Pionýrský Legato Link - jak to slyšíte?
Kuba4
Založený: 08 október 2006
PríspevokZaslal: Ne október 08, 2006 21:49:15    Predmet: Pionýrský Legato Link - jak to slyšíte? Odpovedať s citátom
Mi učaroval, tlačí na basy, ale atmoška je tam.
coffee
Založený: 04 október 2006
PríspevokZaslal: Ne október 08, 2006 23:10:07    Predmet: Odpovedať s citátom
Naposledy upravil coffee dňa St jún 02, 2010 16:16:09, celkom upravené 1 krát.
PríspevokZaslal: Po október 09, 2006 09:35:36    Predmet: Odpovedať s citátom
Na webu jsem našel toto:
Legato Link Conversion
For as great as CDs sound, the digital recording process clips off important musical shadings and nuances above 22.5kHz. These signals contain important clues about musical texture and shape that define a live musical event. Pioneer's Legato Link Conversion system "links" digital samples together every 20 microseconds and then applies a special psychoacoustic processing formula to restore missing high frequency dynamics to fully recapture all the shading and detail of the original performance.
Restores high-frequency dynamics lost in the digital recording process, to fully reproduce all the shading and detail of the original musical performance.
Legato Link Conversion "S"
(Elite PDR-99 CD Recorder only) An integral part of Pioneer's advanced Wide Band Technology, Legato Link Conversion S - an advanced version of Pioneer's innovative Legato Link technology - restores the rich harmonics and overtones that are lost in the digital recording process. It accomplishes this by "linking" one digital sample of musical information to another every 20 microseconds and then applying carefully formulated algorithms to extrapolate missing ultra-harmonic frequencies that nevertheless preserve the intrinsic flavor and personality of the original performance.
Takže pokud Kuba mluví o basech, tak to s legato link nemá nic společného - tipuji si na slušný analogový filtr a nízkou výstupní impedanci bufferů CDP.
Jinak OBNOVIT informaci ve frekvencích nad polovinou vzorkovací frekvence z principu NEJDE. Taková informace tam prostě NENÍ. Lze si něco VYMYSLET a vydávat to za původní frekvence. Ten popis neříká nic o tom, jak to dělají, protože "linking one digital sample of musical information to another every 20 microseconds and then applying carefully formulated algorithms to extrapolate missing ultra-harmonic frequencies" dělá každý oversampling digitální filtr (20 us je v podstatě doba mezi dvěma vzorky na CD, mezi které filtr interpoluje nové vzorky), akorát takový filtr tam nezavádí vyšší frekvence, ale naopak to řeže přesně na 22kHz.
Může to znít jinak, může to znít příjemně, ale v žádném případě nejde o obnovení původní informace.
Kuba4
PríspevokZaslal: Po október 09, 2006 11:48:17    Predmet: Více vlivů, samozřejmě. Odpovedať s citátom
Jo LL ten zvuk samozřejmě nedělá sám. Vliv bude mít i obrácená mechanika a ty basy jsou asi jiné záměrně.
coffee
PríspevokZaslal: Po október 09, 2006 15:42:32    Predmet: Odpovedať s citátom
Naposledy upravil coffee dňa St jún 02, 2010 16:16:27, celkom upravené 1 krát.
Troton
Site Admin
Založený: 11 august 2006
PríspevokZaslal: Po október 09, 2006 21:36:07    Predmet: Odpovedať s citátom
Legato link podla mna zvuku znacne pomaha, na DVD Pioneer 646A je dost pocutelny.
PríspevokZaslal: Po október 09, 2006 22:10:59    Predmet: Odpovedať s citátom
A lze jej zapnout/vypnout, aby bylo možné porovnat s klasickým (pouhým) digitálním filtrem ve stejném přehrávači (převodníky, analog. část, zdroje)?
Troton
Site Admin
PríspevokZaslal: Ut október 10, 2006 08:08:01    Predmet: Odpovedať s citátom
Nie je to moj stroj, ale znameho, no co si pamatam, ma to nastavenie OFF a potom dalsie dve urovne. On to pocuval vzdy na tej najvyssej.
MSW
Založený: 18 október 2006
PríspevokZaslal: St november 01, 2006 12:06:51    Predmet: Odpovedať s citátom
Je taky Pioneer tak pionýrský jako je Denon denoňácký? Tedy charakteristický?
Nothing is best
Odowakar
Založený: 05 december 2006
PríspevokZaslal: So december 09, 2006 18:24:44    Predmet: Odpovedať s citátom
MSW
Mám Pioneery už pár let a dá se říct, že mají určitý svůj charakter zvuku. Vždycky měly dobré basy a ani ostatní pásma se nemusely nikdy stydět. Mechaniky byly taky vždy na špici - viz třeba PD95 neboPD77.
Co je ale nejvíc odlišovalo od většiny ostatních, to byla jejich schopnost "vybírat" si nahrávky. Denon, Rotel, Marantz, NAD a ostatní prostě přehrají všechno svým způsobem stejně. Pioneer některé styly přehraje stejně jako ony, některé o něco hůř a nějaké zase lépe. Z mých zkušeností vyplývá, že třeba elektronickou hudbu, metal, velké symfonické tělesa nepřehraje tak přesvědčivě, jako konkurence. Naopak rock typu Dire Straits, Jethro Tull, Marianne Faithfull, Pink Floyd nebo třeba country či swing (např. O. Havelka) přehraje lépe než jiné přehrávače.
Při nákupu Pioneera je zkrátka třeba vzít v úvahu druh poslouchané hudby více v úvahu než u jiných přehrávačů. Pokud se strefíš, je to paráda.
Haxna
Založený: 23 november 2006
PríspevokZaslal: Ne december 10, 2006 09:46:46    Predmet: Odpovedať s citátom
Kuba4
Jakej vliv na zvuk ma obracena mechanika v nekterych prehravacich Pionner ? Prosim o vysvetleni ?
Kuba4
PríspevokZaslal: Ne december 10, 2006 13:27:34    Predmet: Odpovedať s citátom
Mechanika je pouze spolehlivá, čte, co je na cd. Spolehlivěji než normální mechanika, CD se méně chvěje (protože leží na talíři) a na čočku se méně práší (svítí zhora). V konečném důsledku vydží déle, šetří se třeba serva pro doostřování. CD, které nepřečtu v PC mi 801čka přehrává bez problémů i po 14 letech každodenního provozu.
Co se týká těch basů, nemusí to být, podle mně, jen analogovým filtrem, ale klidně tím LL. Protože si "vymýšlí", přebuduje trochu kmitočtový průběh, tím se mohou zdát basy lepší. Je to asi, jak píše Troton a Odowakar, někdy to nahrávce pomůže jindy ne. Výhodu mají Ti, kdo mohou LL vypínat, když to není ono. Podobně jako přepínatelné filtry v přehrávačích Sony ES.
Haxna
PríspevokZaslal: Ne december 10, 2006 14:48:03    Predmet: Odpovedať s citátom
Kuba4
Psal jsi, cituji: Jo LL ten zvuk samozřejmě nedělá sám. Vliv bude mít i obrácená mechanika a ty basy jsou asi jiné záměrně.
Stale jsem se nedozvedel, jaky vliv na zvuk muze mit mechanika "stable platter" od klasicke mechaniky.
Kuba4
PríspevokZaslal: Ne december 10, 2006 15:40:26    Predmet: Odpovedať s citátom
Z mé strany jsem napsal vše, spolehlivější čtení dat.
Pokud čekáš podrobné vysvětlení, tak ode mně ne. V korekcích čtení CD se moc nevyznám a nedokážu říct jestli čip řídící mechaniku z číny nebo malajsie celý proces řeší lépe či hůře. Taky fakt, že to už OM nedělají mnohé napoví, asi se to nevyplatilo.
Co se týká těch jiných basů, tam to vidím na ten dopočítávaný efekt LL nebo na analogový filtr.
Neslyšel jsem model Pioneer bez obrácené mechaniky a s LL. Vždy jen v kombinaci. 95, 77, 801, 703, 505.
Slyšel jsi některý z těch cd přehrávačů s obrácenou mechanikou? Jak bys rozdílný zvuk vysvětlil Ty? Myslíš, že mechaniky jsou stejné?
Odowakar
PríspevokZaslal: Ne december 10, 2006 20:01:00    Predmet: Odpovedať s citátom
Haxna
Nevím proč má Pioneer takové basy. Ale asi všechny přehrávače s obrácenou mechanikou se tím vyznačují - náhoda? snad. Ony ty basy nejsou oproti jiným přehrávačům snad ani tak o mnoho hlubší, spíš tak nějak přirozenější, zábavnější, někdo by řekl analogovější, ale to je asi blbost. Nemyslím že LL zkresluje, např. mojí 707čku v testu měřil p.Láb a výsledky byly vpořádku.
Těžko věřit že to bude mít na svědomí pouze mechanika, asi to bude od všeho trochu a konstruktéři tak vtiskli Pioneerům jejich charakteristický zvuk.
Ale je třeba korektně říct, že to nejsou rozdíly, které tě okamžitě praští vší silou přes uši - je třeba delší dobu poslouchat. A opět připomínám - pinďour je vybíravej hajzlík!
Haxna
PríspevokZaslal: Po december 11, 2006 02:23:41    Predmet: Odpovedať s citátom
2 Kuba
Nechci prudit. Jen nesnasim, kdyz se na obchodnich kecech typu "stable platter" zaklada podvedomi lidi, ze je to proste zvukove lepsi (v cem ???). Je to jako ve starem Stereu & Videu, kdyz nekdo doporucoval nabarvit okraje CD zelenym fixem pro lepsi cteni - od te doby uz ten casak nekupuji. Mam 16 let stary prehravac TESLA MC911 - PHILIPS CD460 - klasika - laser dole (uz vidim vysmech slucharu, kteri vubec netusi, jak CD prehravac funguje, ale rozdily na zaklade reklamy proznaji, pac muj 16 let stary stroj je v porovnani s jejich shit, ale ve cteni poskrabanych CD da na prdel kdejakymu jinymu za 20-ti nasobnou cenu). Mam ho vybaveny dle doporuceni velmi znalych lidi (Jejkal, Stranak - pochybuji, ze nekdo vi, o koho jde) signalizaci bezchybneho cteni prehravaneho CD a bez naznaku chyb precte na cca 95% vse (vyjma RW, ktere neumi). V cem muze byt jeho mechanika jina - z dekoderu mi lezou bezchybna data, dokud se neohlasi interpolace (ani tam to neni kolikrat slyset - snad proto, z nemam aparat za 500 tisic ??). A jak ovlivni zvuk ? Mechanika bud cte a nebo ne. Zmena zvuku je blbost. Prectete si prosim pred temito vyroky neco o RED BOOK a taky neco o Reed Solomonovu opravnem kodu. Pak kazdy pochopi, ze to bud hraje, nebo lupe, nedejboze preskakuje. Zmena prostoru, basu, vysek, barvy, pruzracnosti a dalsich pro mne nepochopitelnych zmen jsou s prominutim kraviny. Abych nebyl offtopic, tak Legato Link je dalsi obchodni tah, aby lidi zaplatili za neco, co mozna muze znit lepe, ale pro lidi z branze HI-FI (vernost !) to nema zadnou vahu. Jen zdimani penez z neznalych. Toliko odemne. Muzu dodat materialy pro studium principu CD dle specifikace RED BOOK pro lidi, kteri nebudou resit problem zvuku v mechanikach, ale v naslednem zpracovani - D/A prevod atd... Toto neni pro Dusina !! Laughing
Kuba4
PríspevokZaslal: Po december 11, 2006 07:49:03    Predmet: Odpovedať s citátom
4Haxna
Já si rád přečtu. Máš ty materiály jen na papíře nebo i v elektronické formě? Dík
Kuba4
PríspevokZaslal: Po december 11, 2006 08:07:54    Predmet: Odpovedať s citátom
4 Haxna
Wikipedia potvrzuje, co si napsal, mechanika buď čte vše a hraje nebo čte částečně, opravuje a hraje nebo čte částečně lupe, praská nebo přeskakuje
OK. Beru zpět mystifikaci, že se obrácená mechanika podílí na "jiném" zvuku přehrávačů Pioneer.
"korekce" zvuku bude v převodníku nebo pravděpodobněji v analogové části
Nemáš náhodou knihu o přehrávačích číslicových desek?
PríspevokZaslal: Po december 11, 2006 08:56:21    Predmet: Odpovedať s citátom
Korekce zvuku lze nesnadněji udělat v digitální oblasti - LL může posilovat basy, stejně již s původními daty dělá psí kusy.
Haxna
PríspevokZaslal: Po december 11, 2006 09:05:47    Predmet: Odpovedať s citátom
Kuba
Neco mam v elektronicke podobe, neco muzu naskenovat a poslat treba na mail, ju ? Okamzite Ti muzu poskytnout pekny clanek z casopisu Amaterske radio (tusim z roku 92 Smile ve formatu pdf), kde je prave od autoru Jejkal, Stranak srozumitelne a v cestine popsan princip klasickeho CD prehravace.
Ghost
Založený: 09 október 2006
PríspevokZaslal: Po december 11, 2006 09:06:33    Predmet: Odpovedať s citátom
PIONEER PD-S703 vybaveny legato linkem ma pokles na 20kHz -4dB. Tento pokles neni zpusoben vystupnimi analogovymi obvody, deje se na digitalni strane. Zvuk je diky tomu zemitejsi a basu se zda objemove vice.
Kuba4
PríspevokZaslal: Po december 11, 2006 09:09:26    Predmet: Odpovedať s citátom
Haxna napísal:
4Haxna
Budu rád, když mi to pošleš. Díky
4Ghost
Neměřil si nějaký přehrávač Pioneer, kde se LL dá vynout?
Ghost
PríspevokZaslal: Po december 11, 2006 09:14:49    Predmet: Odpovedať s citátom
to Kuba:
Ne.
PríspevokZaslal: Po december 11, 2006 09:26:40    Predmet: Odpovedať s citátom
Ghost napísal:
To může být způsobeno i nízkým řádem digitálního filtru při oversamplingu - místo ostrého brickwall filtru na 21-22kHz použijí méně ostrý - vložené vzorky při oversampligu pak nebudou tak vyhlazené (tedy do signálu se "vymyslí" frekvence na fs, ale zase bude díky malé strmosti pokles i na frekvencích mírně pod fs). A nebo je to úplně jinak Smile
Kuba4
PríspevokZaslal: Po december 11, 2006 11:13:21    Predmet: Odpovedať s citátom
Zajímavý článek je tady, ale ten asi všichni už znají, že?
Na audio digitálně
PríspevokZaslal: Po december 11, 2006 11:37:28    Predmet: Odpovedať s citátom
Čtivě napsané, ale přijde mi to trochu zmatené. Bez vysvětlení tam najednou začne motat přijímač SPDIF. Tuto hlášku jsem nepochopil:
Opravdu tristní a nepochopitelnou (technicky) skutečností však zůstává, že se vyskytují i jednoduchá zařízení (CD přehravače) mající veškeré časování zavěšeno na jediný neošetřený oscilátor, kterým se řídí VŠE. Těmito přístroji pak jakékoli poruchy projdou jako nůž máslem a nám nezbývá, než nějak vhodně zajistit jejich ekologickou recyklaci, protože jinak bude veškerá naše snaha zajistit si kvalitní poslech završena pouze žalem a bolestí. Nad existencí těchto "perel Hi-Fi techniky" můžeme propadat zoufalství tím spíše, že celý problém by vyřešily obvodové změny prodražující přístroj maximálně o desítky korun. Na milost se dají vzít takovéto šmejdy pouze v případě, že jsou vybaveny digitálním výstupem. Pak ovšem kvalitní převodník odstraní problémy beze zbytku. (Pokud není někomu jasné proč, nechť se vrátí na začátek kapitoly.)
Odowakar
PríspevokZaslal: Po december 11, 2006 16:28:32    Predmet: Odpovedať s citátom
Haxna
Pana Jejkala a Straňáka znám pouze z některých jejich článků a klidně s tebou souhlasím, že jsou to odborníci na danou tematiku. Věřím, že Tvůj přehrávač hraje dobře - proč ne?
Já taky nepoznám ve slepém testu přehrávač od přehrávače, pokud jsou ale ve stejné (alespoň přibližně) cenové kategorii. Ovšem z tvého příspěvku vyznívá, jakoby nebyly rozdíly - zvukové - mezi přehrávači žádné. Buď přečte nebo ne a pokud ano, musí to hrát stejně. To není samozřejmě pravda. Rozdíly ve zvuku mezi třeba Naim CDX a dejme tomu Rotelem za desítku je velký. Jestli je to v analogové, digitální části, v mechanice, v kombinaci všeho je mi srdečně jedno. Nemusím rozumět do detailu (ale třeba nemusím rozumět vůbec) tomu, jak přesně fungují jednotlivé části přehrávače. To k poslechu vážně nepotřebuješ, věř mi.
Ghost
Ten pokles měli starší typy a to ještě ty levnější. Novější modely už žádný pokles nemají.
Haxna
PríspevokZaslal: Po december 11, 2006 17:22:42    Predmet: Odpovedať s citátom
Odowakar
Mozna, ze jsem nektere veci spatne formuloval - preci jen bylo pul treti rano a unava se projevila. Nicmene jsem chtel rici, ze mechanika jako takova, nebude mit zadny vliv na charakter zvuku typu vice/mene basu, vice/mene vysek, jiny prostor a podobne nesmysly (at je s linearnim, nebo ramenkovym posuvem snimaciho mechanismu, nebo i otocenou mechanikou). Bud cte dobre, nebo s chybama a projev bude na urovni praskani, nebo vypadku zvuku.
Nebo necte vubec ...... ale ta by letela z okna. Dle mne ma na vysledny zvuk vliv pouze kvalita D/A prevodniku (vcetne digitalniho filtru), analogove casti (vcetne dostatecne kvalitnich zdroju) a pripustim i pro "jitter-isty" kvalitu oscilatoru v generatoru systemovych hodin. Takze omluva, pokud to predtim vyznelo jinak.. Wink
PríspevokZaslal: Po december 11, 2006 17:47:57    Predmet: Odpovedať s citátom
Haxna napísal:
Odowakar
Souhlas. Ještě bych vypíchl ten zdroj - při seekování mechaniky je na napájecích linkách pěkný bordel.
Ke tvé Tesle - mám MC902, šlape jako hodinky. Bavil jsem se s profi opraváři, prý je používají jako testovací CD do dílen (i můj případ Smile ), protože vydrží všechno a přečtou všechno.
Odowakar
PríspevokZaslal: Po december 11, 2006 18:12:27    Predmet: Odpovedať s citátom
Haxna, Dustin
Souhlasim, určitě mají převodníky rozhodující význam a pak to všechno ostatní. Ale on ten talířek u Pioneera je tak hezkej Laughing
