BlackBerry Hifi inventar
Zaslal: Ne január 17, 2016 12:30:37 Predmet: |
To sa mi velice páči .  |
Zaslal: Ne január 17, 2016 13:02:06 Predmet: |
Jj, a zaujimave su i milniky/prvenstva ich firmy, hlavne tie posledne:
| citácia: | Demonstrated first AC-3 output for LaserDisc to Dolby 1994
First THX approved LaserDisc Player (Runco LJR II 1995)
First out board AC-3 demodulator (Lexicon LDD-1 1995)
First out board DTS processor (Millennium 2.4.6 1997)
First digital output on a DSS receiver (1997)
First mass marketed 24 bit 96K DAC (LINK DAC 1998)
First discrete sign-magnitude 384 kHz Ladder DAC (Platinum DAC 2000)
First discrete asynchronous upsampler (Platinum Plus 192 kHz Upsampler 2001)
First 80 bit DSP based digital filter (16X Filter 2005)
First iPod based digital music server (iLink 2006)
First 384 kHz inputs and upsampling (DAC III 2009)
First 32 bit interface (Xport 2009)
First 384 kHz Bit Perfect USB input (Signature USB on DAC IV 2010)
First CD transport that could play data files up to 32 bit, 384 kHz (Data CD IV 2010)
First clock with Jitter under 1 psec (77 Femtosecond Galaxy Clock - 2011, 33 Femtosecond Clock - 2015)
First DAC to exceed the 24 bit theoretical limits (SELECT DAC - 2014, 149 dB dynamic range, SELECT II DAC - 2015, 173 dB dynamic range = 28.5 effective bits)
Zdroj: http://www.msbtech.com/history/historyHome.php |
Zaslal: Ne január 17, 2016 13:04:29 Predmet: |
| Akurat z umiestnenia hodin na DPS asi nepovazuju za dolezite aby boli hodiny co najblizsie k prevodniku. |
lubos Hifista
Založený: 15 december 2006 Príspevky: 214
Henri Hifista - zaslúžilec
Zaslal: St január 20, 2016 08:37:31 Predmet: |
Jj, akurat tieto grafy, na rozdiel od inych v meraniach, uz uplne krasne nie su:
Fig.10 MSB Diamond DAC IV, Upsampling 2 On, Analog Ground Lifted, spectrum of 50Hz sinewave, DC–1kHz, at 0dBFS into 100k ohms (left channel blue, right red; linear frequency scale).
Fig.11 MSB Diamond DAC IV, Filter 3, Upsampling Off, HF intermodulation spectrum, DC–30kHz, 19+20kHz at 0dBFS into 100k ohms (left channel blue, right red; linear frequency scale).
Fig.12 MSB Diamond DAC IV, Filter 4, Upsampling Off, HF intermodulation spectrum, DC–30kHz, 19+20kHz at 0dBFS into 100k ohms (left channel blue, right red; linear frequency scale).
Fig.13 MSB Diamond DAC IV, Filter 4, Upsampling 2 On, HF intermodulation spectrum, DC–30kHz, 19+20kHz at 0dBFS into 100k ohms (left channel blue, right red; linear frequency scale).
Zdroj: http://www.stereophile.com/content/msb-technology-platinum-data-cd-iv-transport-amp-diamond-dac-iv-amp-da-converter-measurement |
Zaslal: St január 20, 2016 09:09:45 Predmet: |
Podívej se v tom odkazu na impulsní odezvy filtru 3 a filtru 4 a bude to jasne, proč CCIF 19+20k spektrum tak vypadá. Správný filtr je filtr 1, se kterým to Atkinson, bohužel, neměřil. _________________ mám rád hifi, ale víte, jak je to dál ..... |
Zaslal: St január 20, 2016 09:59:48 Predmet: |
Hodiny za desinu...... mne stačia tie v mobile  |
Zaslal: St január 20, 2016 10:16:19 Predmet: |
| PMA napísal: | | Podívej se v tom odkazu na impulsní odezvy filtru 3 a filtru 4 a bude to jasne, proč CCIF 19+20k spektrum tak vypadá. Správný filtr je filtr 1, se kterým to Atkinson, bohužel, neměřil. |
presne tak, ostatne robia ten krasne široky a bystrozraky priestor
preto davam prednost DACom od dCS a Meitnera- tie si menej vymyslaju |
Zaslal: St január 20, 2016 10:44:16 Predmet: |
| bubuxin napísal: |
Trochu neprakticke- nemozes ten mobil pouzivat ked ho mas stale pripojeny k DACu  |
