tantito Hifista - pokročilec
Založený: 24 február 2013 Príspevky: 352 Bydlisko: Žilina
Zaslal: Ne február 14, 2016 15:20:38 Predmet: Linn Black |
Predam signalovy kabel od Skotskeho vyrobcu LINN,model Black,kabel je v peknom stave,dlzka 1.2M,35€....
viac foto: http://elektro.bazos.sk/inzerat/58322167/LINN-BLACK.php
mojskyd@gmail.com
39.35 KB |
121 Time(s) |
_________________ Thorens TD160mk1/Technics SL1200GR/Project Tube Box DS2/Topping D90/Sansui907XR/Mabat Little Sandhorn |
Zaslal: Ne február 14, 2016 15:51:46 Predmet: |
Čo tak si dať trošku práce si dať s tým inzerátom?
| citácia: | Linn ‘Black’ interconnect cable is our standard cable for connecting Majik or Akurate components in a Linn system.
This cable is derived from the low capacitance polystyrene dielectric cable used originally to carry the signal from a turntable and cartridge to a pre-amplifier. This ‘phono’ signal is probably the most demanding of all signals in any audio system, usually less than one thousandth of the signal between a CD player and an amplifier. A cable good enough to handle this signal will accurately transfer any other low level audio signals in an audio or AV system.
* Double layer braided and foil shielding for excellent screening from mains frequencies
* 45-strand copper conductor
* Outer diameter 5.1 mm
Zdroj: http://www.linn.co.uk/hifi-separates/accessories/interconnect-cables#black-interconnects
Zaslal: Ne február 14, 2016 15:56:36 Predmet: |
| miero napísal: | Čo tak si dať trošku práce si dať s tým inzerátom?
Zdroj: http://www.linn.co.uk/hifi-separates/accessories/interconnect-cables#black-interconnects |
tak diky moc aspon pivo by som mal zobrat:)
Zaslal: So február 20, 2016 00:20:45 Predmet: Linn |
30€
Zaslal: Ut marec 01, 2016 10:39:09 Predmet: Linn Black |
25
Zaslal: So marec 12, 2016 12:49:26 Predmet: |
predane
