Breeze Audio-CM6631 USB DAC
gsmservice3
Založený: 17 október 2010
PríspevokZaslal: So október 01, 2016 08:31:12    Predmet: Breeze Audio-CM6631 USB DAC Odpovedať s citátom
Predám,použité ,plne funkčné. Cena 35eur plus dohoda
Product Description:
* 1 asynchronous USB, the highest support 192KHz/32bit (I2S) and 192K (24BIT) SPDIF coaxial output
* No external power supply, but the board bulk CLC filtering and multiple ASM1117 regulator circuit composed, can CM6631 provides extremely pure DC voltage
* 4 configuration dual crystal Japan KDS high precision SMD crystal
* 5 compatible WINXP WIN7 32BIT and 64BIT system support the DTS source output
* Six regulated power supply, veneer can be used independent 5V power supply, as long as it does not install the board that relatively largeinductance can direct input 5V but board powerful CLC filter Cadogan group regulator circuit in USB mode power supply is also extremelypristine;
* 5 output digital transformer isolation, compatibility is more a
 Filesize:  147.25 KB
 Viewed:  145 Time(s)
www.mobilshopsala.sk
gsmservice3
PríspevokZaslal: So október 01, 2016 08:31:36    Predmet: foto Odpovedať s citátom
dac
 Filesize:  167.35 KB
 Viewed:  163 Time(s)
gsmservice3
PríspevokZaslal: St október 05, 2016 18:27:28    Predmet: Odpovedať s citátom
aktualne
gsmservice3
PríspevokZaslal: Ne október 30, 2016 08:41:41    Predmet: Odpovedať s citátom
aktualne
