Coques Hifista - zaslúžilec
Zaslal: Št júl 16, 2015 14:32:51 Predmet: TEAC UD-503 (2015 model) |
Papierovo sa mi to páči. Táto značka je mi sympatická. Som na to celkom zvedavý, cena by mohla byť okolo 25000czk. Nemá niekto skúsenosť s posluchom staršieho modelu UD-501?
http://www.teac.com/product/ud-503/
kód: |
UD-503 SPECIFICATIONS
Digital Audio Input
Coaxial
Connector RCA jack x 1
1/8" (3.5mm) Mini jack x 1 (compatible with Optical Input)
Input Level 0.5 Vp-p
Input Impedance 75 ohms
Supported Format DSD, PCM
DSD 2.8MHz (176.4kHz/24bit DoP transfer)
PCM 32k / 44.1k / 48k / 88.2k / 96k / 176.4k /192kHz, 16 / 24bit
Optical
Connector TOS link x 1
1/8" Mini Optical jack x 1 (compatible with Coaxial Input)
Input Level –24.0 to –14/5dBm peak
USB
Connector USB B type x 1
PCM 32k / 44.1k / 48k / 88.2k / 96k / 176.4k /192k / 352.8k / 384kHz, 16 / 24 / 32bit
Analog Audio Input
Connector RCA jack x 1 pair
Input Impedance 51k ohms
Sensitivity 130mV
Analog Audio Output
Connectors
Balanced XLR 3-32 x 1 pair
Unbalanced RCA jack x 1 pair
Output Impedance
Balanced 188 ohms
Unbalanced 150 ohms
Max Output Level
Fixed (0dB) 2.0Vrms (XLR/RCA)
Fixed (+6dB) 4.0Vrms (XLR/RCA)
Variable 12.0Vrms (XLR), 6Vrms (RCA)
Frequency Response 5Hz to 80kHz (+1dB/–3dB)
Signal-to-Noise Ratio
Balanced 112dB (A-weighted, 1kHz)
Unbalanced 110dB (A-weighted, 1kHz)
Total Harmonic Distortion 0.0015% (1kHz, LHF: 20Hz to 20kHz)
Headphone Output
Connectors 1/4" (6.3mm) Stereo jack x 2
Format Balanced, Active Ground, Unbalanced
Polarity
Balanced Tip: HOT, Ring: COLD, Shield: GND
Active Ground Tip: HOT, Ring: COLD, Shield: GND
Unbalanced Tip: L, Ring: R, Shield: GND
Max Output Power
Balanced 700mW + 700mW (32ohms loaded, THD 1%)
Unbalanced 500mW + 500mW (32ohms x 1 loaded, THD 1%)
350mW + 350mW (32ohms x 2 loaded, THD 1%)
Supported Headphone Impedance 16 to 600 ohms
Audio Settings
Up-conversion x8, x4, x2, Off
DSD Cut-off Frequency 50kHz, 150kHz
PCM Digital Filter FIR Sharp, FIR Slow, Short-delay Sharp, Short-delay Slow
Line Output RCA, XLR (Pin2: HOT), XLR (Pin3:HOT)
Line Output Level Fixed (0dB), Fixed (+6dB), Variable, Off
Supported OS
Windows Windows 8.1 (32/64bit), Windows 8 (32/64bit), Windows 7 (32/64bit)
Macintosh Yosemite (OS X10.10), Mavericks (OS X10.9), Mountain Lion (OS X10.8), Lion (OS X10.7)
Operation Power
US/Canada AC 120V, 60Hz
UK/Europe AC 230V, 50Hz
Power Consumption 16 Watts (0.4 Watts at Standby Mode)
Overall Dimensions
(including protrusions) 11.4" (W) x 3.2" (H) x 9.8" (D)
290 (W) x 81.2 (H) x 248.7 (D) mm
Weight 9.3 lbs. / 4.2 kg
Accessories Remote control (RC-1319), AAA Batteries x 2, RCA-Mini Plug Cable, Power Cord, Cushion for Foot x 3, Owner's Manual (including Warranty card)
Dohnalik Hifista
Založený: 21 október 2011 Príspevky: 152 Bydlisko: Kroměříž
Zaslal: Št júl 16, 2015 15:08:39 Predmet: |
TEAC ted začal dělat slušné DACy, určitě to nebude nic špatného. |
koso Hifi obsluha
Založený: 18 január 2010 Príspevky: 28 Bydlisko: Trnava
Zaslal: St september 09, 2015 12:21:40 Predmet: |
UD 501 mam doma uz vyse roka a som maximalne spokojny. Za tie peniaze je to vyborna masina. Univerzalna, s velkym potencialom osobneho "doladenia" zvuku (nastavenie filtrov, upsampling atd). Mal som doma pozicane aj niekolkonasobne drahsie DA prevodniky, ktore sa mi zvukovo nepaciti tak, ako TEAC. Samozrejme zalezi na tom, kde a do akeho retazca je to zapojene.
moj retazec je takyto:
Sietovy filter: PS Audio Quintet Power Center
CD prehravac (momentalne zapojeny ako transport): C.E.C. TL51XR
Hlavny zdroj signalu: Auralic Aries (taham hlavne z priamo pripojeneho ssd HDD)
DAC: Teac UD 501
Zosilovac: Primare I30
Repraky: Sonus Faber Minima Amator
Kabelaz: Supra Trico, Audioquest VDM-3, Viablue KR2 Silver, HGA DNA, Kimber Hero, Kimber 12TC
Vyuzivam koaxialny a USB digitalny vstup, symetricky aj nesymetricky vystup.
Zvuk je vyvazeny, krystalovo cisty, nic nie je zbytocne vystupene do popredia. Velmi muzikalny...
Ak by niekoho zaujimalo nieco konkretne ohladne tohoto DAC, rad sa podelim o skusenosti... Kazdopadne ho ale mozem len doporucit. Je to vynikajuca investicia.
Novy model UD 503 vyzera byt este lepsi (okrem ineho DA cipu ma oproti UD501 navyse dialkove ovladanie a variabilny vystup s digitalnym ovladanim hlasitosti, cize sa da pouzit ako predzosilovac) ale bude adekvatne k tomu aj drahsi... |
kuko61 Hifi obsluha
Založený: 23 január 2010 Príspevky: 45 Bydlisko: Bratislava
Zaslal: Po september 14, 2015 23:29:44 Predmet: |
Rozmýšlam nad kúpou slúchadlového DAC/AMP-u a UD-503 je môj favorit.
V EU sa začína predávať v týchto dňoch, recenzia predajného kusu mimo japonských stránok zatiaľ nie je. Jedna z prvých by mohla byť tu http://everythingaudionetwork.blogspot.sk/
Vraj nemá byť náhradou UD-501, takže cenovo bude nad ním.
V európe bude cenníková cena pravdepodobne 999€. Aspoň taká sa objavila v eu eshopoch:
http://shop.audiosalon.sk/ud-503b/p827665c30191
https://www.wifimedia.eu/teac-audio-m-138.html
UD-501 má cenníkovú cenu 799€ a v súčasnosti sa dá kúpiť za 630€, tak by aj tu mohla cena klesnúť aspon o stovku.
Nejaké info aj s fotkami vnútra sa dá nájsť napr. tu, len si treba preložiť stránku z japončiny
http://my-hiend.com/wp/category/brand/teac/
_________________ Infinity Kappa 8.2i
iPod 5.5G iMod, Fiio E17 -> IEM LZ-A2, LZ-A4
Pioneer U-05 -> Burson Soloist SL -> Elemental Watson -> Audeze LCD3, Meze 99Classic, AKG K545, DT990Pro, Senn HD530/II, HD540/II, HD560/II, HD565 |
corny74 Hifi obsluha
Založený: 22 február 2011 Príspevky: 3 Bydlisko: Slovenská republika
Zaslal: Ut december 22, 2015 00:54:19 Predmet: |
Ma uz niekto UD-503? Ak ano mozno by nebolo dat nejake dojmy, poznatky, pripadne porovnanie s inym DAC-om ... mna by to urcite zaujmalo a myslim, ze su tu aj ini zaujemcovia o ten DAC. |
