ztensablogmss Ready2Die
Založený: 05 január 2021 Príspevky: 1
Zaslal: Ut január 05, 2021 03:50:41 Predmet: Super Quartz Breitling's Chronospace Evo B60 Replica Model |
With all the attention focused on the mechanical debate, the older conflict of mechanical vs. quartz has moved into the background. As one of the most expected Swiss replicas watches brands in the business, however, the Breitling has been betting big on its in-house SuperQuartz chronograph caliber, which is certified by the COS and is not using it only for digital displays anymore.
The brand has just unveiled the Chronospace Evo B60 featuring the first analog-display quartz movement entirely developed by and for the Breitling collection. They are now branding the SuperQuartz as a "100% Breitling engine" and the watch is certainly made to a high standard with a light titanium case and functions including a 24-hour counter, central minutes display with red-tipped hands, and split times
Previously the Chronospace Evo model was famous and popular as the only electronic model exclusively equipped with pointer-type displays. The SuperQuartz is 10 times more precise than a standard quaquartz movement the Chronospace Evo B60, tenths of a second are displayed in a counter between 2 and 3 o'clock. The two central chronograph hands are complemented by a 24-hour counter between 9 and 10 o'clock, "dedicated to missions lasting an entire day." By pressing the ppush-pieceat 4 o'clock, the user can stop the chronograph hands to measure split times while pressing it a second time enables the hands to "catch up with" the correct position and to continue the timing operation in progress. The fake Breitling says this is designed to keep track of several competitors taking part in a race or to measure several successive times during a mission.
The Chronospace Evo B60 also features a unidirectional rotating bezel with four rider tabs serving to mark off times and also improve grip. The titanium case is water-resistant to 100 m (330 ft) and is full of protective reinforcements for its screw-locked crown. The fake watch will be available in two dial versions: one black with slate ggrayounters and the other blue with black counters, equipped with either a bracelet in titanium or a strap in leather or rubber. In purely aesthetic terms, this new Chronospace from the replica Breitling is definitely an improvement, particularly as we've never been overly fond of digital displays. The black dial is a bit tougher looking than the blue, and while the metal bracelet gives it an undeniably rugged appeal we think it will look pretty good on a rubber band. |
