henryaudio
Henri
Založený: 30 marec 2015
PríspevokZaslal: Po marec 14, 2016 16:30:49    Predmet: henryaudio Odpovedať s citátom
http://www.henryaudio.com/
podobnosť čisto nahodna Cool
Norwegian Henry Audio breathes new life into your HiFi setup
Henry Audio USB DAC 128 mkII is the result of an international collaboration
Henry Audio USB DAC 128 mkII works with asynchronous USB Audio Class 1 and 2. It supports sample rates up to 192kHz
All the source code and schematics are Open Source
http://www.6moons.com/audioreviews2/henry/1.html
"In your first iterations of the DAC, you employed an ESS Sabre chip. The new DAC has gone with a different chip. Why?
"ESS don't make their products available through typical electronic parts distributors. Getting them in low volumes was a big hassle. But what made me choose another chip was the discovery of an internal math bug in the ES9022/9023. A >-1.3dB full-scale square wave played through their chip will generate great amounts of distortion. With modern compressed music, that isn't just a theoretical occurrence. I worked many years with signal conditioning and was able to see what goes on. In technical terms, the internal FIR filter does a 2's complement overflow where a very positive number actually flips around and becomes a very negative number. This occurs before the sigma-delta modulator. A digital limiter or lower gain in the FIR would solve this." Clap
