Predam img stage line sph-450tc
jao01
Založený: 27 február 2017
PríspevokZaslal: St september 20, 2017 12:06:02    Predmet: Predam img stage line sph-450tc Odpovedať s citátom
Predam tento subwoofer v dobrom stave len je trochu zaprašeny. Novy stoji 570e cenu navrhnite. Je to tento:
http://www.elektrodoplnky.sk/kategoria/monacor/instalacny-material/reproduktory/hi-fi-reproduktory/pa-basove-reproduktory/monacor-sph-450tc-subwoofer-2-x-350-w-2-x-4/
Subwoofer, 2 x 350 W, 2 x 4 Ω Dual voice coil bass speaker of highest power capability Incredible bass pressure from amazingly small cabinets Extensive ventilation of the voice coil High-quality inverse cone Gold-plated terminals Diecast Extra long excursion Double centering spider For professional and semiprofessional DJ and PA applications and for car hi-fi and home cinema applications of highest requirements
Impedance (Z): 2 x 4 Ω
Operating voltage: -
Frequency range: f3-1500 Hz
Resonant frequency (fs): 20 Hz
Rec. crossov. frequ. (fmax.) (12 dB/oct.): 400 Hz
Power rating: 2 x 350 W
Peak music power output: 2 x 500 W
Sensitivity: 93 dB/W/m
Max. rated SPL: -
Max. voltage: -
Radiation angle, horizontal: -
Radiation angle, vertical: -
Suspension compl. (Cms): 0,22 mm/N
Moving mass (Mms): 305 g
Mech. Q factor (Qms): 2,97
Electr. Q factor (Qes): 0,27
Total Q factor (Qts): 0,25
Equivalent volume (Vas): 480 l
DC resistance (Re): 2 x 3.7 Ω/1 x 7.4 Ω
Force factor (BxL): 32,4 Tm
Voice coil induct. (Le): 2 x 1.1 mH/1 x 4.6 mH
Voice coil diameter: Ø99,3 mm
Voice coil former: aluminium
Linear excursion (XMAX): ±12,9 mm
Eff. cone area (Sd): 1250 cm2
Magnet weight: 5,7 kg
Magnet diameter: Ø220 mm
Mounting cutout: Ø425 mm
Mounting depth: 205 mm
Mounting hole diameter: -
Hole spacing X-axis: -
Hole spacing Y-axis: -
Dimensions: Ø 460 mm x 220 mm
Outside diameter: Ø460 mm
Width: Ø460 mm
Height: -
Depth: 220 mm
Protective class: -
Admiss. ambient temp.: 0-40 °C
Weight: 17 kg
Sales unit: 1
Type of speaker: 18"
TEST:
https://www.hifitest.de/test/lautsprecherbausaetze/monacor-raver_cinema_5219
jao01
PríspevokZaslal: Št september 21, 2017 11:01:31    Predmet: Odpovedať s citátom
Predam aj tieto veci: https://elektro.bazos.sk/inzerat/77396677/Predam-Jamo-sub--660260800-a-ine.php
http://www.areadvd.de/hardware/2012/jamo_sub660.shtml
http://www.areadvd.de/hardware/2012/jamo_sub260.shtml
https://www.hifi-regler.de/testberichte/test_jamo_sub_800_kurzfassung.php
jao01
PríspevokZaslal: Št september 28, 2017 17:24:20    Predmet: Odpovedať s citátom
Stale aktualne.
jao01
PríspevokZaslal: St október 04, 2017 08:33:04    Predmet: Odpovedať s citátom
jao01
PríspevokZaslal: St október 11, 2017 17:55:56    Predmet: Odpovedať s citátom
Stale aktualne akurt Jamo sub 260 predane.
jao01
PríspevokZaslal: Po november 06, 2017 20:33:41    Predmet: Odpovedať s citátom
Stale aktualne https://elektro.bazos.sk/inzerat/78941518/Predam-Jamo-sub--660260800-a-ine.php
jao01
PríspevokZaslal: So november 18, 2017 13:41:50    Predmet: Odpovedať s citátom
jao01
PríspevokZaslal: St november 29, 2017 20:34:35    Predmet: Odpovedať s citátom
Stale aktualne https://elektro.bazos.sk/inzerat/79911464/Predam-Jamo-sub--660800Monacor-SPH-450TCHypex-DS-08.php
