NAD 7020i
tantito
Založený: 24 február 2013
PríspevokZaslal: Po apríl 25, 2016 17:13:21    Predmet: NAD 7020i Odpovedať s citátom
Predam Stereo receiver NAD 7020i,vo velmi peknom technickom a optickom stave,bez oderkov a suchancov,vela vstupov plus predzosilnovac na MM prenostku,moznost rozpojit ako koncak a predzosik,pripojenie az dvoch parov repro,v ramci ceny slusny a neutralny zvuk,soft clipping,4-8 Ohm
99€
mojskyd@gmail.com
http://www.manualslib.com/manual/108993/Nad-7020i.html
foto http://elektro.bazos.sk/inzerat/60839173/NAD-7020i.php
 Filesize:  43.7 KB
 Viewed:  95 Time(s)
 Filesize:  55.08 KB
 Viewed:  102 Time(s)
 Filesize:  36.14 KB
 Viewed:  97 Time(s)
Naposledy upravil tantito dňa Ne máj 01, 2016 07:52:40, celkom upravené 1 krát.
tantito
PríspevokZaslal: Po apríl 25, 2016 17:34:22    Predmet: Odpovedať s citátom
PRE-AMP SECTIONPhono inputInput impedance(R and C)Input sensitivity, 1kHzSignal/Noise ratio(A-weighted with cartridge connected)THD(20Hz - 20kHz)RIAA response accuracy(20Hz - 20kHz)Line level inputsInput impedance(R and C)Input sensitivity(ref. 20W)Maximum input signalSignal/Noise ratio(A-weighted ref 1W)Frequency response(20Hz - 20kHz)Infrasonic filterLine level outputsOutput impedanceMaximum output levelTone controlsTrebleBassPOWER AMP SECTIONContinuous output power into 8Rated distortion(THD 20Hz - 20kHz)Clipping power(maximum continuous power per channel)IHF Dynamic headroom at 8IHF dynamic power(maximum short term power per channel)Damping factor(ref. 8 , 50Hz)Input sensitivity(for rated power into 8 )FM TUNER SECTIONInput sensitivityCapture ratio(45 - 65dBf)AM rejection(45 - 65dBf)Selectivity, alternate channelImage rejectionI F rejectionHarmonic distortion Signal/Noise ratio Frequency response ±0.5dB Channel separation at 1kHz AM TUNER SECTION Usable sensitivity Selectivity Image rejection I F rejection Signal/Noise ratio Harmonic distortion Remote NAD Link PHYSICAL SPECIFICATIONS Dimensions (W x H x D) Net weight Shipping weight Power consumption (120 ~ 240V, 50/60Hz) * Minimum power per chnnel, 20Hz - 20kHz, both channels driven with no more than rated distiortion. Dimensions are of unit's cabinet without attached feet; add up to 18mm for total height. Dimension depth excludes terminals, sockets, controls and buttons. © NAD Electronics. All rights reserved. E & OE * Mono -30dB THD+N Mono 30dB S/N Stereo 50dB S/N Stereo 60dB S/N 47k / 100pF 2.4mV ref. 20W 75dB ref. 5mV <0.04% ±0.5dB 40k / 100pF 150mV >10V 84dB +0.5dB, -1.0dB -3db at 15Hz, 24dB/octave Tape Source Z + 1k Phones 220 Tape 10V Phones >10V into 600 >500mV into 8 ±7dB at 10kHz ±10dB at 50Hz 20W (13dBW) 0.03% 25W +2.5dB 8 35W (15.5dBW) 4 35W (15.5dBW) 2 50W (17dBW) >30 900mV 11.3dBf (2.0µV/300 ) 15dBf (3.0µV/300 ) 37dBf (40µV/300 ) 47dBf (120µV/300 ) <1.5dB >60dB 58dB 70dB 90dB Mono 0.1% Stereo 0.1% Mono >80dB Stereo >74dB 30Hz - 15kHz 45dB 5µV 30dB 45dB 35dB 45dB 0.5% No No 420 x 91x 273mm 5.5kg 6.8kg 150W
tantito
PríspevokZaslal: Ne máj 01, 2016 07:52:08    Predmet: Odpovedať s citátom
predane
