onb Hifi obsluha
Založený: 19 september 2013 Príspevky: 14
Zaslal: Po september 17, 2018 12:35:58 Predmet: Tannoy System 6 NFM II |
Predám tieto vynikajúce koaxiálne bedne z legendárnej série vo výbornom stave. Cena 300 EUR
Specifications System 6 NFM II
Recommended Amplifier Power: 20 to 150 watt RMS
Peak Power Handling: 175 watt
Nominal Impedance: 8 Ω
Sensitivity (2,83 volts at 1m): 91 dB
Distortion: less than 0,75% (52 Hz - 25 kHz)
Phase Response: System behaves substantially as a frequency-independent time delay
Dispersion: 90 degrees conical
Crossover Frequency: 2 kHz
Crossover Type: 2nd order LF, 1st order HF Hard-Wired, low-loss, Positive acoustic polarity
Frequency Response (±3 dB): 52 Hz - 25 kHz
Drive Unit Type: 6,5 inch, 1667 Dual Concentric
Cabinet Internal Volume: 10 litres
Cabinet Material: 30,6 mm MDF front baffle; 15 mm high density particle board lined with TF-1 acoustic wadding
Cabinet Finish: High quality vinyl finish. Velti shadow grey soft-texture finish baffle
Grille: Single piece, black acoustically transparent material over a rigid frame
Dimensions (H x W x D): 345 x 230 x 223 mm (13,6" x 9,1" x 8,8")
Weight (net): 5,7 kg (12,6 lb)
http://stereonomono.blogspot.com/2014/03/tannoy-system-6-nfm-ii.html
https://www.hilberink.nl/codehans/tansys215.pdf
227.74 KB |
139 Time(s) |
