.3 Maximum SPL Data Presentation .................................................................................... 21
7 Impedance ................................................................................................................................. 22
7.1 Data Acquisition ................................................................................................................ 22
7.2 Data Presentation .............................................................................................................. 23
8 Required Power Amplifier Size ............................................................................................... 24
8.1 Calculation ......................................................................................................................... 24
8.2 Data Presentation .............................................................................................................. 25 |
http://www.ce.org/Standards/Standard-Listings/R3-Audio-Systems/CEA-2034-(ANSI).aspx
Cena od $39 - http://www.pdfengineers.org/65571-CEA-2034-PDF.html |
